[资料分享与下载] 飞思卡尔单片机DZ60---SCI(查询接收)
2265|7
niuyaliang 发表于 2015-2-27 20:09 | 显示全部楼层 |阅读模式
  1. [cpp] view plaincopy
  2. #include <hidef.h> /* for EnableInterrupts macro */
  3. #include "derivative.h" /* include peripheral declarations */
  4.
  5. //整个功能:PC-单片机-PC,PC串口发数据-单片机串口接收数据-单片机将接收到的数据发送回给PC
 楼主| niuyaliang 发表于 2015-2-27 20:10 | 显示全部楼层
  2. #define LED_D1      PTDD_PTDD0
  3. #define LED_D1_DIR  PTDDD_PTDDD0
  4.
  5. #define LED_ON      0
  6. #define LED_OFF     1
  7.
  8. unsigned char SCANF_SEND_STRINGS[] = "HELLO MCU WORLD";
  9. unsigned char *pSendString = SCANF_SEND_STRINGS;
  10. unsigned char ReceiveString;
  11.
  12. /*************************************************************/
  13. /*                  初始化总线时钟PEE模式                    */
  14. /*              外部晶振频率为4MHz,总线频率16MHz            */
  15. /*************************************************************/
  16. void INIT_MCG(void)
  17. {
  18.   MCGC2=0x36;
  19.   while(!MCGSC_OSCINIT);
  20.   MCGC1=0xb8;
  21.   while(MCGSC_IREFST);
  22.   while(MCGSC_CLKST!=0b10);
  23.   MCGC2_LP = 1;
  24.   MCGC1 = 0x90;
  25.   MCGC3 = 0x48;
  26.   MCGC2_LP = 0;
  27.   while(!MCGSC_PLLST);
  28.   while(!MCGSC_LOCK);
  29.   MCGC1 = 0x10;
  30.   while(MCGSC_CLKST!=0b11);
  31. }
  32.
  33.
  34. //延时函数
  35. void delay(void)
  36. {
  37.   unsigned int i;
  38.   unsigned int j;
  39.
  40.
  41.   for(i = 0; i < 100; i++)
  42.      for(j = 0; j < 4000; j++);
  43.
  44. }
  45.
  46.
  47. void main(void) {
  48.
  49.   DisableInterrupts;
  50.   SOPT1 = 0;
  51.   INIT_MCG();
  52.   EnableInterrupts; /* enable interrupts */
  53.   /* include your code here */
  54.
  55.   LED_D1_DIR = 1;
  56.   LED_D1     = LED_OFF;
  57.
  58.
  59.
  60. //以下为设置波特率,以及初始化SCI1控制寄存器
  61.   SCI1BDH = 0X00;
  62.   SCI1BDL = 0X68;//波特率设置为9600
  63.   SCI1C1 = 0x00; //设置SCI1为正常模式,八位数据位,无奇偶校验
  64.   SCI1C2 = 0x0C; //RE = 1(bit2)接收器打开
  65.                  //TE = 1(bit3)发送器打开
  66.
  67.
  68.   while(1)
  69.   {
  70.     while(!SCI1S1_RDRF);// SCI1S1_RDRF = 1时,表示接收数据寄存器满,可以取出数据
  71.     SCI1S1_RDRF  = 0; //清除SCI1S1_RDRF
  72.     ReceiveString = SCI1D; //将接收寄存器中的数据保存至ReceiveString
  73.   //  LED_D1 = ~LED_D1;
  74.    // delay();
  75.
  76.     while(!SCI1S1_TDRE);//SCI1S1_TDRE = 1时,发送数据寄存器(缓存区)空,可以发送数据
  77.     SCI1D = ReceiveString;//将接收到的数据,放至发送数据寄存器(缓存区),发送
  78.   //  LED_D1 = ~LED_D1;
  79. //   delay();
  80.
  81.   }
  82.
  83.
  84.   for(;;) {
  85.     __RESET_WATCHDOG(); /* feeds the dog */
  86.   } /* loop forever */
  87.   /* please make sure that you never leave main */
  88. }
  89.
  4.
  5. #define LED_ON      0
  7.
  11.
  17. {
  18.   MCGC2=0x36;
  20.   MCGC1=0xb8;
  23.   MCGC2_LP = 1;
  24.   MCGC1 = 0x90;
  25.   MCGC3 = 0x48;
  26.   MCGC2_LP = 0;
  29.   MCGC1 = 0x10;
  31. }
  32.
  33.
  34. //延时函数
  36. {
  37.   unsigned int i;
  38.   unsigned int j;
  39.
  40.
  43.
  44. }
  45.
  46.
  48.
  50.   SOPT1 = 0;
  51.   INIT_MCG();
  54.
  55.   LED_D1_DIR = 1;
  57.
  58.
  59.
  61.   SCI1BDH = 0X00;
  66.
  67.
  68.   while(1)
  69.   {
  74.    // delay();
  75.
  79. //   delay();
  80.
  81.   }
  82.
  83.
  84.   for(;;) {
  88. }
  89.
 楼主| niuyaliang 发表于 2015-2-27 20:11 | 显示全部楼层
程序改成下面语句,上位机串口发大数据不死机,但可能丢数据。
  2. while(1)
  3. {
  4. /*  while(!SCI1S1_RDRF);// SCI1S1_RDRF = 1时,表示接收数据寄存器满,可以取出数据
  5.    SCI1S1_RDRF  = 0; //清除SCI1S1_RDRF
  6.    ReceiveString = SCI1D; //将接收寄存器中的数据保存至ReceiveString
  7.
  8.
  9.   while(!SCI1S1_TDRE);//SCI1S1_TDRE = 1时,发送数据寄存器(缓存区)空,可以发送数据
  10.   SCI1D = ReceiveString;//将接收到的数据,放至发送数据寄存器(缓存区),发送
  11. /
  12.    if(SCI1S1_RDRF == 1)
  13.    {
  14.       ReceiveString = SCI1D;
  15.      if(SCI1S1_TDRE == 1)
  16.       {
  17.           SCI1D = ReceiveString;
  18.       }
  19.
  20.    }
  21.
  22.
  23. }
ccw1986 发表于 2015-2-28 08:41 | 显示全部楼层
谢谢分享
cowboy2014 发表于 2015-2-28 16:18 | 显示全部楼层
谢谢楼主的分享啊
就是爱你乖 发表于 2015-9-11 18:02 | 显示全部楼层
您好,我配置的SCI1,发送接收完全没问题。可是SCI2怎么调都不行,您调通了吗?求讲解
