求助:关于s3c2410 samsung3.5"TFTLCD显示
2925|4
 楼主| lennie298 发表于 2007-3-22 00:57 | 显示全部楼层 |阅读模式
&nbsp;下午下了与开发板配套的内核,LCD还能把图像显示出来,但是位置似乎有点不对<br />于是我再去linux下编译内核,下到板子上LCD没有显示,结果整了一晚上都没反应。。。<br /><br />再把原先配套的内核弄进去也没有显示了,运行到内核后LCD一直亮着(没图像,纯白)<br /><br />主机控制台显示如下:<br /><br />Inode-cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;4096&nbsp;(order:&nbsp;3,&nbsp;32768&nbsp;bytes)<br />Mount-cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;1024&nbsp;(order:&nbsp;1,&nbsp;8192&nbsp;bytes)<br />Buffer-cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;4096&nbsp;(order:&nbsp;2,&nbsp;16384&nbsp;bytes)<br />Page-cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;16384&nbsp;(order:&nbsp;4,&nbsp;65536&nbsp;bytes)<br />POSIX&nbsp;conformance&nbsp;testing&nbsp;by&nbsp;UNIFIX<br />Linux&nbsp;NET4.0&nbsp;for&nbsp;Linux&nbsp;2.4<br />Based&nbsp;upon&nbsp;Swansea&nbsp;University&nbsp;Computer&nbsp;Society&nbsp;NET3.039<br />Initializing&nbsp;RT&nbsp;netlink&nbsp;socket<br />CPU&nbsp;clock&nbsp;=&nbsp;200.000&nbsp;Mhz,&nbsp;HCLK&nbsp;=&nbsp;100.000&nbsp;Mhz,&nbsp;PCLK&nbsp;=&nbsp;50.000&nbsp;Mhz<br />Initializing&nbsp;S3C2410&nbsp;buffer&nbsp;pool&nbsp;for&nbsp;DMA&nbsp;workaround<br />S3C2410&nbsp;USB&nbsp;Controller&nbsp;Core&nbsp;Initialized<br />USB&nbsp;Function&nbsp;Character&nbsp;Driver&nbsp;Inte**ce&nbsp;-&nbsp;0.5,&nbsp;(C)&nbsp;2001,&nbsp;Extenex&nbsp;Corp.<br />usbctl:&nbsp;Opened&nbsp;for&nbsp;usb-char<br />usbctl:&nbsp;Started&nbsp;for&nbsp;usb-char<br />Starting&nbsp;kswapd<br />devfs:&nbsp;v1.10&nbsp;(20020120)&nbsp;Richard&nbsp;Gooch&nbsp;(rgooch@atnf.csiro.au)<br />devfs:&nbsp;boot_options:&nbsp;0x1<br />ttyS%d0&nbsp;at&nbsp;I/O&nbsp;0x50000000&nbsp;(irq&nbsp;=&nbsp;52)&nbsp;is&nbsp;a&nbsp;S3C2410<br />ttyS%d1&nbsp;at&nbsp;I/O&nbsp;0x50004000&nbsp;(irq&nbsp;=&nbsp;55)&nbsp;is&nbsp;a&nbsp;S3C2410<br />ttyS%d2&nbsp;at&nbsp;I/O&nbsp;0x50008000&nbsp;(irq&nbsp;=&nbsp;58)&nbsp;is&nbsp;a&nbsp;S3C2410<br />SAMSUNG&nbsp;LTV350QV&nbsp;35IN&nbsp;LCD&nbsp;TEST.<br />Samsung&nbsp;320x240&nbsp;LCD<br />Samsung&nbsp;320x240&nbsp;LCD<br /><br />执行到这里就不动了,实在是调得头痛了,<br /><br />请各位大虾帮我看一下是哪里出的问题,是不是LCD烧坏了?<br /><br />&nbsp;小弟在此先行谢过!<br /><br />&nbsp;<br />&nbsp;
阿南 发表于 2007-3-22 17:09 | 显示全部楼层
如果怀疑LCD或硬件有问题,可以不用linux先测试一下好环
1dqmoon 发表于 2007-3-22 23:04 | 显示全部楼层
使用2410test中的lcd test来试一下
使用那个后,一般屏幕都会有显示,如果没有,说明硬件没接好,后者是屏挂了
 楼主| lennie298 发表于 2007-3-23 12:37 | 显示全部楼层
谢谢楼上两位
<br />硬件测试是好的<br />连接也没问题<br />会不会是能耗的问题?那先前怎么能显示呢
1dqmoon 发表于 2007-3-24 21:03 | 显示全部楼层
那有可能是你的程序出错
可能是你改动了linux的显示驱动,换回原来的程序试试看
