[S3C2440] 关于Linux NFS启动问题
1079|0
 楼主| wx837078933 发表于 2015-4-1 09:43 | 显示全部楼层 |阅读模式
刚开始学习linux,跟着教程移植了mini2440的内核,并按照友善的手册添加dm9000网卡支持,但是出现了很奇怪的问题,当使用tftp把内核下载并烧写到nand中,并使用u-boot的b命令启动内核,则可以成功启动内核,并挂载到NFS文件系统上,但是,一旦重启,在使用b命令,内核能启动,但就是不能找到网卡,提示etho not found,不能挂载到nfs系统。
出错的启动信息。请大神解惑。。。。谢谢了
Starting kernel ...
Uncompressing Linux.............................................................        ....................................................................... done, bo        oting the kernel.
Linux version 2.6.32.2 (root@ubuntu) (gcc version 4.4.3 (ctng-1.6.1) ) #16 Tue M        ar 31 07:44:14 PDT 2015
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: MINI2440
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: noinitrd init=/linuxrc mem=64m root=/dev/nfs rw nfsroot=192        .168.1.24://NFSboot/rootfs ip=192.168.1.70:192.168.1.24:192.168.1.1:255.255.255.        0::eth0:off console=ttySAC0
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60480KB available (3700K code, 418K data, 160K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 97 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
ROMFS MTD (C) 2007 Red Hat, Inc.
msgmni has been set to 118
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Console: switching to colour frame buffer device 60x53
fb0: s3c2410fb frame buffer device
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
brd: module loaded
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c24xx-nand s3c2440-nand: Tacls=2, 20ns Twrph0=6 60ns, Twrph1=2 20ns
s3c24xx-nand s3c2440-nand: NAND soft ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bi        t)
Scanning device for bad blocks
Bad eraseblock 158 at 0x0000013c0000
Bad eraseblock 754 at 0x000005e40000
Bad eraseblock 1539 at 0x00000c060000
Creating 5 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "U-boot"
ftl_cs: FTL header not found.
0x000000040000-0x000000060000 : "param"
0x000000060000-0x000000560000 : "Kernel"
0x000000560000-0x000040560000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 256MiB 3,3V 8-bit"        -- size truncated to 0xfaa0000
0x000000000000-0x000040000000 : "nand"
mtd: partition "nand" extends beyond the end of device "NAND 256MiB 3,3V 8-bit"        -- size truncated to 0x10000000
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
dm9000 Ethernet Driver, V1.31
dm9000 dm9000: eth%d: Invalid ethernet MAC address. Please set using ifconfig
eth0: dm9000e at c486e300,c4872304 IRQ 51 MAC: 00:00:00:00:00:00 (chip)
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
i2c /dev entries driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
cpuidle: using governor ladder
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
IP-Config: Failed to open eth0
IP-Config: Device `eth0' not found.
Looking up port of RPC 100003/2 on 192.168.1.24
--------------------------------------------------------------------------------------------成功的信息-------------------------
OpenJTAG> tftp 30000000 net_xin_uImage
dm9000 i/o: 0x20000000, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 08:00:3e:26:0a:5b
could not establish link
TFTP from server 192.168.1.24; our IP address is 192.168.1.70
Filename 'net_xin_uImage'.
Load address: 0x30000000
Loading: checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
done
Bytes transferred = 2145524 (20bcf4 hex)
OpenJTAG> nand write.jffs2 30000000 kernel 20bcf4
NAND write: device 0 offset 0x60000, size 0x20bcf4
Writing data at 0x26b800 -- 100% complete.
2145524 bytes written: OK
OpenJTAG> menu
##### 100ask Bootloader for OpenJTAG #####
[n] Download u-boot to Nand Flash
[o] Download u-boot to Nor Flash
[k] Download Linux kernel uImage
[j] Download root_jffs2 image
[y] Download root_yaffs image
[d] Download to SDRAM & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the Nand Flash
Set the boot parameters
Boot the system
[r] Reboot u-boot
[q] Quit from menu
Enter your selection:
Enter your selection: b
Booting Linux ...
NAND read: device 0 offset 0x60000, size 0x500000
Reading data from 0x55f800 -- 100% complete.
5242880 bytes read: OK
## Booting image at 30007fc0 ...
   Image Name:   Linux-2.6.32.2
   Created:      2015-03-31  14:44:37 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2145460 Bytes =  2 MB
   Load Address: 30008000
   Entry Point:  30008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
Starting kernel ...
Uncompressing Linux.................................................................................................................................... done, booting the kernel.
Linux version 2.6.32.2 (root@ubuntu) (gcc version 4.4.3 (ctng-1.6.1) ) #16 Tue Mar 31 07:44:14 PDT 2015
Machine: MINI2440
Kernel command line: noinitrd init=/linuxrc mem=64m root=/dev/nfs rw nfsroot=192.168.1.24://NFSboot/rootfs ip=192.168.1.70:192.168.1.24:192.168.1.1:255.255.255.0::eth0:off console=ttySAC0
NR_IRQS:85
irq: clearing subpending status 00000007
TCP reno registered
brd: module loaded
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
eth0: dm9000e at c486e300,c4872304 IRQ 51 MAC: 08:00:3e:26:0a:5b (chip)
ALSA device list:
eth0: link down
IP-Config: Complete:
     device=eth0, addr=192.168.1.70, mask=255.255.255.0, gw=192.168.1.1,
     host=192.168.1.70, domain=, nis-domain=(none),
     bootserver=192.168.1.24, rootserver=192.168.1.24, rootpath=
eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
Looking up port of RPC 100005/1 on 192.168.1.24
VFS: Mounted root (nfs filesystem) on device 0:14.
Freeing init memory: 160K
----------munt all----------------
****************Studying ARM*********************
Kernel version:linux-2.6.32.2
Dream:D_xin
Date:2015.3
