[资料分享与下载] 飞思卡尔单片机DZ60---EEPROM读写
1349|0
niuyaliang 发表于 2015-2-27 19:53 | 显示全部楼层 |阅读模式
  1. [cpp] view plaincopy
  2. //向EEPROM中写入数据,然后读出数据,赋值给PORTD,点亮相应的LED灯
  3.
  4. #include <hidef.h> /* for EnableInterrupts macro */
  5. #include "derivative.h" /* include peripheral declarations */
  6.
  7.
  8. #define uint unsigned int
  9. #define uchar unsigned char
  10.
  11.
  12. #define LED     PTDD
  13. #define LED_DIR PTDDD
  14.
  15. #define LED_OFF 0XFF
  16.
  17.
  18. void Read_EEPROM(uint start_addr, uchar *pReadbuf, uchar length);
  19. void Write_EEPROM(uint start_addr, uchar *pData, uchar length);
  20.
  21. //uchar Data[6] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06};
  22. //uchar Readbuf[6] = {0};
  23.
  24. uchar Data[6] = {0xFE, 0xFD, 0xFB, 0xF7, 0xEF, 0xDF};
  25. uchar Readbuf[6] = {0XFF};
  26.
  27. uchar i = 0;
  28. uint j = 60000;
  29.
  30.
  31. /*************************************************************/
  32. /*                  初始化总线时钟PEE模式                    */
  33. /*              外部晶振频率为4MHz,总线频率16MHz            */
  34. /*************************************************************/
  35. void INIT_MCG(void)
  36. {
  37.   MCGC2=0x36;
  38.   while(!MCGSC_OSCINIT);
  39.   MCGC1=0xb8;
  40.   while(MCGSC_IREFST);
  41.   while(MCGSC_CLKST!=0b10);
  42.   MCGC2_LP = 1;
  43.   MCGC1 = 0x90;
  44.   MCGC3 = 0x48;
  45.   MCGC2_LP = 0;
  46.   while(!MCGSC_PLLST);
  47.   while(!MCGSC_LOCK);
  48.   MCGC1 = 0x10;
  49.   while(MCGSC_CLKST!=0b11);
  50. }
  51.
  52.
  53. void main(void) {
  54.
  55.   DisableInterrupts;
  56.   SOPT1 = 0;
  57.   INIT_MCG();
  58.
  59.   LED_DIR = 0XFF;
  60.   LED = LED_OFF;
  61.
  62.
  63.   EnableInterrupts; /* enable interrupts */
  64.   /* include your code here */
  65.
  66.
  67.
  68.   FCDIV = 73;//设置分频,16MHZ/8/(9+!)在150k到200khz之间
  69.
  70.   //EEPROM整个空间为2*1024BYTES,地址为0x1400到0x17FF
  71.
  72.   //写入数据部分
  73.   Write_EEPROM(0X1400, Data, 6);
  74.
  75.   //读出数据部分
  76.   Read_EEPROM(0X1400, Readbuf, 6);
  77.
  78.   while(1)
  79.   {
  80.       for(i = 0; i < 6; i++)
  81.       {
  82.         LED = Readbuf[i];
  83.         while(j--);
  84.
  85.       }
  86.   }
  87.
  88.
  89.
  90.
  91.
  92.
  93.   for(;;) {
  94.     __RESET_WATCHDOG(); /* feeds the dog */
  95.   } /* loop forever */
  96.   /* please make sure that you never leave main */
  97. }
  98.
  99.
  100. void Write_EEPROM(uint start_addr, uchar *pData, uchar length)
  101. {
  102.   uchar i;
  103.   uchar *pAddr;
  104.
  105.   if(FSTAT_FACCERR == 1)
  106.     FSTAT_FACCERR = 1;//通过写入1来清除错误标记
  107.
  108.    pAddr = (uchar *)(start_addr);//指定地址
  109.    *pAddr = 0x01;
  110.
  111.
  112.    FCMD = 0X40;//擦除命令
  113.    FSTAT_FCBEF = 1;//启动命令
  114.
  115.    asm{         //等待4个bus cycle
  116.    NOP
  117.    NOP
  118.    NOP
  119.    NOP
  120.    }
  121.
  122.    while(FSTAT_FCCF == 0);//等待完成
  123.
  124.
  125.    for(i = 0; i < length; i++)
  126.    {
  127.
  128.       if(FSTAT_FACCERR == 1)
  129.         FSTAT_FACCERR = 1;
  130.
  131.       pAddr = (uchar *)(start_addr + i);
  132.       *pAddr = pData[i];
  133.
  134.       FCMD = 0X20;//写入命令
  135.       FSTAT_FCBEF = 1;// 启动命令
  136.       asm
  137.       {
  138.         NOP
  139.         NOP
  140.         NOP
  141.         NOP
  142.       }
  143.
  144.       while(FSTAT_FCCF == 0);//等待完成
  145.
  146.    }
  147.
  148. }
  149.
  150.
  151. void Read_EEPROM(uint start_addr, uchar *pReadbuf, uchar length)
  152. {
  153.     uchar i;
  154.     uchar *pAddr;
  155.
  156.     for(i = 0; i < length; i++)
  157.     {
  158.       pAddr = (uchar *)(start_addr);
  159.       pReadbuf[i] = *pAddr;
  160.       start_addr++;
  161.     }
  162.
  163. }
