[i.MX] iMX6 SabreSD开发板突然无法NFS启动了
2297|4
 楼主| leifenger 发表于 2015-2-2 16:34 | 显示全部楼层 |阅读模式
我在iMX6 SabreSD开发板上,无法NFS启动了,之前一直是可以启动的,测试了网线是ok的,莫非是网卡芯片故障了?
打印提示信息如下:
U-Boot 2009.08 (Nov 21 2014 - 09:54:19)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 191
Temperature:   38 C, calibration data 0x5b65157d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [WDOG ]
Boot Device: MMC
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
Net:   got MAC address from IIM: 00:04:9f:02:e2:10
FEC0 [PRIME]
Hit any key to stop autoboot:  0
PHY indentify @ 0x3 = 0x004dd075
FEC: Link is down 6149
Using FEC0 device
TFTP from server 192.168.6.109; our IP address is 192.168.6.110
Filename 'uImage'.
Load address: 0x10800000
Loading: FEC: Link is down 6149
NFS启动配置如下:
setenv ipaddr 192.168.6.110
setenv serverip 192.168.6.109
setenv bootfile uImage
setenv nfsroot /tftpboot/rootfs
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200'
setenv bootargs_nfs 'setenv bootargs ${bootargs} root=/dev/nfs rw ip=${ipaddr}:${serverip}:192.168.6.1:255.255.255.0::eth0:off nfsroot=${serverip}:${nfsroot},v3,tcp
setenv bootcmd_net 'run bootargs_base bootargs_nfs;bootm'
setenv bootcmd 'tftpboot uImage; run bootcmd_net'
saveenv
run bootcmd
FSL_TICS_Rita 发表于 2015-2-3 16:46 | 显示全部楼层
楼主你好,你这里应该是u-boot中ip设置的有问题,建议你参考一下论坛中帖子:
https://bbs.21ic.com/icview-808990-1-1.html
FSL_TICS_Rita 发表于 2015-2-3 16:47 | 显示全部楼层
有问题我们再沟通~~
FSL_TICS_Rita 发表于 2015-2-4 17:19 | 显示全部楼层
楼主你好,请问现在NFS可以起来了吗?
FSL_TICS_Rita 发表于 2015-3-5 17:31 | 显示全部楼层
楼主你好,请问NFS 可以起来了吗?
