PIC16F72编译警告求助!请高手帮忙!
2922|4
kaavie 发表于 2015-3-1 18:03 | 显示全部楼层 |阅读模式
一直用汇编首次用PICC遇到以下问题,望请各路高手帮忙!
个人认为1,C语言基础太弱;2,对CONST不了解,3,不确定是不是FONT存储到程序段是不是要选BANK。
一、《main.c》程序:
int main(void)
        LCDInit();
        putstr(30,5,"RonView");           //这是被警告的15行
  putstr(10,1,"STC12C5A60S2");      //这是被警告的16行
  delay(30000);
        cls();
  SHOW_BMP();
        delay(30000);
  cls();
  LCD_write_chinese_string(0,7,12,7,0,0);
  LCD_write_chinese_string(0,5,12,7,7,0);
  LCD_write_chinese_string(0,3,12,7,14,0);
  LCD_write_chinese_string(0,1,12,7,21,0);
        while(1);
二、其他程序片段:
const unsigned char FONT[]=              // ASCII
0x00,0x00,0x00,0x00,0x00, // - -
        0x00,0x00,0x5F,0x00,0x00, // -!-
        0x00,0x07,0x00,0x07,0x00, // -"-
        0x14,0x7F,0x14,0x7F,0x14, // -#-
        0x24,0x2E,0x7B,0x2A,0x12, // -$-
        0x23,0x13,0x08,0x64,0x62, // -%-
        0x36,0x49,0x56,0x20,0x50, // -&-
        0x00,0x04,0x03,0x01,0x00, // -'-
        0x00,0x1C,0x22,0x41,0x00, // -(-
        0x00,0x41,0x22,0x1C,0x00, // -)-
        0x22,0x14,0x7F,0x14,0x22, // -*-
        0x08,0x08,0x7F,0x08,0x08, // -+-
        0x40,0x30,0x10,0x00,0x00, // -,-
        0x08,0x08,0x08,0x08,0x08, // ---
        0x00,0x60,0x60,0x00,0x00, // -.-
        0x20,0x10,0x08,0x04,0x02, // -/-
        0x3E,0x51,0x49,0x45,0x3E, // -0-
        0x00,0x42,0x7F,0x40,0x00, // -1-
        0x62,0x51,0x49,0x49,0x46, // -2-
        0x21,0x41,0x49,0x4D,0x33, // -3-
        0x18,0x14,0x12,0x7F,0x10, // -4-
        0x27,0x45,0x45,0x45,0x39, // -5-
        0x3C,0x4A,0x49,0x49,0x31, // -6-
        0x01,0x71,0x09,0x05,0x03, // -7-
        0x36,0x49,0x49,0x49,0x36, // -8-
        0x46,0x49,0x49,0x29,0x1E, // -9-
        0x00,0x36,0x36,0x00,0x00, // -:-
        0x40,0x36,0x36,0x00,0x00, // -;-
        0x08,0x14,0x22,0x41,0x00, // -<-
        0x14,0x14,0x14,0x14,0x14, // -=-
        0x00,0x41,0x22,0x14,0x08, // ->-
        0x02,0x01,0x59,0x05,0x02, // -?-
        0x3E,0x41,0x5D,0x55,0x5E, // -@-
        0x7C,0x12,0x11,0x12,0x7C, // -A-
        0x7F,0x49,0x49,0x49,0x36, // -B-
        0x3E,0x41,0x41,0x41,0x22, // -C-
        0x7F,0x41,0x41,0x41,0x3E, // -D-
        0x7F,0x49,0x49,0x49,0x41, // -E-
        0x7F,0x09,0x09,0x09,0x01, // -F-
        0x3E,0x41,0x51,0x51,0x72, // -G-
        0x7F,0x08,0x08,0x08,0x7F, // -H-
        0x00,0x41,0x7F,0x41,0x00, // -I-
        0x20,0x40,0x41,0x3F,0x01, // -J-
        0x7F,0x08,0x14,0x22,0x41, // -K-
        0x7F,0x40,0x40,0x40,0x40, // -L-
        0x7F,0x02,0x0C,0x02,0x7F, // -M-
        0x7F,0x04,0x08,0x10,0x7F, // -N-
        0x3E,0x41,0x41,0x41,0x3E, // -O-
        0x7F,0x09,0x09,0x09,0x06, // -P-
        0x3E,0x41,0x51,0x21,0x5E, // -Q-
        0x7F,0x09,0x19,0x29,0x46, // -R-
        0x26,0x49,0x49,0x49,0x32, // -S-
        0x01,0x01,0x7F,0x01,0x01, // -T-
        0x3F,0x40,0x40,0x40,0x3F, // -U-
        0x1F,0x20,0x40,0x20,0x1F, // -V-
        0x7F,0x20,0x18,0x20,0x7F, // -W-
        0x63,0x14,0x08,0x14,0x63, // -X-
        0x03,0x04,0x78,0x04,0x03, // -Y-
        0x61,0x51,0x49,0x45,0x43, // -Z-
        0x7F,0x7F,0x41,0x41,0x00, // -[-
        0x02,0x04,0x08,0x10,0x20, // -\-
        0x00,0x41,0x41,0x7F,0x7F, // -]-
        0x04,0x02,0x7F,0x02,0x04, // -^-
        0x08,0x1C,0x2A,0x08,0x08, // -_-
        0x00,0x00,0x01,0x02,0x04, // -`-
        0x24,0x54,0x54,0x38,0x40, // -a-
        0x7F,0x28,0x44,0x44,0x38, // -b-
        0x38,0x44,0x44,0x44,0x08, // -c-
        0x38,0x44,0x44,0x28,0x7F, // -d-
        0x38,0x54,0x54,0x54,0x08, // -e-
        0x08,0x7E,0x09,0x09,0x02, // -f-
        0x98,0xA4,0xA4,0xA4,0x78, // -g-
        0x7F,0x08,0x04,0x04,0x78, // -h-
        0x00,0x00,0x79,0x00,0x00, // -i-
        0x00,0x80,0x88,0x79,0x00, // -j-
        0x7F,0x10,0x28,0x44,0x40, // -k-
        0x00,0x41,0x7F,0x40,0x00, // -l-
        0x78,0x04,0x78,0x04,0x78, // -m-
        0x04,0x78,0x04,0x04,0x78, // -n-
        0x38,0x44,0x44,0x44,0x38, // -o-
        0xFC,0x24,0x24,0x24,0x18, // -p-
        0x18,0x24,0x24,0x24,0xFC, // -q-
        0x04,0x78,0x04,0x04,0x08, // -r-
        0x48,0x54,0x54,0x54,0x24, // -s-
        0x04,0x3F,0x44,0x44,0x24, // -t-
        0x3C,0x40,0x40,0x3C,0x40, // -u-
        0x1C,0x20,0x40,0x20,0x1C, // -v-
        0x3C,0x40,0x3C,0x40,0x3C, // -w-
        0x44,0x28,0x10,0x28,0x44, // -x-
        0x9C,0xA0,0xA0,0x90,0x7C, // -y-
        0x44,0x64,0x54,0x4C,0x44, // -z-
        0x08,0x36,0x41,0x00,0x00, // -{-
        0x00,0x00,0x77,0x00,0x00, // -|-
        0x00,0x00,0x41,0x36,0x08, // -}-
        0x08,0x04,0x08,0x10,0x08, // -~-
        0x55,0x2A,0x55,0x2A,0x55, // --
void pputch(unsigned char x, unsigned char y, unsigned int ch)
  unsigned char i;
  send_cmd(Set_X_Address,x);
  send_cmd(Set_Y_Address,y);
  for(i=0;i<5;i++)
    send_dat(FONT[(ch-0x20)*5+i]);
void putstr(unsigned char x, unsigned char y, char *str)
  while(*str!=0)
    pputch(x,y,*str++);
    x=x+6;
三、错误信息:
Warning [359] G:\Program Case\VA TEST\Program\LCD DEMO\main.c; 15.22 illegal conversion between pointer types
pointer to const unsigned char -> pointer to unsigned char
Warning [359] G:\Program Case\VA TEST\Program\LCD DEMO\main.c; 16.27 illegal conversion between pointer types
HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode)  V9.83
Copyright (C) 2011 Microchip Technology Inc.
(1273) Omniscient Code Generation not available in Lite mode (warning)
Error   [1347] ; 0. can't find 0x7A7 words (0x7a7 withtotal) for psect "stringtext" in class "STRCODE" (largest unused contiguous range 0x7FF)
yklstudent 发表于 2015-3-1 20:50 | 显示全部楼层
版本没**吧,FLASH溢出了吧
 楼主| kaavie 发表于 2015-3-2 21:16 | 显示全部楼层
Lite Mode怎么变成Pro Mode,求指点!
yklstudent 发表于 2015-3-2 21:28 | 显示全部楼层
找和谐版本,自己努力找找就可以了
 楼主| kaavie 发表于 2015-3-7 16:51 | 显示全部楼层
**后是没地方去选择Lite Mode或是Pro Mode,谁能截图给我看下具体选择位置。
个人签名:科技永无止境!
19
