PCM3010 怎么设置MUTE状态???
1070|8
 楼主| liuzaiy 发表于 2015-3-14 09:29 | 显示全部楼层 |阅读模式
PCM, TE, pc
houcs 发表于 2015-3-14 09:31 | 显示全部楼层
很多编码器都有MUTE管教 这个居然没有?
pangb 发表于 2015-3-14 09:31 | 显示全部楼层
你担心什么呢?
 楼主| liuzaiy 发表于 2015-3-14 09:32 | 显示全部楼层
有个关断电源控制脚   关电做静音 会有冲击声吧?
小小猫咪 发表于 2015-3-14 09:32 | 显示全部楼层
搞不好得要额外加电路来实现静音
houcs 发表于 2015-3-14 09:33 | 显示全部楼层
To eliminate the clicking noise which is generated by DAC output dc level change during power-down ON/OFF
control, external mute control is generally required. The recommended control sequence is: external mute ON,
codec power down ON, SCKI stop and restart if necessary, codec power down OFF, and external mute OFF.
yinxiangh 发表于 2015-3-14 09:40 | 显示全部楼层
To eliminate the clicking noise which is generated by DAC output dc level change during power-down O ...
外部静音控制?
houcs 发表于 2015-3-14 09:40 | 显示全部楼层
找技术支持啊,他们应该有典型的应用设计电路图。
 楼主| liuzaiy 发表于 2015-3-14 09:41 | 显示全部楼层
好,我知道了,多谢啊
