宏定义
1009|3
juventus9554|  楼主 | 2015-4-16 21:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AD, ADC, CD, dc, TE
汇编手册的宏定义很简单,而且后面的参数 P1 P2 啊这些都有用到,
add3 .macro P1, P2, P3, ADDRP
MOV ACC, P1
ADD ACC, P2
ADD ACC, P3
ADD ACC, ADDRP
.endm
为什么下面的宏定义里面就没有任何关于m,n这些参数的应用。
ADCDRV_8ch_INIT    .macro m,n,p,q,r,s,t,u
_ADCDRV_8ch_RltPtrA    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 1
_ADCDRV_8ch_RltPtrB    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 2
_ADCDRV_8ch_RltPtrC    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 3
_ADCDRV_8ch_RltPtrD    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 4
_ADCDRV_8ch_RltPtrE    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 5
_ADCDRV_8ch_RltPtrF    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 6
_ADCDRV_8ch_RltPtrG    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 7
_ADCDRV_8ch_RltPtrH    .usect "ADCDRV_8ch_Section",2,1,1    ; output terminal 8
; publish Terminal Pointers for access from the C environment
        .def     _ADCDRV_8ch_RltPtrA
        .def    _ADCDRV_8ch_RltPtrB
        .def    _ADCDRV_8ch_RltPtrC
        .def    _ADCDRV_8ch_RltPtrD
        .def     _ADCDRV_8ch_RltPtrE
        .def    _ADCDRV_8ch_RltPtrF
        .def    _ADCDRV_8ch_RltPtrG
        .def    _ADCDRV_8ch_RltPtrH
        MOVL    XAR2, #ZeroNet                        ; "ZeroNet" is address to a location initialised to 0
        MOVW    DP, #_ADCDRV_8ch_RltPtrA
        MOVL    @_ADCDRV_8ch_RltPtrA, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrB, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrC, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrD, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrE, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrF, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrG, XAR2            ; zero output terminal pointer
        MOVL    @_ADCDRV_8ch_RltPtrH, XAR2            ; zero output terminal pointer
        .endm
司徒老鹰| | 2015-4-16 21:10 | 只看该作者
_ADCDRV_8ch_RltPtrA,这些是定义地址的,它可以在CMD文件中找到,或者用#pragma 转向
上面是定义指令的,
llljh| | 2015-4-16 21:11 | 只看该作者
有没有可能这些变量在其它地方使用过,又或者这个程序经过许多人改过,原来使用了,现在没有这些变量。
juventus9554|  楼主 | 2015-4-16 21:11 | 只看该作者
呵呵,想法很多啊大家
