MSP430F449 LCD COMx口用示波器测不到波形,怎么办?
983|1
 楼主| wangjinlili 发表于 2015-1-31 21:15 | 显示全部楼层 |阅读模式
跑的是官方的例程
  • /* --COPYRIGHT--,BSD_EX
  • * Copyright (c) 2012, Texas Instruments Incorporated
  • * All rights reserved.
  • * Redistribution and use in source and binary forms, with or without
  • * modification, are permitted provided that the following conditions
  • * are met:
  • * *  Redistributions of source code must retain the above copyright
  • *    notice, this list of conditions and the following disclaimer.
  • * *  Redistributions in binary form must reproduce the above copyright
  • *    notice, this list of conditions and the following disclaimer in the
  • *    documentation and/or other materials provided with the distribution.
  • * *  Neither the name of Texas Instruments Incorporated nor the names of
  • *    its contributors may be used to endorse or promote products derived
  • *    from this software without specific prior written permission.
  • * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  • * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
  • * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
  • * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
  • * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
  • * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
  • * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
  • * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
  • * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
  • * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
  • * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  • *                       MSP430 CODE EXAMPLE DISCLAIMER
  • * MSP430 code examples are self-contained low-level programs that typically
  • * demonstrate a single peripheral function or device feature in a highly
  • * concise manner. For this the code may rely on the device's power-on default
  • * register values and settings such as the clock configuration and care must
  • * be taken when combining code from several examples to avoid potential side
  • * effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
  • * for an API functional library-approach to peripheral configuration.
  • * --/COPYRIGHT--*/
  • //  MSP-FET430P440 Demo - LCD, Display "6543210" on STK/EVK LCD
  • //  Description: Displays "6543210" on MSP-EVK430S320 LCD.
  • //  ACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO = 32 x ACLK = 1048576Hz
  • //  //* An external watch crystal between XIN & XOUT is required for ACLK *//
  • //                                Connections MSP430 -> LCD
  • //                                             T.I. MSP-EVK430S320
  • //                            MSP430F449       6.5 digit 4 mux LCD
  • //                                                   #T218010
  • //                       | |          COM3 |-----|2    COM4     |
  • //                       --|RST       COM2 |-----|1    COM3     |
  • //                         |          COM1 |-----|3    COM2     |
  • //                         |          COM0 |-----|4,20 COM1     |
  • //                        -|XIN       SEG0 |-----|19            |
  • //                    32kHz|          SEG1 |-----|18            |
  • //                        -|XOUT      SEG2 |-----|17            |
  • //                         |          SEG3 |-----|16            |
  • //                         |          SEG4 |-----|15            |
  • //                         |          SEG5 |-----|14            |
  • //                         |          SEG6 |-----|13            |
  • //                         |          SEG7 |-----|12            |
  • //                       +-|R33       SEG8 |-----|11            |
  • //                      1M |          SEG9 |-----|10            |
  • //                       +-|R23       SEG10|-----|9             |
  • //                      1M |          SEG11|-----|8             |
  • //                       +-|R13       SEG12|-----|7             |
  • //                      1M |          SEG13|-----|6             |
  • //                       +-|R03       SEG14|-----|5 (bits C,E,H |
  • //                       | |               |     |   of digit 7)|
  • //                      Vss ---------------       --------------
  • //  M. Buccini / H. Grewal
  • //  Texas Instruments Inc.
  • //  Feb 2005
  • //  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.21A
  • #include <msp430.h>
  • const char digit[10] =
  •   0xB7,  /* "0" LCD segments a+b+c+d+e+f */
  •   0x12,  /* "1" */
  •   0x8F,  /* "2" */
  •   0x1F,  /* "3" */
  •   0x3A,  /* "4" */
  •   0x3D,  /* "5" */
  •   0xBD,  /* "6" */
  •   0x13,  /* "7" */
  •   0xBF,  /* "8" */
  •   0x3F   /* "9" */
  • int main(void)
  •   volatile unsigned int i;                  // Use volatile to prevent removal
  •                                             // by compiler optimization
  •   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  •   FLL_CTL0 |= XCAP14PF;                     // Configure load caps
  •   for (i = 0; i < 10000; i++);              // Delay for 32 kHz crystal to
  •                                             // stabilize
  •   LCDCTL = LCDON + LCD4MUX + LCDSG0_4;      // LCD on, 4-Mux, segments S0-S27
  •   BTCTL = BT_fLCD_DIV128;                   // LCD clock freq is ACLK/128
  •   P5SEL = 0xFC;                             // Select P5.2-7 as Com and Rxx
  •   for (;;)
  •     unsigned char x;
  •     for (x=0; x<7; x++)
  •       LCDMEM[x] = digit[x];                 // Display "6543210"
[color=rgb(51, 102, 153) !important]复制代码
有没有人知道
