[STM32F1] SDIO-FIFO发数据出错
1139|0
 楼主| eternalsunshine 发表于 2015-2-6 21:16 | 显示全部楼层 |阅读模式
sd, FIFO, IO, ni, pi
我向操作单元为“字”的FIFO中写入一个“字”;查询时,发现FIFO中被写了32个“字”。(FIFO一共有32个字的存储空间)
以下是我针对此问题写的一段代码:
#include "stm32f10x.h"
#include "stm32f10x_conf.h"
SDIO_DataInitTypeDef SDIO_DataInitStructure;
SDIO_InitTypeDef SDIO_InitStructure;
void SD_LowLevel_Init(void)        ;
void SDIO_DataInit(void);
int main(void)
    char *character= "abcdefghijklmnop" ;
        uint32_t  *data= (uint32_t *)character ;
    SD_LowLevel_Init();
    SDIO_DataInit();
    SDIO->DCTRL = 0;
        SDIO_DataInitStructure.SDIO_DataLength = 16;
    SDIO_SetSDIOOperation(ENABLE);
        SDIO_DataInitStructure.SDIO_DataTimeOut = 0xffffffff;
    SDIO_DataInitStructure.SDIO_TransferDir = SDIO_TransferDir_ToCard;    //SDIO_TransferDir_ToCard=0 SDIO_TransferDir_ToSDIO=2
    SDIO_DataInitStructure.SDIO_TransferMode = SDIO_TransferMode_Stream;   // SDIO_TransferMode_Stream SDIO_TransferMode_Block
    SDIO_DataInitStructure.SDIO_DPSM = SDIO_DPSM_Enable;
    SDIO_DataConfig(&SDIO_DataInitStructure);
         SDIO->FIFOCNT;
         SDIO->DCOUNT;
         SDIO_WriteData(0X12345678);
         SDIO->FIFOCNT;
         SDIO->DCOUNT;
         SDIO_WriteData(*data++);
         SDIO->FIFOCNT;
         SDIO->DCOUNT;
         SDIO->FIFOCNT;
         SDIO->DCOUNT;
         SDIO_WriteData(*data);
         SDIO->FIFOCNT;
         SDIO->DCOUNT;
  GPIO_InitTypeDef  GPIO_InitStructure;
  /*!< GPIOC and GPIOD Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD , ENABLE);
  /*!< Configure PC.08, PC.09, PC.10, PC.11, PC.12 pin: D0, D1, D2, D3, CLK pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /*!< Configure PD.02 CMD line */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
      /*!< Enable the SDIO AHB Clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_SDIO, ENABLE);
  /*!< Enable the DMA2 Clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
  SDIO_DeInit();
  /*!< Power ON Sequence -----------------------------------------------------*/
  /*!< Configure the SDIO peripheral */
  /*!< SDIO_CK = SDIOCLK / (SDIO_INIT_CLK_DIV + 2) */
  /*!< on STM32F4xx devices, SDIOCLK is fixed to 48MHz */
  /*!< SDIO_CK for initialization should not exceed 12 MHz */
  SDIO_InitStructure.SDIO_ClockDiv = 0x04;
  SDIO_InitStructure.SDIO_ClockEdge = SDIO_ClockEdge_Rising;
  SDIO_InitStructure.SDIO_ClockBypass = SDIO_ClockBypass_Disable;
  SDIO_InitStructure.SDIO_ClockPowerSave = SDIO_ClockPowerSave_Disable;
  SDIO_InitStructure.SDIO_BusWide = SDIO_BusWide_4b;
  SDIO_InitStructure.SDIO_HardwareFlowControl = SDIO_HardwareFlowControl_Disable;
  SDIO_Init(&SDIO_InitStructure);
  /*!< Set Power State to ON */
  SDIO_SetPowerState(SDIO_PowerState_ON);
  /*!< Enable SDIO Clock */
  SDIO_ClockCmd(ENABLE);
/*******************************************Gainspan Testing******************************/
    SDIO_DataStructInit(&SDIO_DataInitStructure);
