[DSP编程] CCS3.3用Memory看CE空间地址数据 就会连接不上仿真器 什么原因
2384|2
 楼主| wushaojay 发表于 2015-1-4 15:16 | 显示全部楼层 |阅读模式
在自己做的板子上测试,目前在测试FLASH模块,其他模块是没有问题的。 FLASH和DSP的解法参考的是这个图
只有AOE引脚我换成了ARE引脚 其他一样。 但现在就是用Memory看CE空间地址数据 仿真器就自动断开连接 提示错误为
Trouble Reading Memory Block at 0x40000 on Page 1 of Length 0x63: Error 0x80000002/-1144 Fatal Error during: Memory,  The memory at 0x00080000 continually indicated it was 'not ready' The emulator was unable to regain control of the processor. The processor must be reset.   Sequence ID: 65 Error Code: -1144 Error Class: 0x80000002
Error connecting to the target: Error 0x80000242/-1144 Fatal Error during: Memory, Initialization, OCS,  The memory at 0x00000800 continually indicated it was 'not ready' The emulator was unable to regain control of the processor. The processor must be reset.   Sequence ID: 0 Error Code: -1144 Error Class: 0x80000242
求大神们,给我分析分析,谢谢了
JY-DX-JY 发表于 2015-1-4 16:55 | 显示全部楼层
看看JTAG电路。
 楼主| wushaojay 发表于 2015-1-4 17:05 | 显示全部楼层
看看JTAG电路。
JTAG没有问题 其他模块可以用 程序可以下载运行
