[AVR单片机] RFM12B基于ATmega48的程序,要移植到ATmega128a中,需要改哪些地方呢!
1563|0
 楼主| 你是我的专属 发表于 2015-1-5 18:42 | 显示全部楼层 |阅读模式
#include <mega48.h>
#define                DDR_IN      0
#define                DDR_OUT         1
#define            PORT_SEL        PORTB
#define     PIN_SEL                PINB
#define                DDR_SEL                DDRB
#define                PORT_SDI        PORTB
#define     PIN_SDI                PINB
#define                DDR_SDI                DDRB
#define            PORT_SCK        PORTB
#define     PIN_SCK                PINB
#define                DDR_SCK                DDRB
#define                PORT_SDO        PORTB
#define     PIN_SDO                PINB
#define                DDR_SDO                DDRB
#define     PORT_IRQ        PORTD
#define                PIN_IRQ                PIND
#define                DDR_IRQ                DDRD
#define                PORT_DATA        PORTD
#define     PIN_DATA        PIND
#define                DDR_DATA        DDRD
#define                PB7                        7
#define                PB6                        6
#define                RFXX_SCK        5
#define                RFXX_SDO        4
#define                RFXX_SDI        3
#define                RFXX_SEL        2
#define                NC                        1
#define                PB0                        0
#define                SEL_OUTPUT()        DDR_SEL |= (1 << RFXX_SEL)
#define                HI_SEL()                PORT_SEL |= (1 << RFXX_SEL)
#define                LOW_SEL()                PORT_SEL &= ~(1 << RFXX_SEL)
#define                SDI_OUTPUT()        DDR_SDI |= (1 << RFXX_SDI)
#define                HI_SDI()                PORT_SDI |= (1 << RFXX_SDI)
#define                LOW_SDI()                PORT_SDI &= ~(1 << RFXX_SDI)
#define                SDO_INPUT()                DDR_SDO &= ~(1 << RFXX_SDO)
#define                LOW_SDO()                PORT_SDO &= (1 << RFXX_SDO)
#define                SDO_HI()                PIN_SDO & (1 << RFXX_SDO)
#define                SCK_OUTPUT()        DDR_SCK |= (1 << RFXX_SCK)
#define                HI_SCK()                PORT_SCK |= (1 << RFXX_SCK)
#define                LOW_SCK()                PORT_SCK &= ~(1 << RFXX_SCK)
#define                RF12_IRQ                2
#define                IRQ_IN()                DDR_IRQ &= ~(1 << RF12_IRQ)
#define                WAIT_IRQ_LOW()        while(PIND & (1 << RF12_IRQ))
#define                RF12_DATA                4
#define                DATA_OUT()                DDR_DATA |= (1 << RF12_DATA)
#define                HI_DATA()                        PORT_DATA |= (1 << RF12_DATA)
#define                LEDG_OUTPUT()        DDRD |= ~(1 << 6)
#define                LEDR_OUTPUT()        DDRD |= ~(1 << 7)
#define                LEDG_ON()                PORTD &= ~(1 << 6)
#define                LEDG_OFF()                PORTD |= (1 << 6)     //PORTD |= !(1<<6)
#define                LEDR_ON()                PORTD &= ~(1 << 7)
#define                LEDR_OFF()                PORTD |= (1 << 7)      //
void RFXX_PORT_INIT (void)
        HI_SEL();
        HI_SDI();
        LOW_SCK();
        HI_DATA();
        SEL_OUTPUT();
        SDI_OUTPUT();
        SDO_INPUT();
        SCK_OUTPUT();
        IRQ_IN();
        DATA_OUT();
unsigned int RFXX_WRT_CMD (unsigned int aCmd)
        unsigned char i;
        unsigned int temp;
        temp = 0;
        LOW_SCK();
        LOW_SEL();
        for (i=0; i<16; i++)
                if (aCmd & 0x8000)
                        HI_SDI();
                else
                        LOW_SDI();
                HI_SCK();
                if (aCmd & 0x8000)
                        HI_SDI();
                else
                        LOW_SDI();
                HI_SCK();
                temp <<= 1;
                if (SDO_HI())
                        temp |= 0x0001;
                LOW_SCK();
                aCmd <<= 1;
        HI_SEL();
        return(temp);
void RF12_INIT (void)
        RFXX_WRT_CMD(0x80E7);
        RFXX_WRT_CMD(0x8239);
        RFXX_WRT_CMD(0xA686);
        RFXX_WRT_CMD(0xC647);
        RFXX_WRT_CMD(0x94A0);
        RFXX_WRT_CMD(0xC2AC);
        RFXX_WRT_CMD(0xCA81);
        RFXX_WRT_CMD(0xCED4);
        RFXX_WRT_CMD(0xC483);
        RFXX_WRT_CMD(0x98B0);
        RFXX_WRT_CMD(0xCC67);
        RFXX_WRT_CMD(0xE000);
        RFXX_WRT_CMD(0xC800);
        RFXX_WRT_CMD(0xC000);
/*        RFXX_WRT_CMD(0x80D7);
        RFXX_WRT_CMD(0xA640);
//        RFXX_WRT_CMD(0xCA83);
        RFXX_WRT_CMD(0x9850);
//        RFXX_WRT_CMD(0xCC67);
        RFXX_WRT_CMD(0xC400);     */
unsigned char RF12_RECV (void)
        unsigned int FIFO_data;
        WAIT_IRQ_LOW();
        RFXX_WRT_CMD(0x0000);
        FIFO_data = RFXX_WRT_CMD(0xB000);
        return(FIFO_data & 0x00FF);
void Delay_ms (unsigned char amS)
        unsigned char i;
        unsigned int j;
        for (i=0; i<amS; i++)
                for (j=0; j<914; j++);
void main(void)
        unsigned char i;
        unsigned char ChkSum;
        LEDG_OFF();
        LEDR_OFF();
        LEDG_OUTPUT();
        LEDR_OUTPUT();
        for (i=0; i<3; i++)
                Delay_ms(200);
                LEDG_ON();
                LEDR_ON();
                Delay_ms(200);
                LEDG_OFF();
                LEDR_OFF();
        LEDG_OFF();
        LEDR_OFF();
        RFXX_PORT_INIT();
        RF12_INIT();
        while (1)
                ChkSum = 0;
                        ChkSum += RF12_RECV();
                i = RF12_RECV();
                if(ChkSum == i)
                        LEDG_ON();
                        Delay_ms(200);
                        LEDG_OFF();
