arm9 s3c2410开发板的启动信息
2903|0
 楼主| lgclgc 发表于 2007-5-27 20:49 | 显示全部楼层 |阅读模式
启动时提示有Bad&nbsp;eraseblock是说nand&nbsp;falsh有坏块么???<br />我是刚买的新板子阿,这个是什么原因造成的?影响使用么?<br />还有<br />mount:&nbsp;Mounting&nbsp;tmpfs&nbsp;on&nbsp;/dev/shm&nbsp;failed:&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory<br />yaffs:&nbsp;Attempting&nbsp;MTD&nbsp;mount&nbsp;on&nbsp;31.2,&nbsp;&quot;(unavailable)&quot;<br />说明什么问题?<br />启动后可以进入控制台<br />但是mkdir时&nbsp;却说cannot&nbsp;alloc&nbsp;memory是怎么回事??<br /><br />我是新手,多多指教!!<br /><br /><br /><br /><br /><br /><br />以下是完整启动信息<br />VIVI&nbsp;version&nbsp;0.1.4&nbsp;(root@localhost.localdomain)&nbsp;(gcc&nbsp;version&nbsp;2.95.3&nbsp;20010315&nbsp;(release))&nbsp;#0.1.4&nbsp;Wed&nbsp;Sep&nbsp;13&nbsp;21:06:12&nbsp;EDT&nbsp;2006<br />MMU&nbsp;table&nbsp;base&nbsp;address&nbsp;=&nbsp;0x33FBC000<br />Succeed&nbsp;memory&nbsp;mapping.<br />+---------------------------------------------+<br />|&nbsp;&nbsp;YC2410&nbsp;&nbsp;USB&nbsp;Downloader&nbsp;ver&nbsp;R2.00&nbsp;&nbsp;06-12-08&nbsp;|<br />+---------------------------------------------+<br />FCLK=200MHz,DMA&nbsp;mode<br />USB:&nbsp;IN_ENDPOINT:1&nbsp;OUT_ENDPOINT:3<br />FORMAT:&nbsp;&ltADDR(DATA):4&gt+&ltSIZE(n+10):4&gt+&ltDATA:n&gt+&ltCS:2&gt<br />NAND&nbsp;device:&nbsp;Manufacture&nbsp;ID:&nbsp;0xec,&nbsp;Chip&nbsp;ID:&nbsp;0x76&nbsp;(Samsung&nbsp;K9D1208V0M)<br />Found&nbsp;saved&nbsp;vivi&nbsp;parameters.<br />Press&nbsp;Return&nbsp;to&nbsp;start&nbsp;the&nbsp;LINUX/Wince&nbsp;now,&nbsp;any&nbsp;other&nbsp;key&nbsp;for&nbsp;vivi<br />Copy&nbsp;linux&nbsp;kernel&nbsp;from&nbsp;0x00050000&nbsp;to&nbsp;0x30008000,&nbsp;size&nbsp;=&nbsp;0x00200000&nbsp;...&nbsp;done<br />zImage&nbsp;magic&nbsp;=&nbsp;0x016f2818<br />Setup&nbsp;linux&nbsp;parameters&nbsp;at&nbsp;0x30000100<br />linux&nbsp;command&nbsp;line&nbsp;is:&nbsp;&quot;noinitrd&nbsp;root=/dev/mtdblock/2&nbsp;console=ttySAC0&quot;<br />MACH_TYPE&nbsp;=&nbsp;193<br />NOW,&nbsp;Booting&nbsp;Linux......<br />Uncompressing&nbsp;Linux............................................................................................&nbsp;done,&nbsp;booting&nbsp;the&nbsp;kernel.<br />Linux&nbsp;version&nbsp;2.6.11.1-bit.lili&nbsp;(azure@azure)&nbsp;(gcc&nbsp;version&nbsp;3.4.1)&nbsp;#236&nbsp;Sat&nbsp;Dec&nbsp;23&nbsp;00:34:14&nbsp;CST&nbsp;2006<br /><br />CPU:&nbsp;ARM920Tid(wb)&nbsp;[41129200]&nbsp;revision&nbsp;0&nbsp;(ARMv4T)<br /><br />CPU0:&nbsp;D&nbsp;VIVT&nbsp;write-back&nbsp;cache<br /><br />CPU0:&nbsp;I&nbsp;cache:&nbsp;16384&nbsp;bytes,&nbsp;associativity&nbsp;64,&nbsp;32&nbsp;byte&nbsp;lines,&nbsp;8&nbsp;sets<br /><br />CPU0:&nbsp;D&nbsp;cache:&nbsp;16384&nbsp;bytes,&nbsp;associativity&nbsp;64,&nbsp;32&nbsp;byte&nbsp;lines,&nbsp;8&nbsp;sets<br /><br />Machine:&nbsp;SMDK2410<br /><br />ATAG_INITRD&nbsp;is&nbsp;deprecated;&nbsp;please&nbsp;update&nbsp;your&nbsp;bootloader.<br /><br />Memory&nbsp;policy:&nbsp;ECC&nbsp;disabled,&nbsp;Data&nbsp;cache&nbsp;writeback<br /><br />CPU&nbsp;S3C2410A&nbsp;(id&nbsp;0x32410002)<br /><br />S3C2410:&nbsp;core&nbsp;200.000&nbsp;MHz,&nbsp;memory&nbsp;100.000&nbsp;MHz,&nbsp;peripheral&nbsp;50.000&nbsp;MHz<br /><br />S3C2410&nbsp;Clocks,&nbsp;(c)&nbsp;2004&nbsp;Simtec&nbsp;Electronics<br /><br />Built&nbsp;1&nbsp;zonelists<br /><br />Kernel&nbsp;command&nbsp;line:&nbsp;noinitrd&nbsp;root=/dev/mtdblock/2&nbsp;console=ttySAC0<br /><br />irq:&nbsp;clearing&nbsp;subpending&nbsp;status&nbsp;00000002<br /><br />PID&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;512&nbsp;(order:&nbsp;9,&nbsp;8192&nbsp;bytes)<br /><br />S3C2410&nbsp;TIMER,&nbsp;(c)&nbsp;2003-2005&nbsp;Simtec&nbsp;Electronics<br /><br />timer&nbsp;tcon=00000000,&nbsp;tcnt&nbsp;a2c1,&nbsp;tcfg&nbsp;00000200,00000000,&nbsp;usec&nbsp;00001eb8<br /><br />Console:&nbsp;colour&nbsp;dummy&nbsp;device&nbsp;80x30<br /><br />Dentry&nbsp;cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;16384&nbsp;(order:&nbsp;4,&nbsp;65536&nbsp;bytes)<br /><br />Inode-cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;8192&nbsp;(order:&nbsp;3,&nbsp;32768&nbsp;bytes)<br /><br />Memory:&nbsp;64MB&nbsp;=&nbsp;64MB&nbsp;total<br /><br />Memory:&nbsp;61840KB&nbsp;available&nbsp;(2198K&nbsp;code,&nbsp;566K&nbsp;data,&nbsp;176K&nbsp;init)<br /><br />Mount-cache&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;512<br /><br />CPU:&nbsp;Testing&nbsp;write&nbsp;buffer&nbsp;coherency:&nbsp;ok<br /><br />NET:&nbsp;Registered&nbsp;protocol&nbsp;family&nbsp;16<br /><br />S3C2410:&nbsp;Initialising&nbsp;architecture<br /><br />SCSI&nbsp;subsystem&nbsp;initialized<br /><br />usbcore:&nbsp;registered&nbsp;new&nbsp;driver&nbsp;usbfs<br /><br />usbcore:&nbsp;registered&nbsp;new&nbsp;driver&nbsp;hub<br /><br />S3C2410&nbsp;DMA&nbsp;Driver,&nbsp;(c)&nbsp;2003-2004&nbsp;Simtec&nbsp;Electronics<br /><br />DMA&nbsp;channel&nbsp;0&nbsp;at&nbsp;c4800000,&nbsp;irq&nbsp;33<br /><br />DMA&nbsp;channel&nbsp;1&nbsp;at&nbsp;c4800040,&nbsp;irq&nbsp;34<br /><br />DMA&nbsp;channel&nbsp;2&nbsp;at&nbsp;c4800080,&nbsp;irq&nbsp;35<br /><br />DMA&nbsp;channel&nbsp;3&nbsp;at&nbsp;c48000c0,&nbsp;irq&nbsp;36<br /><br />NetWinder&nbsp;Floating&nbsp;Point&nbsp;Emulator&nbsp;V0.97&nbsp;(double&nbsp;precision)<br /><br />devfs:&nbsp;2004-01-31&nbsp;Richard&nbsp;Gooch&nbsp;(rgooch@atnf.csiro.au)<br /><br />devfs:&nbsp;devfs_debug:&nbsp;0x0<br /><br />devfs:&nbsp;boot_options:&nbsp;0x1<br /><br />Console:&nbsp;switching&nbsp;to&nbsp;colour&nbsp;frame&nbsp;buffer&nbsp;device&nbsp;40x30<br /><br />fb0:&nbsp;S3C2410&nbsp;frame&nbsp;buffer&nbsp;device<br /><br />S3C2410&nbsp;RTC,&nbsp;(c)&nbsp;2004&nbsp;Simtec&nbsp;Electronics<br /><br />s3c2410-rtc&nbsp;s3c2410-rtc:&nbsp;rtc&nbsp;disabled,&nbsp;re-enabling<br /><br />S3C2410&nbsp;Watchdog&nbsp;Timer,&nbsp;(c)&nbsp;2004&nbsp;Simtec&nbsp;Electronics<br /><br />s3c2410_serial0&nbsp;at&nbsp;MMIO&nbsp;0x50000000&nbsp;(irq&nbsp;=&nbsp;70)&nbsp;is&nbsp;a&nbsp;S3C2410<br /><br />s3c2410_serial1&nbsp;at&nbsp;MMIO&nbsp;0x50004000&nbsp;(irq&nbsp;=&nbsp;73)&nbsp;is&nbsp;a&nbsp;S3C2410<br /><br />s3c2410_serial2&nbsp;at&nbsp;MMIO&nbsp;0x50008000&nbsp;(irq&nbsp;=&nbsp;76)&nbsp;is&nbsp;a&nbsp;S3C2410<br /><br />io&nbsp;scheduler&nbsp;noop&nbsp;registered<br /><br />io&nbsp;scheduler&nbsp;anticipatory&nbsp;registered<br /><br />io&nbsp;scheduler&nbsp;deadline&nbsp;registered<br /><br />io&nbsp;scheduler&nbsp;cfq&nbsp;registered<br /><br />RAMDISK&nbsp;driver&nbsp;initialized:&nbsp;16&nbsp;RAM&nbsp;disks&nbsp;of&nbsp;4096K&nbsp;size&nbsp;1024&nbsp;blocksize<br /><br />Cirrus&nbsp;Logic&nbsp;CS8900A&nbsp;driver&nbsp;for&nbsp;Linux&nbsp;(Modified&nbsp;for&nbsp;SMDK2410)<br /><br />eth0:&nbsp;CS8900A&nbsp;rev&nbsp;E&nbsp;at&nbsp;0xe0000300&nbsp;irq=53,&nbsp;no&nbsp;eeprom&nbsp;,&nbsp;addr:&nbsp;08:&nbsp;0:3E:26:0A:5B<br /><br />Linux&nbsp;video&nbsp;capture&nbsp;interface:&nbsp;v1.00<br /><br />ovcamchip:&nbsp;v2.27&nbsp;for&nbsp;Linux&nbsp;2.6&nbsp;:&nbsp;OV&nbsp;camera&nbsp;chip&nbsp;I2C&nbsp;driver<br /><br />Uniform&nbsp;Multi-Platform&nbsp;E-IDE&nbsp;driver&nbsp;Revision:&nbsp;7.00alpha2<br /><br />ide:&nbsp;Assuming&nbsp;50MHz&nbsp;system&nbsp;bus&nbsp;speed&nbsp;for&nbsp;PIO&nbsp;modes;&nbsp;override&nbsp;with&nbsp;idebus=xx<br /><br />S3C2410&nbsp;NAND&nbsp;Driver,&nbsp;(c)&nbsp;2004&nbsp;Simtec&nbsp;Electronics<br /><br />s3c2410-nand:&nbsp;mapped&nbsp;registers&nbsp;at&nbsp;c4a00000<br /><br />s3c2410-nand:&nbsp;timing:&nbsp;Tacls&nbsp;10ns,&nbsp;Twrph0&nbsp;40ns,&nbsp;Twrph1&nbsp;10ns<br /><br />NAND&nbsp;device:&nbsp;Manufacturer&nbsp;ID:&nbsp;0xec,&nbsp;Chip&nbsp;ID:&nbsp;0x76&nbsp;(Samsung&nbsp;NAND&nbsp;64MiB&nbsp;3,3V&nbsp;8-bit)<br /><br />Scanning&nbsp;device&nbsp;for&nbsp;bad&nbsp;blocks<br /><br />Bad&nbsp;eraseblock&nbsp;1978&nbsp;at&nbsp;0x01ee8000<br /><br />Bad&nbsp;eraseblock&nbsp;1982&nbsp;at&nbsp;0x01ef8000<br /><br />Bad&nbsp;eraseblock&nbsp;2050&nbsp;at&nbsp;0x02008000<br /><br />Creating&nbsp;3&nbsp;MTD&nbsp;partitions&nbsp;on&nbsp;&quot;NAND&nbsp;64MiB&nbsp;3,3V&nbsp;8-bit&quot;:<br /><br />0x00000000-0x00030000&nbsp;:&nbsp;&quot;bootloader&quot;<br /><br />mtd:&nbsp;Giving&nbsp;out&nbsp;device&nbsp;0&nbsp;to&nbsp;bootloader<br /><br />0x00030000-0x00230000&nbsp;:&nbsp;&quot;kernel&quot;<br /><br />mtd:&nbsp;Giving&nbsp;out&nbsp;device&nbsp;1&nbsp;to&nbsp;kernel<br /><br />0x00230000-0x03ffc000&nbsp;:&nbsp;&quot;root&quot;<br /><br />mtd:&nbsp;Giving&nbsp;out&nbsp;device&nbsp;2&nbsp;to&nbsp;root<br /><br />usbmon:&nbsp;debugs&nbsp;is&nbsp;not&nbsp;available<br /><br />usb&nbsp;usb1:&nbsp;Product:&nbsp;S3C24XX&nbsp;OHCI<br /><br />usb&nbsp;usb1:&nbsp;Manufacturer:&nbsp;Linux&nbsp;2.6.11.1-bit.lili&nbsp;ohci_hcd<br /><br />usb&nbsp;usb1:&nbsp;SerialNumber:&nbsp;s3c2410<br /><br />hub&nbsp;1-0:1.0:&nbsp;USB&nbsp;hub&nbsp;found<br /><br />hub&nbsp;1-0:1.0:&nbsp;2&nbsp;ports&nbsp;detected<br /><br />Initializing&nbsp;USB&nbsp;Mass&nbsp;Storage&nbsp;driver...<br /><br />usbcore:&nbsp;registered&nbsp;new&nbsp;driver&nbsp;usb-storage<br /><br />USB&nbsp;Mass&nbsp;Storage&nbsp;support&nbsp;registered.<br /><br />usbcore:&nbsp;registered&nbsp;new&nbsp;driver&nbsp;usbhid<br /><br />drivers/usb/input/hid-core.c:&nbsp;v2.01:USB&nbsp;HID&nbsp;core&nbsp;driver<br /><br />usbcore:&nbsp;registered&nbsp;new&nbsp;driver&nbsp;ov511<br /><br />drivers/usb/media/ov511.c:&nbsp;v1.64&nbsp;for&nbsp;Linux&nbsp;2.5&nbsp;:&nbsp;ov511&nbsp;USB&nbsp;Camera&nbsp;Driver<br /><br />usbcore:&nbsp;registered&nbsp;new&nbsp;driver&nbsp;spca5xx<br /><br />drivers/usb/media/spca5xx/spca_core.c:&nbsp;spca5xx&nbsp;driver&nbsp;00.57.06LE&nbsp;registered<br /><br />mice:&nbsp;PS/2&nbsp;mouse&nbsp;device&nbsp;common&nbsp;for&nbsp;all&nbsp;mice<br /><br />ts:&nbsp;Compaq&nbsp;touchscreen&nbsp;protocol&nbsp;output<br /><br />Initial&nbsp;YC2410&nbsp;Board&nbsp;Buttons&nbsp;driver!<br /><br />/dev/buttons&nbsp;has&nbsp;been&nbsp;added&nbsp;to&nbsp;your&nbsp;system.<br /><br />s3c2410&nbsp;TouchScreen&nbsp;successfully&nbsp;loaded<br /><br />i2c&nbsp;/dev&nbsp;entries&nbsp;driver<br /><br />s3c2410-i2c&nbsp;s3c2410-i2c:&nbsp;slave&nbsp;address&nbsp;0x10<br /><br />s3c2410-i2c&nbsp;s3c2410-i2c:&nbsp;bus&nbsp;frequency&nbsp;set&nbsp;to&nbsp;390&nbsp;KHz<br /><br />s3c2410-i2c&nbsp;s3c2410-i2c:&nbsp;i2c-0:&nbsp;S3C&nbsp;I2C&nbsp;adapter<br /><br />mmci-s3c2410:&nbsp;probe:&nbsp;mapped&nbsp;sdi_base=c4e80000&nbsp;irq=37&nbsp;irq_cd=62&nbsp;dma=0.<br /><br />mmci-s3c2410:&nbsp;initialisation&nbsp;done.<br /><br />UDA1341&nbsp;audio&nbsp;driver&nbsp;initialized<br /><br />NET:&nbsp;Registered&nbsp;protocol&nbsp;family&nbsp;2<br /><br />IP:&nbsp;routing&nbsp;cache&nbsp;hash&nbsp;table&nbsp;of&nbsp;512&nbsp;buckets,&nbsp;4Kbytes<br /><br />TCP&nbsp;established&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;4096&nbsp;(order:&nbsp;3,&nbsp;32768&nbsp;bytes)<br /><br />TCP&nbsp;bind&nbsp;hash&nbsp;table&nbsp;entries:&nbsp;4096&nbsp;(order:&nbsp;2,&nbsp;16384&nbsp;bytes)<br /><br />TCP:&nbsp;Hash&nbsp;tables&nbsp;configured&nbsp;(established&nbsp;4096&nbsp;bind&nbsp;4096)<br /><br />NET:&nbsp;Registered&nbsp;protocol&nbsp;family&nbsp;1<br /><br />MMC:&nbsp;sd_app_op_cond&nbsp;timed&nbsp;out.&nbsp;Probably&nbsp;no&nbsp;SD-Card&nbsp;here.<br /><br />Root-NFS:&nbsp;No&nbsp;NFS&nbsp;server&nbsp;available,&nbsp;giving&nbsp;up.<br /><br />VFS:&nbsp;Unable&nbsp;to&nbsp;mount&nbsp;root&nbsp;fs&nbsp;via&nbsp;NFS,&nbsp;trying&nbsp;floppy.<br /><br />*******<br /><br />VFS:&nbsp;test&nbsp;name&nbsp;=&nbsp;&lt/dev/root&gt&nbsp;<br /><br />VFS:&nbsp;fs_name&nbsp;=&nbsp;&ltyaffs&gt&nbsp;<br /><br />VFS:&nbsp;fs_name&nbsp;=&nbsp;&ltext2&gt&nbsp;<br /><br />VFS:&nbsp;fs_name&nbsp;=&nbsp;&ltmsdos&gt&nbsp;<br /><br />VFS:&nbsp;fs_name&nbsp;=&nbsp;&ltvfat&gt&nbsp;<br /><br />yaffs:&nbsp;Attempting&nbsp;MTD&nbsp;mount&nbsp;on&nbsp;31.2,&nbsp;&quot;(unavailable)&quot;<br /><br />VFS:&nbsp;Mounted&nbsp;root&nbsp;(yaffs&nbsp;filesystem).<br /><br />VFS:&nbsp;tried&nbsp;fs_name&nbsp;=&nbsp;&ltyaffs&gt&nbsp;err=&nbsp;0<br /><br />Mounted&nbsp;devfs&nbsp;on&nbsp;/dev<br /><br />Freeing&nbsp;init&nbsp;memory:&nbsp;176K<br /><br />[01/Jan/1970:00:00:08&nbsp;+0000]&nbsp;boa:&nbsp;server&nbsp;version&nbsp;Boa/0.94.13<br />[01/Jan/1970:00:00:08&nbsp;+0000]&nbsp;boa:&nbsp;server&nbsp;built&nbsp;Feb&nbsp;28&nbsp;2004&nbsp;at&nbsp;21:47:23.<br />[01/Jan/1970:00:00:08&nbsp;+0000]&nbsp;boa:&nbsp;starting&nbsp;server&nbsp;pid=763,&nbsp;port&nbsp;80<br />mount:&nbsp;Mounting&nbsp;tmpfs&nbsp;on&nbsp;/dev/shm&nbsp;failed:&nbsp;No&nbsp;such&nbsp;file&nbsp;or&nbsp;directory<br />/etc/pointercal&nbsp;not&nbsp;existed<br />QWSServerSocket:&nbsp;could&nbsp;not&nbsp;bind&nbsp;to&nbsp;file&nbsp;/tmp/qtembedded-unknown/QtEmbedded-0<br />Error:&nbsp;File&nbsp;exists<br />Failed&nbsp;to&nbsp;bind&nbsp;to&nbsp;/tmp/qtembedded-unknown/QtEmbedded-0<br />Aborted<br /><br />Please&nbsp;press&nbsp;Enter&nbsp;to&nbsp;activate&nbsp;this&nbsp;console.&nbsp;
