[STM32F2] PWM出不来,求助
1089|2
 楼主| wanshon 发表于 2015-1-29 21:31 | 显示全部楼层 |阅读模式
PWM, TI, pi, ST, IO
void TIM4_Configuration(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
        TIM_DeInit(TIM4);
  TIM_TimeBaseStructure.TIM_Period = (250-1); //96K
  TIM_TimeBaseStructure.TIM_Prescaler = (3-1);
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV2;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseStructure.TIM_RepetitionCounter=0;//?????,??????pwm???
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
        /* Output Compare Active Mode configuration: Channel1 */
                                TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;                    //???pwm1????
        TIM_OCInitStructure.TIM_Pulse=125;                                            //???????
                                TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;        //?????????
        TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;        //?????????
                                TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;//???????
        TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;//???????
        TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Set;        //???????
        TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;//??????????
       TIM_OC3Init(TIM4, &TIM_OCInitStructure); //??TIM_OCInitStruct???????????TIMx
                TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable); //??TIMx?CCR3????????
TIM_ARRPreloadConfig(TIM4, ENABLE); //??TIMx?ARR????????
/* TIM4 enable counter */
TIM_Cmd(TIM4, ENABLE); //??TIMx??
        TIM_CtrlPWMOutputs(TIM4, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_8|GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//GPIO_Mode_Out_PP;//;
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL;
        GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource8,GPIO_AF_TIM4);
 楼主| wanshon 发表于 2015-1-29 21:44 | 显示全部楼层
出来了
HAORANAN123 发表于 2015-1-30 11:46 | 显示全部楼层
没看出来有什么啊
