file:///c:/documents and settings/yibin_pan/application data/360se6/User Data/temp/205743w19ae5cupag7u85x.png请问大家谁用过MSP430G2201的芯片Datasheet上说
Serial Onboard Programing是意味着可以用BSL下载吗?如果可以是如何连接TX,RX啊谢谢
Serial Onboard Programming,
No External Programming Voltage Needed
Programmable Code Protection by
Security Fuse
