【TI 技术资料分享】12864串口画图
568|1
胡斯哲|  楼主 | 2015-3-14 17:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
串口画图
#include  <msp430x14x.h>
#include <math.h>
#include "pic.h"
#define  LCD_CS_High   P5OUT|=BIT2   // LCD_RS      P62
#define  LCD_CS_Low    P5OUT&=~BIT2   // LCD_RS
#define  LCD_SID_High   P5OUT|=BIT4   // LCD_RW  DB0_DB7   P64
#define  LCD_SID_Low    P5OUT&=~BIT4   // LCD_RW IR DR
#define  LCD_CLK_High   P5OUT|=BIT3   // LCD_EN P63
#define  LCD_CLK_Low    P5OUT&=~BIT3   // LCD_EN
#define  LCD_PSB_High   P5OUT|=BIT0  //
#define  LCD_PSB_Low    P5OUT&=~BIT0  //     P30
#define uchar unsigned char
#define uint  unsigned int
uchar line[64][16]={0},Point[8]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
void delay_ms(unsigned int timer)
  unsigned int i;
    for(i=0;i<1000;i--)
       for(;timer>0;timer--)
void Send_Byte(unsigned byte)
  uchar i;
  for(i=0;i<8;i++)
     LCD_CLK_Low;
     if(byte&0x80)
     {LCD_SID_High; delay_ms(10);}
     else
     { LCD_SID_Low ;delay_ms(10);}
     byte<<=1;
     LCD_CLK_High;
     delay_ms(10);
     LCD_CLK_Low;
     delay_ms(10);
/*鍐欏懡浠ゅ埌娑叉櫠*/
void LCD_WCMD(unsigned char cmd)
     delay_ms(1);
     Send_Byte(0xf8);            //11111,RW(0),RS(0),0;
     delay_ms(2);
     Send_Byte(0xf0&cmd);
     delay_ms(2);
     Send_Byte(0xf0&cmd<<4);
     delay_ms(2);
/*鍐欐暟鎹埌娑叉櫠*/
void LCD_WDAT(unsigned char date)
     delay_ms(1);
     Send_Byte(0xfa);            //11111,RW(0),RS(1),0
     delay_ms(2);
     Send_Byte(0xf0&date);
     delay_ms(2);
     Send_Byte(0xf0&date<<4);
     delay_ms(2);
void Display(unsigned char X,unsigned char Y,unsigned char *string)
   if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
     LCD_WCMD(X+Y);
   while(*string )
    {                         //鏄
      LCD_WDAT(*string++);
void Display_number(unsigned char X,unsigned char Y,unsigned char number)
    if (X==0)
     {X=0x80;}
   else if (X==1)
     {X=0x90;}
   else if (X==2)
     {X=0x88;}
   else if (X==3)
     {X=0x98;}
     LCD_WCMD(X+Y);
     LCD_WDAT(48+number);
void Clock_init()
   unsigned char t;
   BCSCTL1 = RSEL0 + RSEL1 + RSEL2;         // XT2on, max RSEL
   BCSCTL1&=~XT2OFF;                        //鎵撳紑XT2鎸崱鍣?
   do
      IFG1 &= ~OFIFG;                       // 娓呴櫎鎸崱鍣ㄥけ鏁堟爣蹇?
      for (t = 255; t > 0; t--);            // 寤舵椂锛岀瓑寰匵T2璧锋尟
   while ((IFG1 & OFIFG) != 0);             // 鍒ゆ柇XT2鏄惁璧锋尟
   BCSCTL2 |= SELS+SELM_2;                  // SMCLK = XT2
void LCD_init()
   LCD_WCMD(0x34);      //鎵嶄綔
   delay_ms(2);
   LCD_WCMD(0x30);      //嶄綔
   delay_ms(2);
   LCD_WCMD(0x0C);      //鏄叧鍏夋爣
   delay_ms(2);
   LCD_WCMD(0x01);      //
   delay_ms(2);
                      娓呭睆
void ClrScreen()
   LCD_WCMD(0x01);
   delay_ms(15);
                 璁剧疆鍒扮粯鍥炬ā寮?
void SetGraphicMode()
   LCD_WCMD(0x36);       //閫夋嫨紡
   delay_ms(20);
                   鏄剧ず鍥剧墖
void LCD_PutGraphic(unsigned char  *img)
   int i,j;
   for(i=0;i<32;i++)
      LCD_WCMD(0x80 + i); //
      LCD_WCMD(0x80);     //
      for(j=0;j<16;j++)
         LCD_WDAT(*img);
         img++;
        for(i=0;i<32;i++)
            LCD_WCMD(0x80 + i);
            LCD_WCMD(0x88);
            for(j=0;j<16;j++)
                       LCD_WDAT(*img);
                       img++;
void DrawPoint(uchar x,uchar y)
    line[x][y/8]|=Point[y%8];
    //delay_ms(100);
void  main( void )
  uchar u;
  //unsigned char x,y,colour=1 ;
  WDTCTL = WDTPW + WDTHOLD;     // Stop watchdog timer to prevent time out reset
  //Clock_init();                 //
  P5DIR|=BIT0+BIT2+BIT3+BIT4;
  LCD_PSB_Low;
  LCD_init();
  for(u=0;u<64;u++)
  DrawPoint(u,u);
  for(u=32;u<63;u++)
  DrawPoint(32,u);
  for(u=32;u<63;u++)
  DrawPoint(32,u+32);
  for(u=63;u>0;u--)
  DrawPoint(63-u,u+63);
  ClrScreen();                                                  //清屏
  SetGraphicMode();                                            //设置成绘图模式
  LCD_PutGraphic(&line[0][0]);
  delay_ms(5000);
  _BIS_SR(LPM0_bits);
perry_peng| | 2015-3-17 16:51 | 只看该作者
:handshake
