ads中一个奇怪的汇编问题,s1,s2
2738|1
 楼主| luocolor 发表于 2007-3-12 10:41 | 显示全部楼层 |阅读模式
我使用<br />&nbsp;&nbsp;&nbsp;SS1&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;0xEE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;编译可以通过,<br />但是当我使用:<br />&nbsp;&nbsp;&nbsp;S1&nbsp;&nbsp;&nbsp;EQU&nbsp;&nbsp;0xEE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;,编译确会出问题,错误代码是A1108E:&nbsp;Multiply&nbsp;or&nbsp;incompatibly&nbsp;defined&nbsp;symbol<br />我实在不明白怎么回事,S1我在程序中并没有用到啊.我使用A1,B1定义也都没有问题.很奇怪.
 楼主| luocolor 发表于 2007-3-12 11:07 | 显示全部楼层
原来这样
唉!<br /><br />Syntax<br />FMRRS{cond}&nbsp;Rd,&nbsp;Rn,&nbsp;{Sn,Sm}<br />FMSRR{cond}&nbsp;{Sn,Sm},&nbsp;Rd,&nbsp;Rn<br />where:<br />cond&nbsp;is&nbsp;an&nbsp;optional&nbsp;condition&nbsp;code&nbsp;(see&nbsp;VFP&nbsp;and&nbsp;condition&nbsp;codes&nbsp;on&nbsp;page&nbsp;6-8).<br />Sn,&nbsp;Sm&nbsp;are&nbsp;two&nbsp;consecutive&nbsp;VFP&nbsp;single-precision&nbsp;registers.<br />Rd,&nbsp;Rn&nbsp;are&nbsp;the&nbsp;ARM&nbsp;registers.&nbsp;Do&nbsp;not&nbsp;use&nbsp;r15.
