[资料分享]
【TI技术资料分享】+ 面向电池充电120VAC输入200W交错反激设计
1300|3
描述The TI Design TIDA-00200 proposes an interleaved flybacktopology for battery charger applications that require an output power level of~200W with a minimized bill of material. Besides the actual electronic componentsthe efforts for cooling are a major contributor to the overal design cost. Bytaking advantage of the LM5032 High Voltage Dual Interleaved Current ModeController the design accomplishes great efficiency of 90% at full load and atthe same time spreads out the heat for greatly reduced cooling efforts. A fanis typically not needed; the need for smaller form factor heat sinks providesadditional design flexibility.
特性• Input: 100V-120V +/- 10%  AC 50/60Hz
• Output Voltage 21V (5 Li-Ion battery cells), up-to 9.5 A charge current
• 90% Efficiency
• Interleaved Flyback Topology based on LM5032 High Voltage Dual InterleavedCurrent Mode Controller
• Programmable Line Under-Voltage Lockout & Cycle-by-cycle Current Limit
• Feedback based on TLC272 Dual Single Supply Operational Amplifier
参考原理图:
tidra05.pdf (233.16 KB)
xyz549040622| | 2015-1-29 22:03 | 只看该作者
这是官网的资料,还是自己的资料?
yyl830113|  楼主 | 2015-1-31 09:11 | 只看该作者
xyz549040622 发表于 2015-1-29 22:03
这是官网的资料,还是自己的资料?
官网的资料。
Thefantasy| | 2015-1-31 14:16 | 只看该作者
个人签名:==================================================== 店铺:http://shop114807637.taobao.com/ QQ:2050567376
87
