[STM8] 用STVD定义位域产生问题
1116|0
 楼主| songtao0728 发表于 2015-1-20 14:34 | 显示全部楼层 |阅读模式
代码如下
typedef union{
    unsigned long State;
  struct {
    unsigned long Bit0:1;  //-> Hour high bit
    unsigned long Bit1:1;  //-> Voltage radix point sybmol
    unsigned long Bit2:1;  //-> Battery left 2
    unsigned long Bit3:1;  //-> Battery left 1
    unsigned long Bit4:1;  //-> Second
    unsigned long Bit5:1;  //-> ODO
    unsigned long Bit6:1;  //-> REMN
    unsigned long Bit7:1;  //-> People and Bike **
    unsigned long Bit8:1;  //-> Battery left 3
    unsigned long Bit9:1;  //-> Temperature Symbol
    unsigned long Bit10:1; //-> left
    unsigned long Bit11:1; //-> Battery left 5
    unsigned long Bit12:1; //-> Temperature "A"
    unsigned long Bit13:1; //-> Temperature unit
    unsigned long Bit14:1; //-> M Light
    unsigned long Bit15:1; //-> Battery **
    unsigned long Bit16:1; //-> Mileage radix point
    unsigned long Bit17:1; //-> Voltage Unit
    unsigned long Bit18:1; //-> Speed/Kilometer chinese unit
    unsigned long Bit19:1; //-> Speed/Mileage unit
    unsigned long Bit20:1; //-> Battery left 4
    unsigned long Bit21:1; //-> Door
    unsigned long Bit22:1; //-> Motor
    unsigned long Bit23:1; //-> ECU
    unsigned long Bit24:1; //-> EPS
    unsigned long Bit25:1; //-> Right
    unsigned long Bit26:1; //-> 3
    unsigned long Bit27:1; //-> 2
    unsigned long Bit28:1; //-> 1
    unsigned long Bit29:1; //-> Low Battery **
    unsigned long Bit30:1; //-> Reserved
    unsigned long Bit31:1; //-> Reserved
   }Sub;
} LCD_TypeDef;
我在main.c中定义一个这个类型的变量
volatile LCD_TypeDef Flags;
然后在主程序中对位进行操作,测试发现
Flags.Sub.Bit0 = 1;
Flags.Sub.Bit23 = 0;
0~23赋值都没有问题,24~31就会编译不能通过
Flags.Sub.Bit24 = 0;
Flags.Sub.Bit31 = 1;
提示:#error castm8 C:\DOCUME~1\LUCIEN~1\LOCALS~1\Temp\s798.cx2:2862 value too large,哪位朋友遇到过这样的问题?希望赐教.
