[i.MX] 求助i.MX6 Ubuntu12.04上编译LTIB出问题
1281|1
 楼主| hmsfeng 发表于 2015-1-26 20:36 | 显示全部楼层 |阅读模式
我按照之前的一个帖子https://bbs.21ic.com/icview-680340-1-1.html,编译了L3.0.35,目前发现一个问题,无法编译成功,请楼主帮忙看看。
在编译的时候./ltib出现下面的信息:
vmuser@vmuser:~/ltib$ ./ltib
Processing platform: Freescale iMX6x Based Boards
using config/platform/imx/.config
Processing: fake-provides
Processing: u-boot-v2009.08
Processing: kernel-3.0.35
Processing: skell
Processing: base_libs
Build path taken because: no prebuilt rpm,
rpmbuild --dbpath /home/vmuser/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/vmuser/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/vmuser/ltib/tmp' --define '_rpmdir /home/vmuser/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/vmuser/ltib/dist/lfs-5.1/base_libs/base_libs.spec
Building target platforms: arm
Building for target arm
error: line 1: Unknown tag: define __os_install_post
Build time for base_libs: 0 seconds
Failed building base_libs
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Mon Jan 26 20:29:13 2015
Ended:   Mon Jan 26 20:29:14 2015
Elapsed: 1 seconds
These packages failed to build:
base_libs
Build Failed
Exiting on error or interrupt
不知道怎么解决?求助
 楼主| hmsfeng 发表于 2015-1-27 11:19 | 显示全部楼层
问题已解决,主要原因是修改/ltib/dist/lfs-5.1/base_libs/base_libs.spec的时候,把第一行的define __os_install_post,误删除了%,应该是%define __os_install_post
个人签名:相信自己!
