啥情况啊,AIC23没有声音信号输出咋回事?
1401|4
 楼主| lishong 发表于 2015-4-2 12:59 | 显示全部楼层 |阅读模式
用的是例程:
/*McBSP set,we use mcbsp1 to send and recieve the data between DSP and AIC23*/
MCBSP_Config Mcbsp1Config = {
  MCBSP_SPCR1_RMK(
    MCBSP_SPCR1_DLB_OFF,                   /* DLB    = 0,禁止自闭环方式 */
    MCBSP_SPCR1_RJUST_LZF,                 /* RJUST  = 2 */
    MCBSP_SPCR1_CLKSTP_DISABLE,            /* CLKSTP = 0 */
    MCBSP_SPCR1_DXENA_ON,                  /* DXENA  = 1 */
    MCBSP_SPCR1_ABIS_DISABLE,              /* ABIS   = 0 */
    MCBSP_SPCR1_RINTM_RRDY,                /* RINTM  = 0 */
    0,                                     /* RSYNCER = 0 */
    0,                                     /* RFULL = 0 N/A */
    0,                                     /* RRDY = 0 N/A */
    MCBSP_SPCR1_RRST_DISABLE               /* RRST   = 0 */
    MCBSP_SPCR2_RMK(
    MCBSP_SPCR2_FREE_NO,                   /* FREE   = 0 */
    MCBSP_SPCR2_SOFT_NO,                   /* SOFT   = 0 */
    MCBSP_SPCR2_FRST_FSG,                  /* FRST   = 0 */
    MCBSP_SPCR2_GRST_CLKG,                 /* GRST   = 0 */
    MCBSP_SPCR2_XINTM_XRDY,                /* XINTM  = 0 */
    0,                                     /* XSYNCER = N/A */
    0,                                     /* XEMPTY = N/A */
    0,                                     /* XRDY   = N/A */
    MCBSP_SPCR2_XRST_DISABLE               /* XRST   = 0 */
   /*单数据相,接受数据长度为16位,每相2个数据*/
  MCBSP_RCR1_RMK(
          MCBSP_RCR1_RFRLEN1_OF(1),              /* RFRLEN1 = 1 */
          MCBSP_RCR1_RWDLEN1_16BIT               /* RWDLEN1 = 2 */
  MCBSP_RCR2_RMK(
    MCBSP_RCR2_RPHASE_SINGLE,              /* RPHASE  = 0 */
    MCBSP_RCR2_RFRLEN2_OF(0),              /* RFRLEN2 = 0 */
    MCBSP_RCR2_RWDLEN2_8BIT,               /* RWDLEN2 = 0 */
    MCBSP_RCR2_RCOMPAND_MSB,               /* RCOMPAND = 0 */
    MCBSP_RCR2_RFIG_YES,                   /* RFIG    = 0 */
    MCBSP_RCR2_RDATDLY_1BIT                /* RDATDLY = 1 */
   MCBSP_XCR1_RMK(
    MCBSP_XCR1_XFRLEN1_OF(1),              /* XFRLEN1 = 1 */
    MCBSP_XCR1_XWDLEN1_16BIT               /* XWDLEN1 = 2 */
MCBSP_XCR2_RMK(
    MCBSP_XCR2_XPHASE_SINGLE,              /* XPHASE  = 0 */
    MCBSP_XCR2_XFRLEN2_OF(0),              /* XFRLEN2 = 0 */
    MCBSP_XCR2_XWDLEN2_8BIT,               /* XWDLEN2 = 0 */
    MCBSP_XCR2_XCOMPAND_MSB,               /* XCOMPAND = 0 */
    MCBSP_XCR2_XFIG_YES,                   /* XFIG    = 0 */
    MCBSP_XCR2_XDATDLY_1BIT                /* XDATDLY = 1 */
MCBSP_SRGR1_DEFAULT,
MCBSP_SRGR2_DEFAULT,
MCBSP_MCR1_DEFAULT,
MCBSP_MCR2_DEFAULT,
MCBSP_PCR_RMK(
   MCBSP_PCR_IDLEEN_RESET,                 /* IDLEEN   = 0   */
   MCBSP_PCR_XIOEN_SP,                     /* XIOEN    = 0   */
   MCBSP_PCR_RIOEN_SP,                     /* RIOEN    = 0   */
   MCBSP_PCR_FSXM_EXTERNAL,                /* FSXM     = 0   */
   MCBSP_PCR_FSRM_EXTERNAL,                /* FSRM     = 0   */
   MCBSP_PCR_SCLKME_NO,                    /* SCLKME   = 0   */
   0,                                      /* CLKSSTAT = N/A */
   0,                                      /* DXSTAT = N/A   */
   0,                                      /* DRSTAT = N/A   */
   MCBSP_PCR_CLKXM_INPUT,                  /* CLKXM    = 0   */
   MCBSP_PCR_CLKRM_INPUT,                  /* CLKRM    = 0   */
   MCBSP_PCR_FSXP_ACTIVEHIGH,              /* FSXP     = 0   */
   MCBSP_PCR_FSRP_ACTIVELOW,               /* FSRP     = 1   */
   MCBSP_PCR_CLKXP_FALLING,                /* CLKXP    = 1   */
   MCBSP_PCR_CLKRP_RISING                  /* CLKRP    = 1   */
MCBSP_RCERA_DEFAULT,
MCBSP_RCERB_DEFAULT,
MCBSP_RCERC_DEFAULT,
MCBSP_RCERD_DEFAULT,
MCBSP_RCERE_DEFAULT,
MCBSP_RCERF_DEFAULT,
MCBSP_RCERG_DEFAULT,
MCBSP_RCERH_DEFAULT,
MCBSP_XCERA_DEFAULT,
MCBSP_XCERB_DEFAULT,
MCBSP_XCERC_DEFAULT,
MCBSP_XCERD_DEFAULT,
MCBSP_XCERE_DEFAULT,
MCBSP_XCERF_DEFAULT,
MCBSP_XCERG_DEFAULT,
MCBSP_XCERH_DEFAULT
/*数字音频接口格式设置
AIC23为主模式,数据为DSP模式,数据长度16位*/
Uint16 digital_audio_inteface_format[2]={0x0e,0x53};
/*AIC23的波特率设置,采样率为44.1K*/
Uint16 sample_rate_control[2] = {0x10,0x23};
/*AIC23寄存器复位*/
Uint16 reset[2] ={0x1e,0x00};
/*AIC23节电方式设置,所有部分均所与工作状态*/
Uint16 power_down_control[2] ={0x0c,0x00};
/*AIC23模拟音频的控制
DAC使能,ADC输入选择为Line*/
Uint16 analog_aduio_path_control[2] ={0x08,0x10};
/*AIC23数字音频通路的控制*/
Uint16 digital_audio_path_control[2] ={0x0a,0x01};
/*AIC23数字接口的使能*/
Uint16 digital_interface_activation[2] ={0x12,0x01};
/*AIC23左通路音频调节*/
Uint16 left_line_input_volume_control[2] ={0x01,0x1f};
/*AIC23右通路音频调节*/
Uint16 right_line_input_volume_control[2] ={0x3,0x1f};
/*AIC23耳机左通路音频调节*/
Uint16 left_headphone_volume_control[2] ={0x05,0xFF};
/*AIC23耳机右通路音频调节*/
Uint16 right_headphone_volume_control[2] = {0x07,0xFF};
void main(void)
        int count;
    Uint16 aic23data = 0;
    /* Initialize CSL library - This is REQUIRED !!! */
    /*初始化CSL库*/
    CSL_init();
        /*设置系统的运行速度为144MHz*/
    PLL_config(&myConfig);
    /* Initialize I2C, using parameters in init structure */
    /*初始化I2C的格式*/
        I2C_RSET(I2CMDR,0);
        I2C_RSET(I2CPSC,0xb);
        I2C_RSET(I2CMDR,0x4620);
        I2C_RSET(I2CCLKL,55);
        I2C_RSET(I2CCLKH,55);
        myI2C_setup(&iicInit);
        /*初始化McBSP1*/
        hMcbsp = MCBSP_open(MCBSP_PORT1,MCBSP_OPEN_RESET);
        /*设置McBSP1*/
        MCBSP_config(hMcbsp,&Mcbsp1Config);
        /*启动McBSP1*/
        MCBSP_start(hMcbsp,
                MCBSP_RCV_START | MCBSP_XMIT_START,
                0);
    /*设置AIC23各部分均工作*/
    count = I2C_write( power_down_control,//pointer to data array
                       2,                                //length of data to be transmitted
                       1,                                //master or slaver
                       CODEC_ADDR,            //slave address to transmit to
                       1,                                //transfer mode of operation
                       30000                        //time out for bus busy
        /*设置AIC23的数字接口*/
        count = I2C_write( digital_audio_inteface_format,//pointer to data array
         /*设置AIC23模拟通路*/
        count = I2C_write( analog_aduio_path_control,//pointer to data array
        /*设置数字通路*/
        count = I2C_write( digital_audio_path_control,//pointer to data array
        /*设置AIC23的采样率*/
        count = I2C_write( sample_rate_control,//pointer to data array
        /*设置耳机音量*/
        count = I2C_write( right_headphone_volume_control,//pointer to data array
        /*设置Line输入的音量*/
        count = I2C_write( right_line_input_volume_control,//pointer to data array
        /*启动AIC23*/
        count = I2C_write( digital_interface_activation,//pointer to data array
        /*回放音频*/
        while(TRUE)
                while(!MCBSP_rrdy(hMcbsp)){};
                aic23data = MCBSP_read16(hMcbsp);
                MCBSP_write16(hMcbsp,aic23data);
单步运行确认IIC操作是没问题的,全速运行后,测量AIC23的mic输入脚,有语音输入的时候用示波器检测是有信号的。但为什么LHPOUT或RHPOUT没输出呢?试过左右声道都一样在示波器检测的时候没音频交流信号输出。
 楼主| lishong 发表于 2015-4-2 13:14 | 显示全部楼层
aic23data= 0xff;
        /*回放音频*/
        while(TRUE)
                //while(!MCBSP_rrdy(hMcbsp)){};
                //aic23data = MCBSP_read16(hMcbsp);
                if(aic23data > 0)
                        aic23data--;
                else
                        aic23data= 0xff;
直接这么写都没有声音输出,mcbsp配置音频接口有问题?
 楼主| lishong 发表于 2015-4-2 14:43 | 显示全部楼层
应该是mcbsp的问题,加入读状态寄存器就看出来了:
while(TRUE)
                if(aic23data > 0)
                        aic23data--;
                else
                        aic23data = 0xff;
                while(!MCBSP_xrdy(hMcbsp)){};
发送一次数据后,会一直停在while(!MCBSP_xrdy(hMcbsp)){};这里,也就是说一直不能再发了。奇怪的了。
 楼主| lishong 发表于 2015-4-2 15:55 | 显示全部楼层
晕死,clkx1与clkr1没连接好 ,虚焊了
zhangmangui 发表于 2015-4-29 22:52 | 显示全部楼层
这种问题  确实很难找
