static uint8 init[] = {<br /> LCD_BIT_MASK /*| LCD_BIT_COMMAND*/,<br />/* ST7549配置开始 */<br /> LCD_FUNCTION_SET | /*LCD_FUNCTION_SET_PD |*/ LCD_FUNCTION_SET_H0,<br /> LCD_BIAS_SYSTEM | LCD_BIAS_SYSTEM_6, /* 1/17 */<br /> LCD_CONFIGURE /*| LCD_CONFIGURE_DO*/, /* LSB,MSB的顺序 */<br /> LCD_SET_V_OP | 0x5, /* => 7500 mV (when PRS=1 set below, if TC=0 (or 27C!)) -- sample code uses 24 => 7470 mV for some reason */<br /> LCD_FUNCTION_SET, <br /> LCD_VOP_RANGE | LCD_VOP_RANGE_PRS, <br /> LCD_DISP_CONTROL | LCD_DISP_CONTROL_D /*| LCD_DISP_CONTROL_E*/,<br /> LCD_SET_X | 0,<br /> LCD_SET_Y | 0,<br />/* ST7549?*/ };<br />
