IAP错误
1064|1
 楼主| liuzaiy 发表于 2015-1-18 13:56 | 显示全部楼层 |阅读模式
IAP_ADDR=0x3600,IAP读写檫均不行,程序片段如下,错在那呢。。。。。
void IAP_Page_Erase(unsigned int IAP_Addr,unsigned char Trigger_Check2)
#if (Xtal_Freq<=6)
    ISPCR=0x03 ;
#elif (Xtal_Freq<=10)
   ISPCR=0x02 ;
#elif (Xtal_Freq<=20)
    ISPCR=0x01 ;
#elif (Xtal_Freq<=40)
    ISPCR=0x00 ;
#endif
   ISPCR = ISPCR | 0x80 ;
   IFADRH = IAP_Addr >> 8 ;                     //IAP Flash Address High Byte
   IFADRL = IAP_Addr & 0xFF ;                   //IAP Flash Address Low Byte
   IFMT = 0x03 ;                                //IAP Flash Mode Table (Erase Mode)
   if (Trigger_Check1==0x55)
      SCMD = 0x46 ;
   else
      IAP_Fail() ;
   if (Trigger_Check2==0xAA)
   {  SCMD = 0xB9 ;
   else
   {  SCMD = 0x00 ;
      IAP_Fail() ;
   Trigger_Check2=0x00;
   ISPCR = ISPCR & 0x7F ;
Dong~ 发表于 2015-1-19 09:24 | 显示全部楼层
用什么型号的芯片?
操作的地址是否在IAP空间?
Trigger_Check1, Trigger_Check2的值正确吗?
