**,这是CPU吗!
5607|17
 楼主| pk.kong 发表于 2007-7-3 14:36 | 显示全部楼层 |阅读模式
http://cache.baidu.com/c?word=iphone%2Ccpu&url=http%3A//mobile%2Ezol%2Ecom%2Ecn/59/592030%2Ehtml&p=9e72c54ad49950e00fbe9b7c46&user=baidu
 楼主| pk.kong 发表于 2007-7-3 14:39 | 显示全部楼层
you ren yong ma ?
<br />General&nbsp;Description&nbsp;&nbsp;<br />&nbsp;<br />S3C6400&nbsp;is&nbsp;a&nbsp;32-bit&nbsp;RISC&nbsp;microprocessor,&nbsp;which&nbsp;is&nbsp;designed&nbsp;to&nbsp;provide&nbsp;a&nbsp;cost-effective,&nbsp;low&nbsp;power,&nbsp;high&nbsp;performance&nbsp;Application&nbsp;Processor&nbsp;solution&nbsp;for&nbsp;mobile&nbsp;phones&nbsp;and&nbsp;general&nbsp;applications.&nbsp;<br /><br />To&nbsp;provide&nbsp;optimized&nbsp;H/W&nbsp;performance&nbsp;for&nbsp;the&nbsp;2.5G&nbsp;&&nbsp;3G&nbsp;communication&nbsp;services,&nbsp;S3C6400&nbsp;adopts&nbsp;a&nbsp;64/32-bit&nbsp;internal&nbsp;bus&nbsp;architecture&nbsp;which&nbsp;is&nbsp;composed&nbsp;of&nbsp;AXI,&nbsp;AHB&nbsp;and&nbsp;APB&nbsp;buses,&nbsp;and&nbsp;includes&nbsp;many&nbsp;powerful&nbsp;hardware&nbsp;accelerators&nbsp;for&nbsp;tasks&nbsp;such&nbsp;as&nbsp;motion&nbsp;video&nbsp;processing,&nbsp;audio&nbsp;processing,&nbsp;2D&nbsp;graphics,&nbsp;display&nbsp;manipulation&nbsp;and&nbsp;scaling.&nbsp;An&nbsp;Integrated&nbsp;Multi&nbsp;Format&nbsp;Codec&nbsp;(MFC)&nbsp;supports&nbsp;encoding&nbsp;and&nbsp;decoding&nbsp;of&nbsp;MPEG4/H.263/H.264&nbsp;and&nbsp;decoding&nbsp;of&nbsp;VC1.&nbsp;This&nbsp;H/W&nbsp;Encoder/&nbsp;Decoder&nbsp;supports&nbsp;real-time&nbsp;video&nbsp;conferencing&nbsp;and&nbsp;TV&nbsp;signal&nbsp;output&nbsp;in&nbsp;NTSC&nbsp;and&nbsp;all&nbsp;PAL&nbsp;formats.<br /><br />The&nbsp;S3C6400&nbsp;has&nbsp;an&nbsp;optimized&nbsp;interface&nbsp;to&nbsp;external&nbsp;memory&nbsp;capable&nbsp;of&nbsp;sustaining&nbsp;the&nbsp;demanding&nbsp;memory&nbsp;bandwidths&nbsp;required&nbsp;in&nbsp;high-end&nbsp;communication&nbsp;services.&nbsp;The&nbsp;memory&nbsp;system&nbsp;has&nbsp;dual&nbsp;external&nbsp;memory&nbsp;ports:&nbsp;a&nbsp;DRAM&nbsp;and&nbsp;a&nbsp;Flash/ROM/DRAM&nbsp;port.&nbsp;The&nbsp;DRAM&nbsp;port&nbsp;can&nbsp;be&nbsp;configured&nbsp;to&nbsp;support&nbsp;mobile&nbsp;DDR,&nbsp;DDR,&nbsp;mobile&nbsp;SDRAM&nbsp;and&nbsp;standard&nbsp;SDRAM.&nbsp;<br /><br />The&nbsp;Flash/ROM/DRAM&nbsp;Port&nbsp;supports&nbsp;SLC/MLC&nbsp;type&nbsp;NAND&nbsp;Flash&nbsp;both,&nbsp;NOR-Flash,&nbsp;OneNAND,&nbsp;CF&nbsp;and&nbsp;ROM&nbsp;type&nbsp;external&nbsp;memory&nbsp;and&nbsp;mobile&nbsp;DDR,&nbsp;DDR,&nbsp;mobile&nbsp;SDRAM&nbsp;and&nbsp;SDRAM&nbsp;<br /><br />To&nbsp;reduce&nbsp;total&nbsp;system&nbsp;cost&nbsp;and&nbsp;enhance&nbsp;overall&nbsp;functionality,&nbsp;S3C6400&nbsp;includes&nbsp;many&nbsp;hardware&nbsp;peripherals&nbsp;such&nbsp;as&nbsp;camera&nbsp;interface,&nbsp;TFT&nbsp;24-bit&nbsp;true&nbsp;color&nbsp;LCD&nbsp;controller,&nbsp;System&nbsp;Manager(&nbsp;power&nbsp;management&nbsp;&&nbsp;etc.),&nbsp;4-channel&nbsp;UART,&nbsp;32-channel&nbsp;DMA,&nbsp;4-channel&nbsp;Timers,&nbsp;General&nbsp;I/O&nbsp;Ports,&nbsp;I2S-Bus&nbsp;Interface,&nbsp;I2C-BUS&nbsp;interface,&nbsp;USB&nbsp;Host,&nbsp;USB&nbsp;OTG&nbsp;operating&nbsp;at&nbsp;high&nbsp;speed(480Mbps),&nbsp;SD&nbsp;Host&nbsp;&&nbsp;High&nbsp;Speed&nbsp;Multi-Media&nbsp;Card&nbsp;Interface&nbsp;and&nbsp;PLLs&nbsp;for&nbsp;clock&nbsp;generation.<br /><br />POP&nbsp;(Package&nbsp;on&nbsp;Package)&nbsp;option&nbsp;with&nbsp;MCP&nbsp;is&nbsp;available&nbsp;for&nbsp;small&nbsp;form&nbsp;factor&nbsp;applications.<br />&nbsp;<br />&nbsp;<br /><br />Features&nbsp;&nbsp;<br />&nbsp;<br />ARM1176JZF-S&nbsp;based&nbsp;CPU&nbsp;Subsystem&nbsp;with&nbsp;Java&nbsp;acceleration&nbsp;Engine<br />16/16KB&nbsp;I/D&nbsp;Cache,&nbsp;16/16KB&nbsp;I/D&nbsp;TCM<br />533/667MHz&nbsp;Operating&nbsp;Frequency&nbsp;<br />One&nbsp;8-bit&nbsp;ITU&nbsp;601/656&nbsp;Camera&nbsp;Interface&nbsp;of&nbsp;up&nbsp;to&nbsp;4M&nbsp;pixel&nbsp;for&nbsp;scaled&nbsp;and&nbsp;16M&nbsp;pixel&nbsp;for&nbsp;un-scaled&nbsp;resolution<br />Multi&nbsp;Format&nbsp;CODEC&nbsp;(MFC)&nbsp;provides&nbsp;encoding&nbsp;and&nbsp;decoding&nbsp;of&nbsp;MPEG-4/H.263/H.264&nbsp;up&nbsp;to&nbsp;30fps@SD,&nbsp;and&nbsp;decoding&nbsp;of&nbsp;VC1&nbsp;video&nbsp;up&nbsp;to&nbsp;30fps@SD<br />2D&nbsp;Graphics&nbsp;Acceleration&nbsp;with&nbsp;BitBlt&nbsp;and&nbsp;Rotation&nbsp;<br />AC-97&nbsp;audio&nbsp;codec&nbsp;interface&nbsp;and&nbsp;PCM&nbsp;serial&nbsp;audio&nbsp;interface&nbsp;<br />1/2/4/8&nbsp;bpp&nbsp;Palletized&nbsp;or&nbsp;16/24bpp&nbsp;Non-Palletized&nbsp;Color-TFT&nbsp;support&nbsp;up&nbsp;to&nbsp;1024x1024&nbsp;<br />I2S,&nbsp;I2C&nbsp;interface&nbsp;support&nbsp;<br />Dedicated&nbsp;IrDA&nbsp;port&nbsp;for&nbsp;FIR,&nbsp;MIR&nbsp;and&nbsp;SIR&nbsp;<br />Flexibly&nbsp;configurable&nbsp;GPIOs&nbsp;<br />1-port&nbsp;USB&nbsp;OTG&nbsp;2.0&nbsp;supporting&nbsp;high&nbsp;speed(480Mbps,&nbsp;on-chip&nbsp;transceiver)<br />1-port&nbsp;USB&nbsp;1.1&nbsp;Host&nbsp;supporting&nbsp;full&nbsp;speed(12Mbps,&nbsp;on-chip&nbsp;transceiver)<br />High&nbsp;Speed-MMC/SD&nbsp;card&nbsp;support<br />Real&nbsp;time&nbsp;clock,&nbsp;PLL,&nbsp;timer&nbsp;with&nbsp;PWM&nbsp;and&nbsp;watch&nbsp;dog&nbsp;timer&nbsp;<br />32&nbsp;channel&nbsp;DMA&nbsp;controller<br />Support&nbsp;8X8&nbsp;key&nbsp;matrix<br />Advanced&nbsp;power&nbsp;management&nbsp;for&nbsp;mobile&nbsp;applications<br />Memory&nbsp;Subsystem<br />-&nbsp;SRAM/ROM/NOR/NAND(SLC/MLC)&nbsp;Interface&nbsp;with&nbsp;x8&nbsp;or&nbsp;x16&nbsp;data&nbsp;bus<br />-&nbsp;Muxed&nbsp;OneNAND&nbsp;Interface&nbsp;with&nbsp;x16&nbsp;data&nbsp;bus<br />-&nbsp;SDRAM&nbsp;/&nbsp;Mobile&nbsp;SDRAM&nbsp;Interface&nbsp;with&nbsp;x16&nbsp;or&nbsp;x32&nbsp;data&nbsp;bus&nbsp;(133Mbps/pin&nbsp;rate)<br />-&nbsp;Mobile&nbsp;DDR&nbsp;Interface&nbsp;with&nbsp;x16&nbsp;or&nbsp;x32&nbsp;data&nbsp;bus&nbsp;(266Mbps/pin&nbsp;DDR)<br />&nbsp;<br /><br />
multiice 发表于 2007-7-3 14:41 | 显示全部楼层
呵呵
原来说是xscale,不过后来Intel否认是采用intel的CPU。当然这个也没有什么,因为xscale已经出售给Marvell,但是没有想到是samsung的。<br /><br />Samsung的CPU性价比确实无敌,在数码消费品中有绝对的优势。
平常人 发表于 2007-7-3 20:39 | 显示全部楼层
听说iPhone的耗电不小
<br />~~~~~~为什么???????<br /><br />这里有篇**,第7、8点是关于功耗的:<br /><a href="http://it.sohu.com/20070627/n250782928.shtml" target=_blank>http://it.sohu.com/20070627/n250782928.shtml</a>
high 发表于 2007-7-3 21:05 | 显示全部楼层
我咋听说挺省电滴
什么连续听music24小时,通话8小时?(6小时?)<br /><br />也一直以为是xscale的
yddoo 发表于 2007-7-3 21:29 | 显示全部楼层
**,这是CPU吗!
这什么都有啊,就是一个全啊,还有好几个名词还看不懂呢!<br /><br />看来手机就快可以当电脑用了.<br /><br />错了,当主机.
drentsi 发表于 2007-7-4 09:34 | 显示全部楼层
要是能用在工业现场就好了
期待ing
weixiao11 发表于 2007-7-4 11:00 | 显示全部楼层
人家是做消费品的,估计不会考虑工业现场
utulinux 发表于 2007-7-4 11:47 | 显示全部楼层
6400的cpu看的很不错。
6400的cpu看的很不错,以后高端的PDA等产品要替换原来intel的270了。
iversonma 发表于 2007-7-4 13:39 | 显示全部楼层
nokia的n95用的是arm11加dsp核
是ti的omap2系列,从技术角度看要比iphone高多了~<br />当然也比samsung的利害<br /><br />而且现在omap3系列的是arm新一代的cotex-a8系列加6000dsp核,估计nokia的下一代手机就用上了<br /><br />另外高通高端的cdma手机也早已用到arm11core了。<br />
utulinux 发表于 2007-7-9 17:53 | 显示全部楼层
据说iphone上市1周卖了60万个了。
xplore 发表于 2007-7-9 18:31 | 显示全部楼层
8小时通话时间
很不错了, 比大部分智能手机强。<br /><br />不过,不能换电池,Apple的设计人员太狂妄了。或者设计是n年前已经定型了,那时候许多手机不能换电池。<br /><br />BS一下, 这个iPhone,&nbsp;我见一次就BS它一下。
zbo007mm 发表于 2007-7-10 22:04 | 显示全部楼层
我也跟着大家BS一下
我也跟着大家BS一下,因为我买不起~~
hqGBoY 发表于 2007-7-11 08:13 | 显示全部楼层
好东西...
zw820506 发表于 2007-9-5 13:41 | 显示全部楼层
骗钱啊~~
不过,不能换电池,Apple的设计人员太狂妄了。或者设计是n年前已经定型了,那时候许多手机不能换电池。<br />-------------------------------<br />我以前Ipod&nbsp;photo换个电池要400<br />
wangkj 发表于 2007-9-5 17:07 | 显示全部楼层
只能说,硬件设计越来越垄断化了
小公司没法玩,资源都不给你开放!
qjy_dali 发表于 2007-9-5 17:10 | 显示全部楼层
不能换电池也不是完全没有优点
从产品本身来看,至少它的模具要相对简单点。要是加电池仓,就麻烦点了
HWM 发表于 2007-9-5 17:18 | 显示全部楼层
用什么MPU那是APPLE的选择,他有其技术和市场方面的通盘考虑
专业厂商不会因为对某种器件的所谓的“爱好”去作出自己的选择的。不过哪天选用了中国的“龙芯”到可以庆贺一下。
