请推荐一款市场易买的且容易使用的音频DA
2537|3
kimjin|  楼主 | 2008-5-1 11:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ahong007| | 2008-5-1 17:44 | 只看该作者
320AIC23
keaiduoyu| | 2008-5-1 18:01 | 只看该作者
IIS DA
CS4344 CS4334 I2S接口
awey| | 2008-5-1 22:42 | 只看该作者
音频DA
PS9604Stereo [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=24-bit]24-Bit [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=192khz]192kHz PCM-to-PWM Converter for Full Digital Power Amplifier ETC
PCM160824-Bit [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=192khz]192kHz Sampling [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=8-channel]8-Channel [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=enhanced]Enhanced Multilevel [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=delta-sigma]Delta-Sigma DIGITAL-TO-ANALOG CONVERTER Texas Instruments
WM878124-Bit [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=192khz]192kHz Stereo ADC Wolfson Microelectronics plc
PCM1803SINGLE-ENDED [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=analog-input]ANALOG-INPUT 24-BIT [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=96-khz]96-kHz STEREO A/D CONVERTER Texas Instruments
PCM1808SINGLE-ENDED [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=analog-input]ANALOG-INPUT 24-BIT [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=96-khz]96-kHz STEREO A/D CONVERTER Burr-Brown Corporation
PCM179424BIT 192KHZ SAMPLING [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=]ADVANCED SEGMENT [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=audio]AUDIO STEREO DIGITAL TO ANALOG CONVERTER Texas Instruments
WM850124-bit 192kHz Stereo DAC with 1.7Vrms Line Driver Wolfson Microelectronics plc
CS536024-Bit Stereo A/D Converter for Digital Audio Cirrus Logic
DSD179624BIT 192KHZ SAMPLING ADVANCED SEGMENT AUDIO STEREO DIGITAL TO ANALOG CONVERTER Texas Instruments
PCM1804FULL DIFFERENTIAL ANALOG INPUT 24-BIT [/url][url=http://category.alldatasheet.com/index.jsp?semiconductor=192-khz]192-kHz STEREO A/D CONVERTER Burr-Brown Corporation
