[技术问答] Nano102使用HIRC作为时钟源PWM输出9Mhz的频点,麻烦各位大神看
3975|3
 楼主| lc_mazha 发表于 2015-1-4 11:03 | 显示全部楼层 |阅读模式
* @file     main.c
* @version  V1.00
* $Revision: 7 $
* $Date: 14/03/27 1:43p $
* @brief    PWM sample for NANO1X2 series MCU
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Nano1X2Series.h"
#define SAMPLE_CNT 32
static uint8_t volatile cap_index;
static uint32_t cap_val[SAMPLE_CNT >> 1][2];
void PWM0_IRQHandler(void);
    static uint8_t token = 0;
    uint32_t u32CapIntFlag;
    uint8_t u8Count = cap_index;
    if(u8Count >= SAMPLE_CNT)
        return;
    // Get channel 2 capture interrupt flag
    u32CapIntFlag = PWM_GetCaptureIntFlag(PWM0, 2);
    // Rising latch condition happened
    if ((u32CapIntFlag & PWM_RISING_LATCH_INT_FLAG) && token == 0) {
        cap_val[u8Count >> 1][0] = PWM_GET_CAPTURE_RISING_DATA(PWM0, 2);
        cap_index++;
        token = 1;
    // Falling latch condition happened
    if ((u32CapIntFlag & PWM_FALLING_LATCH_INT_FLAG) && token == 1) {
        cap_val[u8Count >> 1][1] = PWM_GET_CAPTURE_FALLING_DATA(PWM0, 2);
        cap_index++;
        token = 0;
    // Clear channel 2 capture interrupt flag
    PWM_ClearCaptureIntFlag(PWM0, 2, PWM_RISING_FALLING_LATCH_INT_FLAG);
/* Init System Clock        */
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable  HIRC */
    CLK_EnableXtalRC(CLK_PWRCTL_LXT_EN_Msk | CLK_PWRCTL_HIRC_EN_Msk);
    /* Waiting for clock ready */
      CLK_WaitClockReady(CLK_CLKSTATUS_LXT_STB_Msk | CLK_CLKSTATUS_HIRC_STB_Msk);
    /* Enable PWM clock */
    CLK_EnableModuleClock(PWM0_CH01_MODULE);
    CLK_EnableModuleClock(PWM0_CH23_MODULE);
    /* Set HIRC as PWM clock source */
    CLK_SetModuleClock(PWM0_CH01_MODULE, CLK_CLKSEL1_PWM0_CH01_S_HIRC, 0);
    CLK_SetModuleClock(PWM0_CH23_MODULE, CLK_CLKSEL1_PWM0_CH23_S_HIRC, 0);
    /* Init I/O Multi-function        */
    /* Set PC.0 and PC.2 multi-function pins for PWM channel 0 and 2 */
    SYS->PC_L_MFP = (SYS->PC_L_MFP & ~SYS_PC_L_MFP_PC0_MFP_Msk) | SYS_PC_L_MFP_PC0_MFP_PWM0_CH0;
    SYS->PC_L_MFP = (SYS->PC_L_MFP & ~SYS_PC_L_MFP_PC2_MFP_Msk) | SYS_PC_L_MFP_PC2_MFP_PWM0_CH2;
    /* Lock protected registers */
    SYS_LockReg();
int32_t main (void)
//    uint8_t i;
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    // PWM0 frequency is 9000000Hz, duty 50%,
    PWM_ConfigOutputChannel(PWM0, 0, 9000000, 50);
    // Enable output of channel 0
    PWM_EnableOutput(PWM0, PWM_CH_0_MASK);
    // Start
    PWM_Start(PWM0, PWM_CH_0_MASK);
    while(1);
mintspring 发表于 2015-1-4 13:44 | 显示全部楼层
你到底想问什么啊?说清楚点。
gaoyang9992006 发表于 2015-1-5 15:48 | 显示全部楼层
不知道楼主该程序运行后是不是不满足要求,还是有什么故障无法运行啊,请楼主给出问题的关键所在。
niuyaliang 发表于 2015-1-6 17:43 | 显示全部楼层
迷糊的问题,,,
