[文档下载] 刚刚收到的板子NuTiny-SDK-NUC505相关资料
3933|9
 楼主| gaoyang9992006 发表于 2015-4-10 21:23 | 显示全部楼层 |阅读模式
DVD大礼包         http://pan.baidu.com/s/1gdzTSHX
官网:http://www.nuvoton.com/hq/produc ... 5yo13y/?__locale=en
NUC505YO13Y
  • Overview
  • Resources
  • Where to buy
The NUC505YO13Y 32-bit microcontroller is embedded with the ARM® Cortex®-M4F core running up to 100 MHz, supports DSP FPU function, and provides 2 Mbytes embedded SPI Flash memory, and 128 Kbytes embedded SRAM. The NUC505YO13Y is also equipped with plenty of peripheral devices, such as USB Host/Device, Timers, Watchdog Timers, RTC, UART, SPI, I²S, I²C, PWM Timer, GPIO, 12-bit ADC, 24-bit Audio CODEC, Low voltage reset and Low voltage detector.
Target Application:
Thermal Printer, GPS Tracker, 2.4G Wireless Audio, Audio-related Applications, etc.
Key Features:
  • Core
    - ARM® Cortex®-M4F with DSP and FPU
    - Max frequency of 100 MHz
  • Memory
    - 128 KB of embedded SRAM
    - 2 MB of SPI Flash
  • Connectivity
    - USB 2.0 HS Device
    - Up to two USB 2.0 FS Host
    - Up to three UARTs
    - Up to three SPIs
    - Up to two I²Cs (Up to 1 MHz)
    - SD Host
  • Security for code protect
    - 128-bit key for code protection against illegal pirating
    - Supports multi-entry for 15 times
  • RTC
    - Supports external power pin VBAT
    - 32 bytes spare registers
  • I²S
    - Supports Master or Slave mode operation
    - Internal PLL for frequency adjustment
    - Supports PCM mode A, PCM mode B, I²S and MSB justified data format
    - Supports DMA mode
  • 12-bit ADC
    - Up to eight channels
    - Up to 1MSPS conversion with ADC_CH1, and up to 200 kSPS with others (except ADC_CH0)
  • Audio CODEC
    - Embedded Stereo 24-bit Sigma-Delta CODEC output
    - ADC-THDN: -80 dB, Dynamic Range SNR: 90 dB (A-Weighted)
    - Headphone Output-THDN:-60dB, Dynamic Range SNR: 93 dB (A-Weighted)
    - Sample Rate: 8 kHz to 96 kHz
  • Packages
    - QFN88
    - Temperature range: -40℃~+85℃
[url=]Data Sheet[/url]
Part No.
Buy
Flash
SRAM
Data Flash
ISP ROM
PDMA
I/O
Timer
UART
ISO-7816-3
SPI
I2C
CAN
LIN
EBI
I2S/ AC97
USB OTG
USB Host
USB Device
PWM
Comparator
DAC
ADC
Audio Codec
Touch Key
RTC
Tamper Detect (pin)
Voltage Adjustable Interface
ISP/ICP/IAP
Package
Operating Temp. Range (¢FXC )
Status
SD Host
Ethernet MAC
Camera Interface
QEI
OP Amp.
Crypto
NUC505YO13Y2048K*128K 524*32-bit3 32 1 FSHS4*16-bit 8*12-bit24-bit ISP, ICPQFN88-40 to +85Mass ProductionY Y*
 楼主| gaoyang9992006 发表于 2015-4-10 21:25 | 显示全部楼层
DS_NUC505_Series_EN_Rev1.01
http://www.nuvoton.com/hq/resource-download.jsp?tp_GUID=DA00-NUC505
BSP_NUC505_v3.00.003
http://www.nuvoton.com/hq/resource-download.jsp?tp_GUID=SW0120141215140101
TRM_NUC505_Series_EN_Rev1.01
http://www.nuvoton.com/hq/resource-download.jsp?tp_GUID=DA05-NUC505
NuTiny-SDK-NUC505_V1.4
http://www.nuvoton.com/hq/resource-download.jsp?tp_GUID=HL0120150213163240
598330983 发表于 2015-4-12 20:59 来自手机 | 显示全部楼层
顶楼主呀,这么好,那个dvd原来在这里
quray1985 发表于 2015-4-13 08:41 | 显示全部楼层
谢谢楼主的无私分享
定能从中间学到不少好东西
coslight 发表于 2015-4-13 09:22 | 显示全部楼层
顶一下资料分享
xinba0625 发表于 2015-10-29 17:50 | 显示全部楼层
点击链接加入群【Nuvoton NUC505】:http://jq.qq.com/?_wv=1027&k=aBPl1W
 楼主| gaoyang9992006 发表于 2015-10-29 19:41 | 显示全部楼层
很久以前发的帖子了,还有人回复,真好。
芙蓉洞 发表于 2015-10-29 21:34 | 显示全部楼层
谢谢楼主的热心分享啊,受教了
草原飞天哥 发表于 2016-8-27 20:14 | 显示全部楼层
谢谢。找到
捉虫天师 发表于 2016-8-27 20:16 | 显示全部楼层
不是被楼上的朋友顶上来,我还真不知道在网上可以下载到这个大礼包。
2106
