我遇到了两个符号:一个是[],一个|(竖线),前一个不知道,后一个不太清楚。请大家帮助,谢谢。<br /><br />如:<br /><br /> GBLL THUMB<br /> GBLL ARM<br /> [ {CONFIG} = 16<br />THUMB SETL {TRUE}<br />ARM SETL {FALSE}<br /><br />; If assembling with TASM go into 32 bit mode as the Armulator will<br />; start up the program in ARM state.<br /><br /> CODE32<br /> |<br />THUMB SETL {FALSE}<br />ARM SETL {TRUE}<br /> ]<br /><br /><br />还有一个是双竖线:<br /><br /> AREA |C$$data|, DATA, READWRITE<br /> |
