IAR编译连接出错,问题在哪里?<br />Error[e16]: Segment INTVEC (size: 0x410 align: 0x2) is too long for segment definition. At <br />least 0x3d0 more bytes needed. The problem occurred while processing the segment <br />placement command "-Z(CODE)INTVEC=00-3F", where at the moment of placement the <br />available memory ranges were "CODE:0-3f" <br /> Reserved ranges relevant to this placement: <br /> 0-3f INTVEC <br /><br /> |
