PIC12F629内部4M振荡在C语言中校准
4389|8
 楼主| dcp 发表于 2008-8-3 22:27 | 显示全部楼层 |阅读模式
main<br />;校准内部振荡器<br />;--------------------------------------------------------------------<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;call&nbsp;&nbsp;&nbsp;&nbsp;0x3FF&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;retrieve&nbsp;factory&nbsp;calibration&nbsp;value<br />&nbsp;&nbsp;&nbsp;&nbsp;bsf&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;STATUS,RP0&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;set&nbsp;file&nbsp;register&nbsp;bank&nbsp;to&nbsp;1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;movwf&nbsp;&nbsp;&nbsp;OSCCAL&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;;&nbsp;update&nbsp;register&nbsp;with&nbsp;factory&nbsp;<br />汇编中这是样的<br /><br />c语言:<br /><br />#define&nbsp;&nbsp;&nbsp;OSCCAL_CHECK&nbsp;(*(const&nbsp;unsigned&nbsp;char&nbsp;*)0x3ff)&nbsp;//读取flash&nbsp;0x3ff的振荡校准值<br /><br />main()<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;while&nbsp;(1)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;OSCCAL&nbsp;=&nbsp;OSCCAL_CHECK;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;...&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br /><br /><br />
 楼主| dcp 发表于 2008-8-4 00:53 | 显示全部楼层
编译器。。。
#define&nbsp;OSCCAL_CHECK(*(unsigned&nbsp;char(*)())0x3FF)()
yewuyi 发表于 2008-8-4 08:31 | 显示全部楼层
为什么要校准???
出厂已经做了校准,典型环境下1%还不够吗?
 楼主| dcp 发表于 2008-8-4 12:10 | 显示全部楼层
这个问题你跟HOTPOWER去理论;D
yewuyi 发表于 2008-8-4 13:40 | 显示全部楼层
hotpower难道由搞什么非典?!
yewuyi 发表于 2008-8-4 14:01 | 显示全部楼层
这样不行吗?
const&nbsp;uchar&nbsp;&nbsp;OSCCAL_CHECK&nbsp;&nbsp;@0x3ff;<br /><br /><br />void&nbsp;main(void)<br />{<br />OSCCAL&nbsp;=&nbsp;OSCCAL_CHECK;<br />while(1){}<br />}<br /><br />个人认为不需要把RC校正发到while(1){}循环里面。。。
xieyuanbin 发表于 2008-8-5 10:55 | 显示全部楼层
很关心校准所用基准
yewuyi 发表于 2008-8-5 11:10 | 显示全部楼层
HOTPOWE可能用的是通信时的同步头做的自动校准
哎,真累,搞那么麻烦干什么。。。
xieyuanbin 发表于 2008-8-9 07:57 | 显示全部楼层
自动校准有其必要.
比如交流可控硅调速,必须适应50,60HZ&nbsp;
dcp
71
