[i.MX] i.mx6Q-SDB eMMC启动问题
1971|4
 楼主| 流星恋人 发表于 2015-1-4 21:55 | 显示全部楼层 |阅读模式
i.mx6Q-SDB板,通过工具Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER,uboot kernel可以烧写到SD卡中可以正常启动,但烧写eMMC时,烧写过程正确,完成后启动系统串口没有任何打印信息。具体过程如下:
1,MFGtool版本为4.1.0_130816
2,ucl2.xml烧写eMMC的代码如下,没做任何改动。
<LIST name="SabreSD-eMMC" desc="Choose eMMC Linux as media">
    <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6q-sabresd.bin" >Loading U-boot</CMD>
    <CMD state="BootStrap" type="load" file="uImage" address="0x10800000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD>
    <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
    <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
        <CMD state="Updater" type="push" body="$ ls /dev/*"/>
        <CMD state="Updater" type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16">clean up u-boot parameter</CMD>
        <CMD state="Updater" type="push" body="$ echo 0 > /sys/block/mmcblk0boot0/force_ro">access boot partition 1</CMD>
        <CMD state="Updater" type="push" body="send" file="files/u-boot-mx6q-sabresd.bin">Sending U-Boot</CMD>
        <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2">write U-Boot to sd card</CMD>
        <CMD state="Updater" type="push" body="$ echo 1 > /sys/block/mmcblk0boot0/force_ro"> re-enable read-only access </CMD>
        <CMD state="Updater" type="push" body="$ echo 8 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config">enable boot partion 1 to boot</CMD>
    <CMD state="Updater" type="push" body="send" file="files/uImage">Sending kernel uImage</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync">write kernel image to sd card</CMD>
    <CMD state="Updater" type="push" body="send" file="mksdcard.sh.tar">Sending partition shell</CMD>
    <CMD state="Updater" type="push" body="$ tar xf $FILE "> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ sh mksdcard.sh /dev/mmcblk0"> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ mkfs.ext3 -j /dev/mmcblk0p1">Formatting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ mkdir -p /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="pipe tar -jxv -C /mnt/mmcblk0p1" file="files/rootfs.tar.bz2">Sending and writting rootfs</CMD>
    <CMD state="Updater" type="push" body="frf">Finishing rootfs write</CMD>
    <CMD state="Updater" type="push" body="$ umount /mnt/mmcblk0p1">Unmounting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
</LIST>
3,烧写eMMC将cfg.ini文件改写如下,和 ucl2.xml内容相对应:
[profiles]
chip = MX6Q Linux Update
[platform]
board = SabreSD
[LIST]
name = SabrSD-eMMC
4,eMMC拨码开关设置如下:在烧写过程
eMMC拨码开关应该设置如下:(download mode)
Switch D1   D2  D3  D4   D5  D6  D7 D8
SW6   OFF OFF OFF OFF ON  ON OFF OFF
烧写完成后,断电,设置eMMC拨码开关设置如下:( emmc boot mode)
SW6   ON ON OFF ON OFF ON ON OFF
给板子上电,启动。
什么原因造成的呢?难道是工具Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER的问题?
FSL_TICS_Rita 发表于 2015-1-5 12:26 | 显示全部楼层
楼主你好,这里应该不是烧写工具的问题,我看你的设置都是OK的,并且SD卡也是可以正常启动的。这样,你手上只有一块板子吗?如果有多余的板子,建议你试一下,看是不是EMMC有问题。
请问u-boot也没有起来,对吗?
FSL_TICS_Rita 发表于 2015-1-6 16:21 | 显示全部楼层
楼主你好,请问现在从emmc可以正常启动了吗?
FSL_TICS_Rita 发表于 2015-1-6 16:22 | 显示全部楼层
请问你这里是使用飞思卡尔官网提供的开发板还是自己设计的板子呢?
