[i.MX] imx6solo wm8960始终没有声音输出
6898|13
 楼主| eskytan 发表于 2015-4-21 18:05 | 显示全部楼层 |阅读模式
我尝试各种办法,wm8960始终不能得到声音输出。调试过程如下:
首先,打开电源使能脚:
       ret=gpio_request(SABRESD_CODEC_PWR_EN, "audio_pwr_en");
       if (!ret){
              printk("Turn on audio(wm8962) power!(1:enable)\n");
              gpio_direction_output(SABRESD_CODEC_PWR_EN, 1);         // 0:enable, 1:disable
              gpio_free(SABRESD_CODEC_PWR_EN);
串口打印如下出错信息:
wm8962 0-001a: Failed to get supply 'SPKVDD1': -19
wm8962 0-001a: Failed to request supplies: -19
wm8962 0-001a: asoc: failed to probe CODEC wm8962.0-001a: -19
asoc: failed to instantiate card wm8962-audio: -19
Initialize HDMI-audio failed. Load HDMI-video first!
ALSA device list:
  No soundcards found.
把imx6q_init_audio();后移几行,上面的错误就没有了。但出现下面错误 :
wm8962 0-001a: Device is not a WM8962, ID 0 != 6243
wm8962 0-001a: asoc: failed to probe CODEC wm8962.0-001a: -22
asoc: failed to instantiate card wm8962-audio: -22
把sound/soc/codec/下面的wm8962.c改用wm8960.c(修改Kconfig和Makefile)。
wm8960_i2c_probe不调用。原因是:
       .driver = {
              .name = "wm8960",
而   {
              I2C_BOARD_INFO("wm8962", 0x1a),
              .platform_data = &wm8962_config_data,
linux driver是根据name来匹配的,如果匹配就调用。
登记了snd_soc_register_codec后,codec的probe也不调用。
原因是下面这个snd_dai_driver的name要一致才能调用。
static struct snd_soc_dai_driver wm8960_dai = {
       .name = "wm8960",
static struct snd_soc_dai_link imx_dai[] = {
              .name = "HiFi",
              .stream_name = "HiFi",
              .codec_dai_name       = "wm8960",
调用后显示:
wm8960 0-001a: wm8960 probed success!
wm8960 0-001a: Failed to add route HPOUTL->Headphone Jack
asoc: wm8960 <-> imx-ssi.1 mapping ok
input: wm8960-audio DMIC as /devices/platform/soc-audio.5/sound/card0/input1
input: wm8960-audio Ext Spk as /devices/platform/soc-audio.5/sound/card0/input2
ALSA device list:
  #0: wm8960-audio
root@imx6solo ~$ find / -name *wm8960*
/sys/devices/platform/imx-wm8960.0
/sys/bus/platform/devices/imx-wm8960.0
/sys/bus/platform/drivers/imx-wm8960
/sys/bus/platform/drivers/imx-wm8960/imx-wm8960.0
/sys/bus/i2c/drivers/wm8960
/proc/asound/wm8960audio
root@imx6solo ~$
问题是/dev/下面并没有增加设备,无法使用/dev/pcm。
root@imx6solo /usr/bin$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
root@imx6solo /usr/bin$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: wm8960audio [wm8960-audio], device 0: HiFi wm8960-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
现在应该是试试ALSA驱动程序是不是真能用的时候了. 接者就是使用它.
查看声卡是否存在:
root@imx6solo ~$ cat /proc/asound/cards
0 [wm8960audio    ]: wm8960-audio - wm8960-audio
                      wm8960-audio
ALSA 驱动程序在 /dev/snd/ 目录下有自己的驱动程序。
root@imx6solo ~$ ls /dev/snd/
controlC0  pcmC0D0c   pcmC0D0p   timer
http://www.alsa-project.org/main/index.php/Download上面下载alsa tester包括alsa-lib, alsa-utils。
编译:./gitcompile CC=arm-linux-gcc --host=arm-linux
现在进化到configure都从网络上临时下载的地步了,我有点out了。
编译alsa-utils总是过不去。重新下载alsaplayer。
./configure --host=arm-linux CC=arm-linux-gcc --disable-oggvorbis
然后make.
对比了wm8960.c/wm8962.c, imx-wm8960.c/imx-wm8962.c,差别其实非常大。
https://bbs.21ic.com/forum.php?mod=viewthread&tid=869393,从这个链接地址可以下载imx-wm8960.c。
重新配置linux kernel,设备/dev/dsp和/dev/mixer出来,这是OSS接口的要求。
root@imx6solo /test/audio$ ./wavplay test.wav
File Magic:         [RIFF]
File Length:        [424636]
File Type:          [WAVE]
Fmt Magic:          [fmt ]
Fmt Size:           [16]
Fmt Format:         [PCM]
Fmt Channels:       [2]
Fmt Sample_rate:    [22050](HZ),22khz
Fmt Bytes_p_second: [88200]
Fmt Blocks_align:   [4]
Fmt Sample_length:  [16]
Chunk Type:         [data]
Chunk Length:       [424600]
Plug PCM: Rate conversion PCM (44100, sformat=S16_LE)
Converter: linear-interpolation
Protocol version: 10002
Its setup is:
  stream       : PLAYBACK
  access       : RW_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 22050
  exact rate   : 22050 (22050/1)
  msbits       : 16
  buffer_size  : 8192
  period_size  : 256
  period_time  : 11609
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 256
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 8192
  silence_threshold: 0
  silence_size : 0
  boundary     : 536870912
Slave: Direct Stream Mixing PCM
Its setup is:
  stream       : PLAYBACK
  access       : MMAP_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 44100         //44khz
  exact rate   : 44100 (44100/1)
  msbits       : 16
  buffer_size  : 16384
  period_size  : 512
  period_time  : 11609
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 512
  period_event : 0
  start_threshold  : 2
  stop_threshold   : 16384
  silence_size : 0
  boundary     : 1073741824
Hardware PCM card 0 'wm8960-audio' device 0 subdevice 0
Its setup is:
  stream       : PLAYBACK
  format       : S16_LE
  subformat    : STD
  channels     : 2
  msbits       : 16
  buffer_size  : 16384
  period_size  : 512
  period_time  : 11609
  tstamp_mode  : ENABLE
  period_step  : 1
  avail_min    : 512
  period_event : 0
  start_threshold  : 1
  stop_threshold   : 1073741824
  silence_size : 1073741824
  appl_ptr     : 0
  hw_ptr       : 0
root@imx6solo /test/audio$ aplay test.wav
Playing WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 22050 Hz, Stereo
Aborted by signal Interrupt...
仍然是没有声音输出!!
换了一个44khz采集率的wav文件,仍然没有声音输出!
root@imx6solo /test/audio$ aplay xihuanni.wav
Playing WAVE 'xihuanni.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
再次检查了pin mux config,是正确的。但就是没有任何audio输出!
如果直接用imx-wm8962.c,则有许多出错信息,如下:
WM8960 PLL: Unsupported N=3
Failed to start FLL: -22
Failed to set SYSCLK: -22
asoc: machine hw_params failed
ALSA lib pcm_direct.c:980:(snd1_pFailed to set SYSCLK: -22
cm_direct_initialize_slave) unable to install hw params
ALSA lib pcm_dmix.c:1030:(snd_pcm_dmix_open) unable to initialize slave
aplay: main:660: audio open error: Invalid argument
所以,要用imx-wm8962.c来修改的话,还有点麻烦,不会很容易。
网上找了一个人交流,他用的是imx-wm8960.module,就是编译出来的.o
ifneq ($(wildcard sound/soc/imx/imx-wm8960.c),)
snd-soc-imx-wm8960-objs := imx-wm8960.c
else
snd-soc-imx-wm8960-objs := imx-wm8960.module
endif
我这样修改后,运行导致crash。
register wm8960 I2C driver success!
Unable to handle kernel paging request at virtual address f8f2fe18
pgd = 80004000
[f8f2fe18] *pgd=1bce9811, *pte=00000000, *ppte=00000000
Internal error: Oops: 807 [#1] PREEMPT
Modules linked in:
CPU: 0    Not tainted  (3.0.101-2790-gc248ed7 #274)
598330983 发表于 2015-4-21 20:43 | 显示全部楼层
确实有。o的输出,不过我也见过hex的,都是可以自己设定的。
FSL_TICS_Rita 发表于 2015-4-22 11:36 | 显示全部楼层
楼主你好,我看到你的这个问题在我们的英文论坛上也提交了同样的问题:https://community.freescale.com/thread/353072。请问你这里使用的是哪个版本的BSP?
 楼主| eskytan 发表于 2015-4-22 12:03 | 显示全部楼层
L3.0.101_4.1.1_141016_source,CPU是imx6 solo。
 楼主| eskytan 发表于 2015-4-22 12:04 | 显示全部楼层
楼主你好,我看到你的这个问题在我们的英文论坛上也提交了同样的问题:https://community.freescale.com/th ...
是的。提交了同样的问题,同样没有人回复啊。
FSL_TICS_Rita 发表于 2015-4-22 12:19 | 显示全部楼层
关于这个问题我也不是很熟悉,我帮你催一下,请耐心等待哈~~英文论坛上问题处理的话,一般都是48小时内的。
 楼主| eskytan 发表于 2015-4-22 12:44 | 显示全部楼层
先验证了i2c,示波器显示有输出,并且测了看device addr也是0x1A。
alsamixer配置也是全部拉高,退出后重新进入,也是对的,可以保存和读出。
i2s data仍然没有,数据线对地电阻也测了,并没有短路。
FSL_TICS_Rita 发表于 2015-4-22 15:53 | 显示全部楼层
alsamixer配置也是全部拉高,退出后重新 ...
OK。
FSL_TICS_Rita 发表于 2015-4-22 17:06 | 显示全部楼层
楼主你好,我们的工程师已经给你回复了,建议你参考我们英文论坛中的帖:
https://community.freescale.com/message/332170#332170
please double check the IOMUX setting that is match with your own hardware design.
 楼主| eskytan 发表于 2015-4-22 18:18 | 显示全部楼层
仔细查了linux代码,没有i2s部分,应该是改成SSI了。
ssi有两个,一个是在driver/mxc/ssi.c,这个是以前的。
现在是sound/soc/imx/imx-ssi.c。
imx6q_add_imx_ssi(1, &mx6_sabresd_ssi_pdata); 注册为platform device。
加了一句打印:
imx_ssi_probe successfully。证明probe是被调用了的。
snd_pcm_dmix_open()
snd1_pcm_hw_open_fd()
snd_pcm_plug_open()
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
snd_pcm_mmap_writei
然后挂起,ssi接口无输出,应该是mixer配置不正确。
 楼主| eskytan 发表于 2015-4-23 16:19 | 显示全部楼层
iomux setting检查了,都改为MX6DL_ADU_PAD_CTRL了,无济无事!
 楼主| eskytan 发表于 2015-4-23 18:33 | 显示全部楼层
我怀疑是软件原因:
在static int imx_ssi_probe(struct platform_device *pdev)中,
        ret = snd_soc_register_dai(&pdev->dev, dai);
        if (ret) {
                dev_err(&pdev->dev, "register DAI failed\n");
                goto failed_register;
而在static __devinit int wm8960_i2c_probe(struct i2c_client *i2c,
                                      const struct i2c_device_id *id)中,
        ret = snd_soc_register_codec(&i2c->dev,
                        &soc_codec_dev_wm8960, &wm8960_dai, 0);
Registered DAI 'wm8960-hifi'
Registered DAI 'imx-ssi.1'
设置audio参数时,imx_hifi_hw_params()中调用的是wm8960-hifi的DAI驱动。
现在的问题是SSI的imx_ssi_set_dai_sysclk()或imx_ssi_set_dai_sysclk()都无法调用,我不知道这是否是SSI的BCLK无信号的原因。
FSL_TICS_Rita 发表于 2015-4-24 14:11 | 显示全部楼层
我怀疑是软件原因:
        ret = snd_soc_regis ...
楼主你好,我们的工程师在英文论坛上给你回复了,请注意查看哈~~
 楼主| eskytan 发表于 2015-4-24 18:12 | 显示全部楼层
始终不行啊,代码我都帖上去了。请帮忙看看。。。
