[i.MX]
IMX6 LTIB
928|2
xz85987271|  楼主 | 2015-2-9 16:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, mx, ST, vi, os
Please see >> /home/vikki/imx6-dev/ltib/ltib/host_config.log for details
vikki@vikki:~/imx6-dev/ltib/ltib$ ./ltib
Installing host support packages.
This only needs to be done once per host, but may take up to
an hour to complete ...
If an error occurs, a log file with the full output may be found in:
Exiting on error or interrupt
vikki@vikki:~/imx6-dev/ltib/ltib$ sudo visudo
FSL_TICS_Rita| | 2015-2-12 15:43 | 只看该作者
楼主你好,请问你这里使用的是哪个版本的BSP呢?
FSL_TICS_Rita| | 2015-2-12 15:44 | 只看该作者
建议你参考本论坛中的帖子:
https://bbs.21ic.com/icview-680340-1-1.html
