[TI] msp430f5528 硬件i2c 无法进入中断
1736|3
 楼主| dingliangzhu 发表于 2015-3-31 11:25 | 显示全部楼层 |阅读模式
#include <msp430.h>
unsigned char TXData;
unsigned char TXByteCtr;
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P3SEL |= 0x03;                            // Assign I2C pins to USCI_B0
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
  UCB0BR1 = 0;
  UCB0I2CSA = 0x48;                         // Slave Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  UCB0IE |= UCTXIE;                         // Enable TX interrupt
  TXData = 0x01;                            // Holds TX data
  while (1)
    TXByteCtr = 1;                          // Load TX byte counter
    while (UCB0CTL1 & UCTXSTP);             // Ensure stop condition got sent
    UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
    __bis_SR_register(LPM0_bits + GIE);     // Enter LPM0 w/ interrupts
    __no_operation();                       // Remain in LPM0 until all data
                                            // is TX'd
    TXData++;                               // Increment data byte
// The USCIAB0_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count.
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_B0_VECTOR))) USCI_B0_ISR (void)
#else
#error Compiler not supported!
#endif
  switch(__even_in_range(UCB0IV,12))
  case  0: break;                           // Vector  0: No interrupts
  case  2: break;                           // Vector  2: ALIFG
  case  4: break;                           // Vector  4: NACKIFG
  case  6: break;                           // Vector  6: STTIFG
  case  8: break;                           // Vector  8: STPIFG
  case 10: break;                           // Vector 10: RXIFG
  case 12:                                  // Vector 12: TXIFG
    if (TXByteCtr)                          // Check TX byte counter
      UCB0TXBUF = TXData;                   // Load TX buffer
      TXByteCtr--;                          // Decrement TX byte counter
    else
      UCB0CTL1 |= UCTXSTP;                  // I2C stop condition
      UCB0IFG &= ~UCTXIFG;                  // Clear USCI_B0 TX int flag
      __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
    break;
  default: break;
上面是TI官方提供的硬件I2C的一个操作例程。我将该例程下载到5528单片机中,调试中发现无法进入中断服务函数。我觉得执行完下面三句后,应该就要进入中断。
其中, UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition  这条语句执行完后应该将起始位和从机地址发送出去,理论上在中断使能的情况下就可以进入中断了。
从机是PCF8574(i/o扩展芯片,用来驱动lcd1602),默认地址为0x27,从机地址是对的。上下拉电阻也加上了。不知道问题出在哪个方面,请大家帮帮忙,谢谢!
 楼主| dingliangzhu 发表于 2015-3-31 15:32 | 显示全部楼层
问题解决了,软件没问题,是我硬件的问题。
评分
参与人数 1威望 +6 收起 理由
yytda + 6 赞一个!
查看全部评分
小猫爱吃鱼 发表于 2015-5-22 21:35 | 显示全部楼层
正在用串口,用的是2410,也能用吧?
adsionshm 发表于 2015-7-13 16:35 | 显示全部楼层
好东西,多谢分享
