launchpad uart求助
1111|5
 楼主| zhongzhang0116 发表于 2015-1-26 17:56 | 显示全部楼层 |阅读模式
下载了一个uart 9600的 例程。
编译了下
    TimerA_UART_print("READY.\r\n");   可以显示
    但是 TimerA_UART_tx(0x99);  // 显示不了,但是在for里面,TimerA_UART_tx(rxBuffer);
是可以显示的,显示串口输入。
不知道为什么。求高手解答。
//  MSP430G2xx2 Demo - Timer_A, Ultra-Low Pwr UART 9600 Echo, 32kHz ACLK
//  Description: Use Timer_A CCR0 hardware output modes and SCCI data latch
//  to implement UART function @ 9600 baud. Software does not directly read and
//  write to RX and TX pins, instead proper use of output modes and SCCI data
//  latch are demonstrated. Use of these hardware features eliminates ISR
//  latency effects as hardware insures that output and input bit latching and
//  timing are perfectly synchronised with Timer_A regardless of other
//  software activity. In the Mainloop the UART function readies the UART to
//  receive one character and waits in LPM3 with all activity interrupt driven.
//  After a character has been received, the UART receive function forces exit
//  from LPM3 in the Mainloop which configures the port pins (P1 & P2) based
//  on the value of the received byte (i.e., if BIT0 is set, turn on P1.0).
//  ACLK = TACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO
//  //* An external watch crystal is required on XIN XOUT for ACLK *//
//               MSP430G2xx2
//        /|\|              XIN|-
//         | |                 | 32kHz
//         --|RST          XOUT|-
//           |   CCI0B/TXD/P1.1|-------->
//           |                 | 9600 8N1
//           |   CCI0A/RXD/P1.2|<--------
//  D. Dang
//  Texas Instruments Inc.
//  December 2010
//  Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include "msp430g2452.h"
#include "stdio.h"
// Hardware-related definitions
#define UART_TXD   0x02                     // TXD on P1.1 (Timer0_A.OUT0)
#define UART_RXD   0x04                     // RXD on P1.2 (Timer0_A.CCI1A)
// Conditions for 9600 Baud SW UART, SMCLK = 1MHz
#define UART_TBIT_DIV_2     (1000000 / (9600 * 2))
#define UART_TBIT           (1000000 / 9600)
// Global variables used for full-duplex UART communication
unsigned int txData;                        // UART internal variable for TX
unsigned char rxBuffer;                     // Received UART character
unsigned char test1=0x66;
unsigned char test2=0x88;
// Function prototypes
void TimerA_UART_init(void);
void TimerA_UART_tx(unsigned char byte);
void TimerA_UART_print(char *string);
// main()
void main(void)
    WDTCTL = WDTPW + WDTHOLD;               // Stop watchdog timer
    DCOCTL = 0x00;                          // Set DCOCLK to 1MHz
    BCSCTL1 = CALBC1_1MHZ;
    DCOCTL = CALDCO_1MHZ;
    P1OUT = 0x00;                           // Initialize all GPIO
    P1SEL = UART_TXD + UART_RXD;            // Timer function for TXD/RXD pins
    P1DIR = 0xFF & ~UART_RXD;               // Set all pins but RXD to output
    P2OUT = 0x00;
    P2SEL = 0x00;
    P2DIR = 0xFF;
    _EINT();// __enable_interrupt() = _EINT();
    TimerA_UART_init();                     // Start Timer_A UART
    TimerA_UART_print("G2xx2 TimerA UART\r\n");
    for (;;)
        // Wait for incoming character
        __bis_SR_register(LPM0_bits);
        // Update board outputs according to received byte
        //if (rxBuffer & 0x01) P1OUT |= 0x01; else P1OUT &= ~0x01;    // P1.0
        //if (rxBuffer & 0x02) P1OUT |= 0x08; else P1OUT &= ~0x08;    // P1.3
       // if (rxBuffer & 0x04) P1OUT |= 0x10; else P1OUT &= ~0x10;    // P1.4
        //if (rxBuffer & 0x08) P1OUT |= 0x20; else P1OUT &= ~0x20;    // P1.5
        //if (rxBuffer & 0x10) P1OUT |= 0x40; else P1OUT &= ~0x40;    // P1.6
       // if (rxBuffer & 0x20) P1OUT |= 0x80; else P1OUT &= ~0x80;    // P1.7
       // if (rxBuffer & 0x40) P2OUT |= 0x40; else P2OUT &= ~0x40;    // P2.6
       // if (rxBuffer & 0x80) P2OUT |= 0x80; else P2OUT &= ~0x80;    // P2.7
        // Echo received character
// Function configures Timer_A for full-duplex UART operation
    TACCTL0 = OUT;                          // Set TXD Idle as Mark = '1'
    TACCTL1 = SCS + CM1 + CAP + CCIE;       // Sync, Neg Edge, Capture, Int
    TACTL = TASSEL_2 + MC_2;                // SMCLK, start in continuous mode
// Outputs one byte using the Timer_A UART
    while (TACCTL0 & CCIE);                 // Ensure last char got TX'd
    TACCR0 = TAR;                           // Current state of TA counter
    TACCR0 += UART_TBIT;                    // One bit time till first bit
    TACCTL0 = OUTMOD0 + CCIE;               // Set TXD on EQU0, Int
    txData = byte;                          // Load global variable
    txData |= 0x100;                        // Add mark stop bit to TXData
    txData <<= 1;                           // Add space start bit
    BitCnt = 0xA;                             //??????,8data+ ST/??
     while (CCR0 != TAR)                       //??????
       CCR0 = TAR;                             // TA?????????
     CCR0 += Bitime;                     //????,??????
     TXByte |= 0x100;                        //??????TXByte
     TXByte = TXByte << 1;                 //????????
     CCTL0 =  CCIS0 + OUTMOD0 + CCIE;          // TXD = mark = idle
     while ( CCTL0 & CCIE );                   //??????
// Prints a string over using the Timer_A UART
    while (*string) {
        TimerA_UART_tx(*string++);
// Timer_A UART - Transmit Interrupt Handler
#pragma vector = TIMER0_A0_VECTOR
__interrupt void Timer_A0_ISR(void)
    static unsigned char txBitCnt = 10;
    TACCR0 += UART_TBIT;                    // Add Offset to CCRx
    if (txBitCnt == 0) {                    // All bits TXed?
        TACCTL0 &= ~CCIE;                   // All bits TXed, disable interrupt
        txBitCnt = 10;                      // Re-load bit counter
    else {
        if (txData & 0x01) {
          TACCTL0 &= ~OUTMOD2;              // TX Mark '1'
        else {
          TACCTL0 |= OUTMOD2;               // TX Space '0'
        txData >>= 1;
        txBitCnt--;
// Timer_A UART - Receive Interrupt Handler
#pragma vector = TIMER0_A1_VECTOR
__interrupt void Timer_A1_ISR(void)
    static unsigned char rxBitCnt = 8;
    static unsigned char rxData = 0;
    switch (__even_in_range(TA0IV, TA0IV_TAIFG)) { // Use calculated branching
        case TA0IV_TACCR1:                        // TACCR1 CCIFG - UART RX
            TACCR1 += UART_TBIT;                 // Add Offset to CCRx
            if (TACCTL1 & CAP) {                 // Capture mode = start bit edge
                TACCTL1 &= ~CAP;                 // Switch capture to compare mode
                TACCR1 += UART_TBIT_DIV_2;       // Point CCRx to middle of D0
            else {
                rxData >>= 1;
                if (TACCTL1 & SCCI) {            // Get bit waiting in receive latch
                    rxData |= 0x80;
                rxBitCnt--;
                if (rxBitCnt == 0) {             // All bits RXed?
                    rxBuffer = rxData;           // Store in global variable
                    rxBitCnt = 8;                // Re-load bit counter
                    TACCTL1 |= CAP;              // Switch compare to capture mode
                    __bic_SR_register_on_exit(LPM0_bits);  // Clear LPM0 bits from 0(SR)
            break;
dirtwillfly 发表于 2015-1-26 21:24 | 显示全部楼层
void TimerA_UART_tx(unsigned char byte);这个函数的变量是无符号字符类型,TimerA_UART_tx(0x99)中的0x99会被认为是ASCII码丽的字符,但因为0x99等于10进制的153,超过了127,在扩展ASCII码的范围,可能你的软件不支持所以显示不了
 楼主| zhongzhang0116 发表于 2015-1-27 10:32 | 显示全部楼层
谢谢您的回复。
我用0x09也不行的。
void TimerA_UART_tx(unsigned char byte);这个函数的变量是无符号字符类型,TimerA_UART_tx(0x99)中的0x99 ...
谢谢您的回复。
我用0x09也不行的。
 楼主| zhongzhang0116 发表于 2015-1-27 14:44 | 显示全部楼层
1. 找到原因了。我串口助手,用的是ASCII格式,显示不出来,假设是HEX格式,就可以了。
2. 但是用TimerA_UART_tx(rxBuffer); 这个函数,输入0x02,用ASCII可以显示出来0x02,切换成Hex的话,就是一堆数字了,这个后面要继续研究。
高手可以指点下。
dirtwillfly 发表于 2015-1-27 19:53 | 显示全部楼层
谢谢您的回复。
我用0x09也不行的。
建议:调试的时候,尽量选择ASCII码里的可显示字符
