[资料分享与下载] 飞思卡尔单片机DZ60---SCI(中断接收)
1631|2
niuyaliang 发表于 2015-2-27 20:12 | 显示全部楼层 |阅读模式
  1. [cpp] view plaincopy
  2. #include <hidef.h> /* for EnableInterrupts macro */
  3. #include "derivative.h" /* include peripheral declarations */
  4.
  5.
  6. #define LED_D1      PTDD_PTDD0
  7. #define LED_D1_DIR  PTDDD_PTDDD0
  8.
  9. #define LED_ON      0
  10. #define LED_OFF     1
  11.
  12. unsigned char SCANF_SEND_STRINGS[] = "HELLO MCU WORLD";
  13. unsigned char *pSendString = SCANF_SEND_STRINGS;
  14. unsigned char ReceiveString;
  15.
  16. /*************************************************************/
  17. /*                  初始化总线时钟PEE模式                    */
  18. /*              外部晶振频率为4MHz,总线频率16MHz            */
  19. /*************************************************************/
  20. void INIT_MCG(void)
  21. {
  22.   MCGC2=0x36;
  23.   while(!MCGSC_OSCINIT);
  24.   MCGC1=0xb8;
  25.   while(MCGSC_IREFST);
  26.   while(MCGSC_CLKST!=0b10);
  27.   MCGC2_LP = 1;
  28.   MCGC1 = 0x90;
  29.   MCGC3 = 0x48;
  30.   MCGC2_LP = 0;
  31.   while(!MCGSC_PLLST);
  32.   while(!MCGSC_LOCK);
  33.   MCGC1 = 0x10;
  34.   while(MCGSC_CLKST!=0b11);
  35. }
  36.
  37.
  38. //延时函数
  39. void delay(void)
  40. {
  41.   unsigned int i;
  42.   unsigned int j;
  43.
  44.
  45.   for(i = 0; i < 100; i++)
  46.      for(j = 0; j < 4000; j++);
  47.
  48. }
  49.
  50.
  51. void main(void) {
  52.
  53.   DisableInterrupts;
  54.   SOPT1 = 0;
  55.   INIT_MCG();
  56.   EnableInterrupts; /* enable interrupts */
  57.   /* include your code here */
  58.
  59.   LED_D1_DIR = 1;
  60.   LED_D1     = LED_OFF;
  61.
  62.
  63.
  64. //以下为设置波特率,以及初始化SCI1控制寄存器
  65.   SCI1BDH = 0X00;
  66.   SCI1BDL = 0X68;//波特率设置为9600
  67.   SCI1C1 = 0x00; //设置SCI1为正常模式,八位数据位,无奇偶校验
  68.   SCI1C2 = 0x2C; //RE = 1(bit2)接收器打开
  69.                  //TE = 1(bit3)发送器打开
  70.
  71.   while(1)
  72.   {
  73.
  74.   }
  75.
  76.
  77.
  78.
  79.   for(;;) {
  80.     __RESET_WATCHDOG(); /* feeds the dog */
  81.   } /* loop forever */
  82.   /* please make sure that you never leave main */
  83. }
  84.
  85.
  86. /*************************************************************/
  87. /*                SCI1中断向量接收函数                       */
  88. /*                向量编号为17,中断来源RDRF等               */
  89. /*************************************************************/
  90. interrupt 17 void SCI1_RECEIVE(void)
  91. {
  92.     while(!SCI1S1_RDRF);// SCI1S1_RDRF = 1时,表示接收数据寄存器满,可以取出数据
  93.     ReceiveString = SCI1D; //将接收寄存器中的数据保存至ReceiveString
  94.    LED_D1 = ~LED_D1;
  95.
  96.
  97.     while(!SCI1S1_TDRE);//SCI1S1_TDRE = 1时,发送数据寄存器(缓存区)空,可以发送数据
  98.     SCI1D = ReceiveString;//将接收到的数据,放至发送数据寄存器(缓存区),发送
  99.
  100. }
ccw1986 发表于 2015-2-28 08:41 | 显示全部楼层
谢谢分析哦
多多娃娃 发表于 2016-1-2 21:48 | 显示全部楼层
是否写一个 多字节的  串口中断接收呢?  假设 0.5 秒内 再没有接收到数据 ,就认为 接收完毕了
