[Atmel] 用ASF跑SAMD21程序(24)重跑EEPROM
2283|0
 楼主| ddllxxrr 发表于 2015-1-27 21:17 | 显示全部楼层 |阅读模式
上次跑EEPROM,提示没有定义EEPROM,并提示通过熔丝位写,
由于本人,就这么一个D21开发板,所以采取,无过便是功的方法,就是先搞清楚究竟是怎么回事,再采取行动,
现在条件成熟了。
https://bbs.21ic.com/forum.php?mod=viewthread&tid=874803&extra=page%3D1%26filter%3Dtypeid%26typeid%3D380%26typeid%3D380
那就再跑一下EEPROM
首先新建ASF工程,然后加入EEPROM模块,再后打开ASF EXPLOERE,点开快速指导,按提示形成文件。
然后把熔丝位改为0x04
然后重新编译工程
下载运行
则灯亮,若下电再上电灯又亮,再重复又灭。
程序清单:
  1. /**
  2. * \file
  3. *
  4. * \brief Empty user application template
  5. *
  6. */
  7. /**
  8. * \mainpage User Application template doxygen documentation
  9. *
  10. * \par Empty user application template
  11. *
  12. * This is a bare minimum user application template.
  13. *
  14. * For documentation of the board, go \ref group_common_boards "here" for a link
  15. * to the board-specific documentation.
  16. *
  17. * \par Content
  18. *
  19. * -# Include the ASF header files (through asf.h)
  20. * -# Minimal main function that starts with a call to system_init()
  21. * -# Basic usage of on-board LED and button
  22. * -# "Insert application code here" comment
  23. *
  24. */
  25. /*
  26. * Include header files for all drivers that have been imported from
  27. * Atmel Software Framework (ASF).
  28. */
  29. /**
  30. * Support and FAQ: visit <a href="http://www.atmel.com/design-support/">Atmel Support</a>
  31. */
  32. void configure_eeprom(void);
  33. #include <asf.h>
  34. void configure_eeprom(void)
  35. {    /* Setup EEPROM emulator service */
  36.             enum status_code error_code = eeprom_emulator_init();
  37.                 if (error_code == STATUS_ERR_NO_MEMORY)
  38.                 {
  39.                         while (true) {            /* No EEPROM section has been set in the device's fuses */        }    }
  40.             else if (error_code != STATUS_OK) {        /* Erase the emulated EEPROM memory (assume it is unformatted or         * irrecoverably corrupt) */
  41.                 eeprom_emulator_erase_memory();
  42.                 eeprom_emulator_init();    }}
  43. int main (void)
  44. {
  45.         system_init();
  46.         configure_eeprom();
  47.
  48.
  49.          uint8_t page_data[EEPROM_PAGE_SIZE];
  50.          eeprom_emulator_read_page(0, page_data);
  51.          page_data[0] = !page_data[0];
  52.          port_pin_set_output_level(LED_0_PIN, page_data[0]);
  53.          eeprom_emulator_write_page(0, page_data);
  54.          eeprom_emulator_commit_page_buffer();
  55.          while (true) {    }
  56. }
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
