[Atmel] Atmel ATmega256RFR2 Xplained Pro Starter Kit
1597|0
 楼主| ddllxxrr 发表于 2015-1-30 20:21 | 显示全部楼层 |阅读模式
The ATmega256RFR2 Xplained Pro starter kit is ideal for evaluation and prototyping with the ATmega256RFR2 microcontroller. The ATmega256RFR2 Xplained Pro board is available as an evaluation kit or starter kit. You can also purchase extension boards individually.
Key Features
  • ATmega256RFR2 microcontroller
  • One mechanical reset button
  • One mechanical user pushbutton (wake-up, bootloader entry or general purpose)
  • One user yellow LED
  • 32.768kHz crystal
  • 16MHz crystal
  • 5 Xplained Pro extension headers (2 headers are duplicates)
  • Antenna diversity: Ceramic RF antenna and SMA connector for external antenna
  • Temperature sensor
  • Embedded debugger
    • Auto-ID for board identification in Atmel Studio 6.1
    • One yellow status LED
    • One green board power LED
    • Symbolic debug of complex data types including scope information
    • Programming
    • Data Gateway Interface: SPI, TWI, 4 GPIOs
    • Virtual COM port (CDC)
  • USB powered
  • Supported with application examples in Atmel Software Framework
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
