[Atmel] Atmel SAM V71 Xplained Ultra Evaluation Kit 介绍
2763|5
 楼主| ddllxxrr 发表于 2015-3-5 19:35 | 显示全部楼层 |阅读模式
The Atmel® | SMART™ SAM V71 Xplained Ultra evaluation kit is ideal for evaluating and prototyping with the Atmel SAM V71, SAM V70, SAM S70 and SAM E70 ARM® Cortex®-M7 based microcontrollers.
Extension boards to the SAM V71 Xplained Ultra can be purchased individually.
Key Features
  • ATSAMV71Q21 microcontroller
  • One mechanical reset button
  • One power switch button
  • Two mechanical user pushbuttons
  • Two yellow user LEDs
  • Supercap backup
  • 12.0 MHz crystal
  • 32.768 kHz crystal
  • 2 MB SDRAM
  • 2 MB QSPI Flash
  • IEEE 802.3az 10Base-T/100Base-TX Ethernet RMII PHY
  • AT24MAC402 256KByte EEPROM with EUI-48 address
  • Stereo audio codec
    • External PLL for precise clock generation
    • Microphone jack
    • Headphone jack
  • ATA6561 CAN Transceiver
  • SD Card connector with SDIO support
  • Camera interface connector
  • MediaLB connector
  • Two Xplained Pro extension headers One Xplained Pro LCD header
  • Coresight 20 connector for 4-bit ETM
  • Arduino due compatible shield connectors
  • External debugger connector
  • USB interface, device and host mode
  • Embedded Debugger
    • Auto-ID for board identification in Atmel Studio
    • One yellow status LED
    • One green board power LED
    • Symbolic debug of complex data types including scope information
    • Programming and debugging
    • Data Gateway Interface: SPI, I²C, 4 GPIOs
    • Virtual COM port (CDC)
  • External power input (5-14V)
  • USB powered
  • Supported with application examples in Atmel Software Framework
使用手册:
johnrey 发表于 2015-3-6 15:56 来自手机 | 显示全部楼层
动作真快
 楼主| ddllxxrr 发表于 2015-3-6 17:56 | 显示全部楼层
yhy123456 发表于 2015-5-20 18:47 | 显示全部楼层
好漂亮啊 ,这个板子是几层的啊
sigma318 发表于 2015-5-20 21:19 | 显示全部楼层
怎么购买,多谢钱?
 楼主| ddllxxrr 发表于 2015-5-21 19:15 | 显示全部楼层
怎么购买,多谢钱?
联系当地的代理商,或到贸泽电子去看看,我好像看到有买的
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
