[i.MX]
[i.MX] android4.3 编译报 No rule
1804|2
djy0511|  楼主 | 2015-1-29 09:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=4.3
TARGET_PRODUCT=sabresd_6dq
TARGET_BUILD_VARIANT=eng
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a-neon
TARGET_CPU_VARIANT=cortex-a9
HOST_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-3.11.0-26-generic-x86_64-with-Ubuntu-12.04-precise
HOST_BUILD_TYPE=release
BUILD_ID=1.1.0-rc4
OUT_DIR=out
执行make ,出现下面问题。
第二次重新全编译(make clean后,再执行一次开始编译的几个命令),出现问题相同。
谢谢!
target Strip: libion (out/target/product/sabresd_6dq/obj/lib/libion.so)
target SharedLib: camera.imx6 (out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/camera.imx6_intermediates/LINKED/camera.imx6.so)
target Symbolic: camera.imx6 (out/target/product/sabresd_6dq/symbols/system/lib/hw/camera.imx6.so)
Export includes file: hardware/imx/mx6/libcamera2/Android.mk -- out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/camera.imx6_intermediates/export_includes
target Strip: camera.imx6 (out/target/product/sabresd_6dq/obj/lib/camera.imx6.so)
Notice file: external/jhead/NOTICE -- out/target/product/sabresd_6dq/obj/NOTICE_FILES/src//system/lib/libexif.so.txt
Install: out/target/product/sabresd_6dq/system/lib/libexif.so
target Prebuilt: libg2d (out/target/product/sabresd_6dq/obj/lib/libg2d)
Install: out/target/product/sabresd_6dq/system/lib//libg2d
Install: out/target/product/sabresd_6dq/system/lib/libion.so
Install: out/target/product/sabresd_6dq/system/lib/hw/camera.imx6.so
make: *** No rule to make target `out/target/product/sabresd_6dq/obj/STATIC_LIBRARIES/libSupl_intermediates/export_includes',
needed by `out/target/product/sabresd_6dq/obj/SHARED_LIBRARIES/gps.default_intermediates/import_includes'.  Stop.
djy0511|  楼主 | 2015-1-29 11:02 | 只看该作者
请求大侠们帮忙!
FSL_TICS_ZJJ| | 2015-2-6 12:53 | 只看该作者
楼主你好
通过和我们I.MX工程师的沟通:
建议你将此问题按照帖子   飞思卡尔申请样片与购买的论坛VIP通道开通了,小伙伴速来!   提交一个服务请求:
如果你尚未注册飞思卡尔官网账号,请先点击注册按钮:右侧图标完成注册。
如果你已有飞思卡尔官网账号,可以点击申请SR按钮:右侧图标提交一个服务请求。
最好使用英文详细描述一下遇到的问题,以便国内外工程师都能够帮助到你
