2440 为什么 No NAND device found
4452|1
 楼主| americ 发表于 2007-8-16 15:05 | 显示全部楼层 |阅读模式
改写了&nbsp;一个&nbsp;BootLoader<br /><br />-----与ViVi相似.<br />不过是基于ADS<br /><br /><br /><br />现象:<br />1,用ViVi可以启动Kernel&nbsp;<br />&nbsp;&nbsp;&nbsp;Kernel&nbsp;command&nbsp;line:&nbsp;....<br /><br />&nbsp;&nbsp;其中<br />&nbsp;&nbsp;&nbsp;S3C24XX&nbsp;NAND&nbsp;Driver,&nbsp;(c)&nbsp;2004&nbsp;Simtec&nbsp;Electronics<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;s3c2440-nand:&nbsp;mapped&nbsp;registers&nbsp;at&nbsp;c4880000<br /><br />&nbsp;&nbsp;&nbsp;s3c2440-nand:&nbsp;timing:&nbsp;Tacls&nbsp;9ns,&nbsp;Twrph0&nbsp;39ns,&nbsp;Twrph1&nbsp;9ns<br /><br />&nbsp;&nbsp;&nbsp;NAND&nbsp;device:&nbsp;Manufacturer&nbsp;ID:&nbsp;0xec,&nbsp;Chip&nbsp;ID:&nbsp;0x76&nbsp;(<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Samsung&nbsp;NAND&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;64MiB&nbsp;3,3V&nbsp;8-bit)<br /><br /><br />2,用自己改写的,启动Kernel&nbsp;<br />&nbsp;&nbsp;&nbsp;Kernel&nbsp;command&nbsp;line:&nbsp;....与ViVi启动&nbsp;相同<br /><br />但是<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;s3c2440-nand:&nbsp;mapped&nbsp;registers&nbsp;at&nbsp;c4880000<br /><br />&nbsp;&nbsp;&nbsp;s3c2440-nand:&nbsp;timing:&nbsp;Tacls&nbsp;9ns,&nbsp;Twrph0&nbsp;39ns,&nbsp;Twrph1&nbsp;9ns<br /><br />&nbsp;&nbsp;&nbsp;No&nbsp;NAND&nbsp;device&nbsp;found!!!<br /><br /><br />以上,Kernel&nbsp;完全没改变-------仅仅把NAND&nbsp;起始的BootLoader替换成ViVi或者把ViVi替换成BootLoader..........两者切换,为什么这样?<br />仅仅认不出NAND----导致无法mount&nbsp;FS<br /><br /><br /><br /><br />
 楼主| americ 发表于 2007-8-21 11:17 | 显示全部楼层
你的Linux
有没有&nbsp;类似提示?<br /><br /><br />
