[Atmel] SAM4 的28个新应用
1297|6
 楼主| ddllxxrr 发表于 2015-3-30 22:05 | 显示全部楼层 |阅读模式
sam, TE, ic, AN, TI
这个是我浏览时发现在,不敢独享特来分享。
Atmel engineers recently published 28 application notes for the company’s comprehensive lineup of ARM-based SAM4 devices.
According to an Atmel engineering rep, the application notes target the use of peripheral modules and are based on drivers already available in the ASF (Atmel Software Framework).
“The application notes highlight the availability of the drivers and offers the reader relevant details about the API (application programming interface),” the rep explained.
“This significant increase in the number of application notes for the SAM4 series gives the engineer a better starting point for using the products. More specifically, the new application notes cover the Atmel SAM4S/SD, SAM4N, SAM4L/LS, SAM4E, and to some extent, also the SAM4C and SAM G51/53 families.”
The following app notes are now available from the Atmel web site in PDF format:
missnihao 发表于 2015-3-31 17:26 | 显示全部楼层
楼主好强大呀,收藏
sssha 发表于 2015-3-31 17:34 | 显示全部楼层
多谢版主慷慨分享~:P
如果有中文的就更好了
okyouwin 发表于 2015-3-31 18:10 | 显示全部楼层
资料好强大,。赞一个、
jiang390625 发表于 2015-3-31 18:18 | 显示全部楼层
新应用,点赞。值得一看
catking25 发表于 2015-3-31 18:41 | 显示全部楼层
都是英文版的
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
