make user_lib/romfs/image经常错误
2979|0
 楼主| xuysh 发表于 2007-6-16 00:09 | 显示全部楼层 |阅读模式
[root@localhost&nbsp;uClinux-dist]#&nbsp;make&nbsp;user_only<br />.........................<br />make[3]:&nbsp;***&nbsp;[boa]&nbsp;Error&nbsp;1<br />make[3]:&nbsp;Leaving&nbsp;directory&nbsp;`/usr/local/bin/uClinux-dist/user/boa/src'<br />make[2]:&nbsp;***&nbsp;[all]&nbsp;Error&nbsp;2<br />make[2]:&nbsp;Leaving&nbsp;directory&nbsp;`/usr/local/bin/uClinux-dist/user/boa'<br />make[1]:&nbsp;***&nbsp;[all]&nbsp;Error&nbsp;2<br />make[1]:&nbsp;Leaving&nbsp;directory&nbsp;`/usr/local/bin/uClinux-dist/user'<br />make:&nbsp;***&nbsp;[user_only]&nbsp;Error&nbsp;2<br />[root@localhost&nbsp;uClinux-dist]#make&nbsp;imafs<br />cp&nbsp;busybox&nbsp;/usr/local/bin/uClinux-dist/romfs/bin/busybox<br />cp:&nbsp;stat‘busybox’失败:&nbsp;没有那个文件或目录<br />make[2]:&nbsp;***&nbsp;[romfs]&nbsp;Error&nbsp;1<br />make[2]:&nbsp;Leaving&nbsp;directory&nbsp;`/usr/local/bin/uClinux-dist/user/busybox'<br />make[1]:&nbsp;***&nbsp;[romfs]&nbsp;Error&nbsp;2<br />make[1]:&nbsp;Leaving&nbsp;directory&nbsp;`/usr/local/bin/uClinux-dist/user'<br />make:&nbsp;***&nbsp;[romfs]&nbsp;Error&nbsp;1<br />[root@localhost&nbsp;uClinux-dist]#<br /><br />请问大虾们是什么问题??<br />谢谢!<br /><br />我现在是在linux发的贴子<br />
