[技术问题解答]
i.MX6solo板子linux下面网卡驱动FEC0工作不正常。
1299|1
eskytan|  楼主 | 2015-4-2 11:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-02 01:21:34 UTC (91294)
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
PHY: 1:01 - Link is Up - 100/Full
Sending DHCP requests .
Unable to handle kernel paging request at virtual address ffe00002
pgd = 80004000
[ffe00002] *pgd=27ffe821, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT
Modules linked in:
CPU: 0    Not tainted  (3.0.101-2790-gc248ed7 #25)
PC is at fec_enet_start_xmit+0x14c/0x2e4
LR is at l2x0_cache_sync+0x30/0x54
pc : [<803195c4>]    lr : [<80046f58>]    psr: 20000093
sp : 8bc9fe28  ip : a0000000  fp : 00000001
r10: 80a90cd0  r9 : 00009c00  r8 : 1bfd7000
r7 : ffdffc00  r6 : 80000013  r5 : 920679c0  r4 : 8bc84000
r3 : ffe00000  r2 : 00000005  r1 : 1bfd7800  r0 : 00000202
Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 10004059  DAC: 00000015
Process swapper (pid: 1, stack limit = 0x8bc9e2e8)
Stack: (0x8bc9fe28 to 0x8bca0000)
但在uboot下面FEC0是工作正常的,这说明硬件没有问题。
iMalody| | 2015-6-30 11:39 | 只看该作者
我也遇到楼主一样的问题,linux3.0.101,u-boot网卡驱动正常,kernel里面crash掉,导致nfs也无法启动。
请问楼主解决没?
