dsp28335工程错误
552|1
 楼主| xscumt 发表于 2015-3-24 10:00 | 显示全部楼层 |阅读模式
用28335出现这个错误fatal error: file "../DSP2833x_common/source/Debug/DAC5615.obj" specifies ISA
   revision "C2800", which is not compatible with ISA revision "C28FPU32"
   specified in a previous file or on the command line
怎么回事啊啊 求指导
zhangmangui 发表于 2015-3-24 22:44 | 显示全部楼层
