[资料分享与下载] 飞思卡尔单片机DZ60---SCI(查询发送)
776|0
niuyaliang 发表于 2015-2-27 20:06 | 显示全部楼层 |阅读模式
  1. [cpp] view plaincopy
  2. #include <hidef.h> /* for EnableInterrupts macro */
  3. #include "derivative.h" /* include peripheral declarations */
  4.
  5.
  6. #define LED_D1      PTDD_PTDD0
  7. #define LED_D1_DIR  PTDDD_PTDDD0
  8.
  9. #define LED_ON      0
  10. #define LED_OFF     1
  11.
  12. unsigned char SCANF_SEND_STRINGS[] = "HELLO MCU WORLD";
  13. unsigned char *pSendString = SCANF_SEND_STRINGS;
  14.
  15. /*************************************************************/
  16. /*                  初始化总线时钟PEE模式                    */
  17. /*              外部晶振频率为4MHz,总线频率16MHz            */
  18. /*************************************************************/
  19. void INIT_MCG(void)
  20. {
  21.   MCGC2=0x36;
  22.   while(!MCGSC_OSCINIT);
  23.   MCGC1=0xb8;
  24.   while(MCGSC_IREFST);
  25.   while(MCGSC_CLKST!=0b10);
  26.   MCGC2_LP = 1;
  27.   MCGC1 = 0x90;
  28.   MCGC3 = 0x48;
  29.   MCGC2_LP = 0;
  30.   while(!MCGSC_PLLST);
  31.   while(!MCGSC_LOCK);
  32.   MCGC1 = 0x10;
  33.   while(MCGSC_CLKST!=0b11);
  34. }
  35.
  36.
  37.
  38.
  39.
  40. void delay(void)
  41. {
  42.   unsigned int i;
  43.   unsigned int j;
  44.
  45.
  46.   for(i = 0; i < 100; i++)
  47.      for(j = 0; j < 4000; j++);
  48.
  49. }
  50.
  51.
  52.
  53.
  54.
  55.
  56. void main(void) {
  57.
  58.   DisableInterrupts;
  59.   SOPT1 = 0;
  60.   INIT_MCG();
  61.   EnableInterrupts; /* enable interrupts */
  62.   /* include your code here */
  63.
  64.   LED_D1_DIR = 1;
  65.   LED_D1     = LED_OFF;
  66.
  67.
  68.
  69.
  70. //以下为设置波特率,以及初始化SCI1控制寄存器
  71.   SCI1BDH = 0X00;
  72.   SCI1BDL = 0X68;//波特率设置为9600
  73.   SCI1C1 = 0x00; //设置SCI1为正常模式,八位数据位,无奇偶校验
  74.   SCI1C2 = 0x08; //允许发送数据,禁止中断功能
  75.
  76.
  77.
  78.
  79.   while(1)
  80.   {
  81.
  82.
  83.       while((*pSendString) != '\0')
  84.       {
  85.         while(!SCI1S1_TDRE);//SCI1S1_TDRE 为1表示发送数据缓冲器为空
  86.         SCI1D = *pSendString;
  87.         pSendString++;
  88.         LED_D1 = ~LED_D1;;//每发送一个字节,闪烁一次LED灯
  89.         delay();
  90.       }
  91.
  92.   }
  93.
  94.
  95.
  96.   for(;;) {
  97.     __RESET_WATCHDOG(); /* feeds the dog */
  98.   } /* loop forever */
  99.   /* please make sure that you never leave main */
  100. }
