[AVR单片机] 求教 Atmega8 无法进入外中断
1555|6
 楼主| sanguanko 发表于 2015-3-5 22:11 | 显示全部楼层 |阅读模式
ATmega8 无法进入外中断,程序如下,目的是发生一次外中断累加一次data_1,并通过串口送到PC,上电后串口调试助手只能收到一次01,如果能进入中断应该能收到04啊,求教。多谢
#include <avr/io.h>
/***********************************宏定义**********************************/
#define fosc 11059200         //晶振8MHZ
#define baud 9600                //波特率
unsigned char data_1;//每触发一次中断,该值加1
unsigned char flag;//发生int0中断后,该值置0xFF
void uart0_init(void)
        UCSRB = 0x00;
        UCSRA = 0x00;
        UCSRC =(1<<UCSZ1)|(1<<UCSZ0);
        UBRRL=(fosc/16/(baud+1))%256;
        UBRRH=(fosc/16/(baud+1))/256;
        UCSRB =(1<<RXEN)|(1<<TXEN);
void int0_init(void)
        MCUCR=(1<<ISC01);//INT0下降沿触发中断
        GICR=(1<<INT0);//enable INT0
SIGNAL(SIG_INTERRUPT0)
    cli();
        flag=0xff;
        putchar0(4);
        sei();
void putchar0(unsigned char c)
        while (!(UCSRA&(1<<UDRE)));
        UDR=c;
int main(void)
    uart0_init();
        int0_init();
        putchar0(1);
        sei();
        while(flag==0xff)
                cli();
                flag=0;
                if(data_1<=255)
                        putchar0(data_1);
                        putchar0(2);
                else
                        data_1=0;
                        putchar0(3);
        sei();
 楼主| sanguanko 发表于 2015-3-5 22:28 | 显示全部楼层
PD2外接有上啦电阻,按键按下时,用万用表量,PD2上却是有个有1->0的变化,为什么下降沿没产生中断呢?
j6920 发表于 2015-3-6 09:42 | 显示全部楼层
#include <avr/interrupt.h>
yklstudent 发表于 2015-3-7 18:16 | 显示全部楼层
* vs_proj2.c
* Created: 2015-3-7 14:16:35
*  Author: keliang.yao
#define F_CPU        11059200ul
#include <avr/io.h>
#include <util/delay.h>
#define fosc        11059200ul
#define baud        9600ul
unsigned char data_l;
unsigned char flag;
void usart0_init(void)
        UCSRB = 0x00;
        UCSRA = 0x00;
        UCSRC = (1<<UCSZ1)|(1<<UCSZ0);
        UBRRL = (fosc/16/(baud+1))%256;
        UBRRH = (fosc/16/(baud+1))/256;
        UCSRB = (1<<RXEN)|(1<<TXEN);
        while(!(UCSRA & (1<<UDRE)));
        UDR = c;
        MCUCR = (1<<ISC01);
        GICR = (1<<INT0);
SIGNAL(INT0_vect)
        cli();
        flag = 0xff;
        putchar0(4);
        sei();
int main(void)
        usart0_init();
        int0_init();
        putchar0(1);
        DDRB = 0XFF;
        PORTB = 0X00;
        sei();
        while(1)
        //TODO:: Please write your application code
                while(flag == 0xff)
                        cli();
                        flag = 0;
                        if(data_l <= 255)
                                putchar0(data_l);
                                putchar0(2);
                        else
                                data_l = 0;
                                putchar0(3);
                        sei();
楼主试试这样
 楼主| sanguanko 发表于 2015-3-7 21:58 | 显示全部楼层
谢谢,以前用的是AVRStudio,换成ICCAVR,程序没怎么改,竟然成了
NE5532 发表于 2015-3-16 20:33 | 显示全部楼层
楼主去把中断部分的datasheet重新看一遍再写程序,你满篇不停地开关总中断标志干啥?
SD10A 发表于 2015-9-2 22:35 | 显示全部楼层
这个   如果你不用外部电阻  使用内部上拉   会不会成了?
