推荐一款芯片:FS453 FS454 FS455 FS456
3644|1
 楼主| mmd2102 发表于 2007-2-2 09:50 | 显示全部楼层 |阅读模式
<B><font color=#000040>Description</font></B><br />The&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;is&nbsp;a&nbsp;video&nbsp;scan&nbsp;converter.&nbsp;It&nbsp;can&nbsp;accept&nbsp;computer&nbsp;graphics,&nbsp;in&nbsp;many&nbsp;different&nbsp;input&nbsp;resolutions&nbsp;and&nbsp;rates,&nbsp;and&nbsp;convert&nbsp;them&nbsp;to&nbsp;broadcast&nbsp;quality&nbsp;video.<br />The&nbsp;programmable&nbsp;up&nbsp;and&nbsp;down&nbsp;scaler&nbsp;allows&nbsp;the&nbsp;incoming&nbsp;resolution&nbsp;to&nbsp;be&nbsp;fitted&nbsp;to&nbsp;completely&nbsp;fill&nbsp;the&nbsp;output&nbsp;display&nbsp;screen.&nbsp;The&nbsp;programmable&nbsp;flicker&nbsp;filter&nbsp;is&nbsp;an&nbsp;advanced&nbsp;2&nbsp;dimensional&nbsp;filter&nbsp;that&nbsp;enhances&nbsp;text&nbsp;quality&nbsp;and&nbsp;eliminates&nbsp;artifacts.&nbsp;The&nbsp;degree&nbsp;of&nbsp;sharpness&nbsp;is&nbsp;also&nbsp;programmable.<br /><font color=#000040>Output&nbsp;Standards&nbsp;include:</font><br /><table class=ubb cellspacing=0><TR><td class=ubb><B>Format</B></td><td class=ubb><B>Standard<br /></B></td></TR><TR><td class=ubb>NTSC&nbsp;(SD)</td><td class=ubb>SMPTE-170M</td></TR><TR><td class=ubb>PAL&nbsp;(SD)</td><td class=ubb>ITU-R&nbsp;624</td></TR><TR><td class=ubb>480p&nbsp;(HD)</td><td class=ubb>EIA-770.2-A</td></TR><TR><td class=ubb>720p&nbsp;(HD)</td><td class=ubb>SMPTE&nbsp;296</td></TR><TR><td class=ubb>1080i&nbsp;(HD)</td><td class=ubb>SMPTE&nbsp;274</td></TR></table><br />The&nbsp;digital&nbsp;progressive&nbsp;RGB&nbsp;inputs&nbsp;are&nbsp;scaled&nbsp;to&nbsp;the&nbsp;ITU-R&nbsp;BT.601,&nbsp;4:2:2&nbsp;format.&nbsp;Vertical&nbsp;scaling&nbsp;and&nbsp;flicker&nbsp;filtering&nbsp;are&nbsp;done&nbsp;in&nbsp;the&nbsp;4:2:2&nbsp;format.<br />HD&nbsp;inputs&nbsp;bypass&nbsp;the&nbsp;scaler&nbsp;and&nbsp;flicker&nbsp;filter,&nbsp;and&nbsp;are&nbsp;formatted&nbsp;directly&nbsp;into&nbsp;HD&nbsp;compatible&nbsp;Component&nbsp;(YPrPb)&nbsp;outputs.<br />The&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;can&nbsp;be&nbsp;used&nbsp;both&nbsp;as&nbsp;a&nbsp;TV&nbsp;encoder&nbsp;and&nbsp;as&nbsp;a&nbsp;75MHz&nbsp;DAC&nbsp;for&nbsp;VGA&nbsp;–&nbsp;XGA&nbsp;outputs.<br />The&nbsp;digital&nbsp;video&nbsp;encoder&nbsp;generates&nbsp;Y/C,&nbsp;CVBS,&nbsp;RGB&nbsp;and&nbsp;YPrPb&nbsp;output&nbsp;signals.&nbsp;These&nbsp;signals&nbsp;can&nbsp;be&nbsp;combined&nbsp;to&nbsp;support&nbsp;RGB&nbsp;+&nbsp;CVBS&nbsp;for&nbsp;SCART,&nbsp;YPrPb&nbsp;+&nbsp;CVBS&nbsp;or&nbsp;multiple&nbsp;CVBS&nbsp;and&nbsp;Y/C&nbsp;DAC&nbsp;outputs.&nbsp;The&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;requires&nbsp;power&nbsp;from&nbsp;+1.8V&nbsp;digital&nbsp;and&nbsp;+3.3V&nbsp;analog&nbsp;supplies.&nbsp;For&nbsp;external&nbsp;components,&nbsp;it&nbsp;only&nbsp;needs&nbsp;a&nbsp;27&nbsp;MHz&nbsp;clock&nbsp;and&nbsp;passive&nbsp;parts.&nbsp;The&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;is&nbsp;an&nbsp;80-lead&nbsp;Quad&nbsp;Flat&nbsp;Pack&nbsp;(PQFP)&nbsp;package.<br /><H4><font color=#000040>Features</font></H4><UL><li>Programmable&nbsp;2D&nbsp;scaling<br />–&nbsp;Variable&nbsp;horizontal&nbsp;up&nbsp;and&nbsp;down&nbsp;scale<br />–&nbsp;Variable&nbsp;vertical&nbsp;up&nbsp;and&nbsp;down&nbsp;scale<br />–&nbsp;Output&nbsp;format&nbsp;can&nbsp;be&nbsp;tuned&nbsp;to&nbsp;the&nbsp;exact&nbsp;dimensions&nbsp;of&nbsp;the&nbsp;TV<br />–&nbsp;VGA&nbsp;input&nbsp;can&nbsp;be&nbsp;upscaled&nbsp;to&nbsp;fit&nbsp;PAL&nbsp;(720x576)<br /><li>Advanced&nbsp;2D&nbsp;flicker&nbsp;filter<br /><li>Broadcast&nbsp;quality&nbsp;video&nbsp;encoder<br /><li>Supports&nbsp;multiple&nbsp;progressive&nbsp;input&nbsp;resolutions<br />–&nbsp;Minimum&nbsp;640x480<br />–&nbsp;Maximum&nbsp;1280&nbsp;x&nbsp;1024&nbsp;(SXGA)<br /><li>HD&nbsp;modes<br />–&nbsp;480p<br />–&nbsp;720p<br />–&nbsp;1080i<br /><li>Multiple&nbsp;output&nbsp;formats<br />–&nbsp;NTSC,&nbsp;NTSC-EIAJ,&nbsp;PAL-B/G/H/I<br />–&nbsp;PAL-M,&nbsp;PAL-N,&nbsp;PAL-60<br />–&nbsp;Composite,&nbsp;S-Video<br />–&nbsp;RGB&nbsp;SCART&nbsp;with&nbsp;CVBS<br />–&nbsp;HD&nbsp;YPrPb<br />–&nbsp;SD&nbsp;YPrPb<br />–&nbsp;VGA&nbsp;modes&nbsp;through&nbsp;XGA<br /><li>Glueless&nbsp;digital&nbsp;interface&nbsp;to&nbsp;display&nbsp;chips<br /><li>ITU-R&nbsp;BT.656&nbsp;studio&nbsp;grade&nbsp;encoder<br /><li>4&nbsp;assignable&nbsp;10-bit&nbsp;output&nbsp;D/A&nbsp;converters<br /><li>Macrovision&nbsp;7&nbsp;compliant&nbsp;(FS454)<br />–&nbsp;Includes&nbsp;480p&nbsp;support<br /><li>I2C*&nbsp;compatible&nbsp;port&nbsp;controls<br /><li>80&nbsp;pin&nbsp;PQFP&nbsp;package<br /><li>3.3V,&nbsp;1.8V&nbsp;operation&nbsp;</li></UL><H5><font color=#000040>Applications</font></H5><UL><li>PC&nbsp;Video&nbsp;Out&nbsp;<li>Web&nbsp;Appliances&nbsp;<li>Video&nbsp;Kiosks&nbsp;<li>Gaming&nbsp;Consoles&nbsp;</li></UL><br /><br /><I>*Note:&nbsp;I2C&nbsp;is&nbsp;a&nbsp;registered&nbsp;trademark&nbsp;of&nbsp;Philips&nbsp;Corporation.&nbsp;The&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;Serial&nbsp;I/O&nbsp;bus&nbsp;is&nbsp;similar&nbsp;but&nbsp;not&nbsp;identical&nbsp;to&nbsp;the&nbsp;Philips&nbsp;I2C&nbsp;bus.&nbsp;</I><I>All&nbsp;parameters&nbsp;can&nbsp;be&nbsp;read&nbsp;and&nbsp;written&nbsp;via&nbsp;the&nbsp;I2C&nbsp;compatible&nbsp;serial&nbsp;port.&nbsp;The&nbsp;flexibility&nbsp;of&nbsp;the&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;allows&nbsp;a&nbsp;glueless&nbsp;digital&nbsp;interface&nbsp;to&nbsp;most&nbsp;graphic&nbsp;display&nbsp;chips.<br /></I><br /><font color=#000040><B><BLINK>architectual&nbsp;overview</BLINK></B></font><br />The&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;PC-to-Video&nbsp;Scan&nbsp;Converter&nbsp;supports&nbsp;High&nbsp;Definition&nbsp;(HD)&nbsp;and&nbsp;Standard&nbsp;Definition&nbsp;(SD)&nbsp;outputs&nbsp;and&nbsp;is&nbsp;compatible&nbsp;with&nbsp;most&nbsp;graphic&nbsp;controller&nbsp;chips.&nbsp;It&nbsp;takes&nbsp;in&nbsp;digital&nbsp;RGB&nbsp;or&nbsp;YCrCb&nbsp;data&nbsp;and&nbsp;produces&nbsp;SD&nbsp;or&nbsp;HD&nbsp;analog&nbsp;outputs.&nbsp;In&nbsp;SD&nbsp;mode&nbsp;the&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;converts,&nbsp;scales,&nbsp;removes&nbsp;flicker,&nbsp;interlaces&nbsp;and&nbsp;encodes&nbsp;the&nbsp;data&nbsp;into&nbsp;NTSC&nbsp;or&nbsp;PAL&nbsp;formats.&nbsp;In&nbsp;HD&nbsp;mode&nbsp;the&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;performs&nbsp;the&nbsp;different&nbsp;color&nbsp;space&nbsp;conversions&nbsp;then&nbsp;inserts&nbsp;the&nbsp;required&nbsp;syncs&nbsp;for&nbsp;output.&nbsp;The&nbsp;FS453&nbsp;/&nbsp;FS454&nbsp;has&nbsp;the&nbsp;following&nbsp;major&nbsp;sections:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<img src="http://www.focussemi.com/images/products/fs454/fs454_block.gif">&nbsp;&nbsp;&nbsp;<li>Input&nbsp;Synchronization&nbsp;<li>Patented&nbsp;Horizontal&nbsp;and&nbsp;Vertical&nbsp;Scaling&nbsp;<li>Programmable&nbsp;Color&nbsp;Space&nbsp;Converter&nbsp;<li>Patented&nbsp;2D&nbsp;Flicker&nbsp;Filter&nbsp;<li>Studio&nbsp;Grade&nbsp;Encoder&nbsp;<li>HDTV&nbsp;Sync&nbsp;Insertion&nbsp;<li>Configurable&nbsp;Quad&nbsp;10&nbsp;bit&nbsp;DAC&nbsp;<li>Oscillators&nbsp;and&nbsp;PLLs&nbsp;<li>Serial&nbsp;Control&nbsp;Port&nbsp;</li><br /> 相关链接:<a href='http://hi.baidu.com/embedall/blog/item/007e993808b8e3c2d462255d.html'>http://hi.baidu.com/embedall/blog/item/007e993808b8e3c2d462255d.html</a>
 楼主| mmd2102 发表于 2007-2-2 10:01 | 显示全部楼层
1.3 General Physical Requirements
1.3&nbsp;<font color=#FF0000>General&nbsp;Physical&nbsp;Requirements</font><br /><br />Implementing&nbsp;the&nbsp;FS453&nbsp;in&nbsp;your&nbsp;system&nbsp;will&nbsp;require&nbsp;very&nbsp;few&nbsp;components&nbsp;–&nbsp;just&nbsp;a&nbsp;27&nbsp;MHz&nbsp;clock&nbsp;and&nbsp;passive&nbsp;parts.&nbsp;&nbsp;The&nbsp;FS453&nbsp;uses&nbsp;an&nbsp;80-lead&nbsp;Quad&nbsp;Flat&nbsp;Pack&nbsp;(PQFP)&nbsp;or&nbsp;an&nbsp;88-lead&nbsp;Fine-pitch&nbsp;Ball&nbsp;Grid&nbsp;<br />Array&nbsp;(FBGA)&nbsp;package&nbsp;and&nbsp;requires&nbsp;power&nbsp;from&nbsp;+1.8V&nbsp;digital&nbsp;and&nbsp;+3.3V&nbsp;analog&nbsp;supplies.&nbsp;&nbsp;
