特向大家推荐一款多功能ARM SOC芯片
5018|17
 楼主| ysdx 发表于 2008-3-11 22:07 | 显示全部楼层 |阅读模式
开发系统支持LINUX/WINCE。特别适合做机顶盒、广告*、数码相框、PDA等音视频的东西。功耗很低。我已经用它开发了2款产品,感觉不错。对了,价格很好。谁知道如何把数据手册上传到主页的资料库中?
 楼主| ysdx 发表于 2008-3-11 22:11 | 显示全部楼层
Video&nbsp;Interface<br />–&nbsp;Supports&nbsp;NTSC&nbsp;(M,&nbsp;J,&nbsp;4.43),&nbsp;PAL&nbsp;(B,&nbsp;D,&nbsp;G,&nbsp;H,&nbsp;I,&nbsp;M,&nbsp;N,&nbsp;Nc),&nbsp;PAL-60&nbsp;TV&nbsp;Standard&nbsp;Video&nbsp;out&nbsp;and<br />Progressive&nbsp;Scan&nbsp;(525P/625P,&nbsp;RGB/YPbPr)&nbsp;Component&nbsp;Video&nbsp;out&nbsp;(compliant&nbsp;with&nbsp;EIA770-1/2)<br />–&nbsp;Four&nbsp;built-in&nbsp;54&nbsp;MHZ/10-bits&nbsp;Video&nbsp;DACs&nbsp;Providing&nbsp;Video&nbsp;Outputs&nbsp;of&nbsp;Composite,&nbsp;S-Video,&nbsp;or<br />Component&nbsp;(YUV,&nbsp;RGB,&nbsp;.)<br />–&nbsp;Compliant&nbsp;with&nbsp;Macrovision&nbsp;7.1&nbsp;for&nbsp;Interlaced&nbsp;Video&nbsp;(NTSC,&nbsp;PAL);&nbsp;Macrovision&nbsp;AGC&nbsp;1.2&nbsp;for<br />Progressive&nbsp;Scan&nbsp;(525P,&nbsp;625P)<br />–&nbsp;Encoder&nbsp;of&nbsp;WSS&nbsp;(Wide&nbsp;Screen&nbsp;Signaling)&nbsp;for&nbsp;PAL&nbsp;Formats<br />–&nbsp;Encoder&nbsp;of&nbsp;CGMS&nbsp;(Copy&nbsp;Generation&nbsp;Management&nbsp;System)&nbsp;for&nbsp;NTSC&nbsp;Formats<br />–&nbsp;Supports&nbsp;Close&nbsp;Captioning<br />–&nbsp;Programmable&nbsp;LUMA/CHROMA&nbsp;Filters<br />–&nbsp;Programmable&nbsp;LUMA/CHROMA&nbsp;Delay&nbsp;(Y&nbsp;to&nbsp;C&nbsp;or&nbsp;C&nbsp;to&nbsp;Y)<br />–&nbsp;On-chip&nbsp;Image&nbsp;/&nbsp;Video&nbsp;Enhancement&nbsp;Filtering,&nbsp;e.g.&nbsp;Brightness&nbsp;/&nbsp;Contrast&nbsp;/&nbsp;Saturation&nbsp;/&nbsp;Hue<br />Adjustment<br />–&nbsp;Automatic&nbsp;Detection&nbsp;of&nbsp;Video&nbsp;DAC&nbsp;Connection&nbsp;Presence&nbsp;for&nbsp;Power-Saving&nbsp;Capability<br />–&nbsp;Supports&nbsp;VGA&nbsp;Output&nbsp;Mode&nbsp;for&nbsp;PC&nbsp;Monitor<br />–&nbsp;Supports&nbsp;Simultaneous&nbsp;Interlaced&nbsp;Video&nbsp;(CVBS,&nbsp;S-Video)&nbsp;and&nbsp;Progressive&nbsp;Video&nbsp;(525P/625P,<br />RGB/YPbPr)&nbsp;Outputs<br />–&nbsp;Supports&nbsp;Direct&nbsp;CCIR-601/656&nbsp;Digital&nbsp;Video&nbsp;Output&nbsp;for&nbsp;External&nbsp;TV&nbsp;Encoder&nbsp;/&nbsp;Video&nbsp;Processor<br />–&nbsp;Supports&nbsp;Direct&nbsp;CCIR-601/656&nbsp;Digital&nbsp;Video&nbsp;Input&nbsp;from&nbsp;External&nbsp;video&nbsp;Decoder<br />–&nbsp;Supports&nbsp;Direct&nbsp;ITU1120&nbsp;and&nbsp;SMPTE274M&nbsp;Digital&nbsp;Video&nbsp;Output&nbsp;for&nbsp;External&nbsp;High&nbsp;Definition&nbsp;TV<br />Encoder
High-Color&nbsp;VGA&nbsp;STN/TFT&nbsp;LCD&nbsp;Controller&nbsp;with&nbsp;Dedicated&nbsp;DMA<br />–&nbsp;Supports&nbsp;Both&nbsp;Passive&nbsp;STN&nbsp;and&nbsp;Active&nbsp;TFT&nbsp;Panels<br />–&nbsp;Panel&nbsp;Size:&nbsp;QVGA,&nbsp;VGA,&nbsp;up&nbsp;to&nbsp;800x480<br />–&nbsp;Panel&nbsp;Interface:&nbsp;STN&nbsp;–&nbsp;4&nbsp;or&nbsp;8&nbsp;bits,&nbsp;TFT&nbsp;–&nbsp;16,&nbsp;18,&nbsp;or&nbsp;24&nbsp;bits<br />–&nbsp;Bits&nbsp;per&nbsp;Pixel:&nbsp;STN&nbsp;Monochrome&nbsp;-&nbsp;1,&nbsp;2&nbsp;and&nbsp;4&nbsp;bpp&nbsp;-&nbsp;up&nbsp;to&nbsp;16&nbsp;Gray&nbsp;Levels,&nbsp;STN&nbsp;Color&nbsp;-&nbsp;1,&nbsp;2,&nbsp;4,<br />8&nbsp;and&nbsp;12&nbsp;bpp&nbsp;-&nbsp;up&nbsp;to&nbsp;4096&nbsp;Colors,&nbsp;TFT&nbsp;Color&nbsp;-&nbsp;1,&nbsp;2,&nbsp;4,&nbsp;8,&nbsp;16,&nbsp;18,&nbsp;24&nbsp;bpp&nbsp;-&nbsp;up&nbsp;to&nbsp;16M&nbsp;colors<br />–&nbsp;256&nbsp;Entry&nbsp;by&nbsp;16-bit&nbsp;Palette&nbsp;for&nbsp;Palletized&nbsp;Gray&nbsp;Levels&nbsp;or&nbsp;Colors<br />–&nbsp;Frame&nbsp;Rate&nbsp;Control&nbsp;-&nbsp;Temporal&nbsp;Dithering&nbsp;to&nbsp;16&nbsp;Gray&nbsp;Levels<br />–&nbsp;Programmable&nbsp;Panel&nbsp;Timing&nbsp;Signals<br />–&nbsp;Hardware&nbsp;Scrolling&nbsp;for&nbsp;Virtual&nbsp;Screen<br />–&nbsp;LCD&nbsp;Formatter&nbsp;to&nbsp;Convert&nbsp;TV&nbsp;Video&nbsp;Format&nbsp;to&nbsp;LCD&nbsp;Video&nbsp;Format
 楼主| ysdx 发表于 2008-3-11 22:12 | 显示全部楼层
Audio&nbsp;Decoder&nbsp;by&nbsp;DSP<br />–&nbsp;Multiple&nbsp;Audio&nbsp;Format&nbsp;Decoding&nbsp;Capability:&nbsp;MPEG&nbsp;Layer&nbsp;I/II&nbsp;&&nbsp;MP3,&nbsp;WMA,&nbsp;AAC,&nbsp;AAC&nbsp;Plus,<br />Dolby&nbsp;Digital&nbsp;(AC-3),&nbsp;DTS,&nbsp;MPEG-2&nbsp;MC&nbsp;extensions,&nbsp;Linear&nbsp;PCM,&nbsp;LPCM&nbsp;multi-channel&nbsp;and<br />MLPTM&nbsp;(Meridian&nbsp;Lossless&nbsp;Packing)<br />–&nbsp;Audio&nbsp;Post-Processing&nbsp;Capability<br />–&nbsp;Built-in&nbsp;Prompting&nbsp;Beep&nbsp;Sound&nbsp;Generator&nbsp;for&nbsp;Operating&nbsp;User-friendly&nbsp;and&nbsp;Test&nbsp;Tone&nbsp;Generator<br />for&nbsp;Speaker&nbsp;Setup<br /><br />Audio&nbsp;Interface<br />–&nbsp;Supports&nbsp;2&nbsp;Channels&nbsp;PCM&nbsp;Input&nbsp;Interface&nbsp;for&nbsp;External&nbsp;Audio&nbsp;ADC&nbsp;Interface&nbsp;and&nbsp;Audio&nbsp;Decoder<br />–&nbsp;Provides&nbsp;2&nbsp;to&nbsp;8&nbsp;Channel&nbsp;PCM&nbsp;and&nbsp;Simultaneous&nbsp;2&nbsp;Channel&nbsp;Stereo&nbsp;Downmixed&nbsp;PCM&nbsp;under<br />Flexible&nbsp;Output&nbsp;Interface&nbsp;for&nbsp;Different&nbsp;Audio&nbsp;DAC&nbsp;Configurations<br />–&nbsp;On-chip&nbsp;Audio&nbsp;Frequency&nbsp;Synthesizer&nbsp;to&nbsp;Support&nbsp;Different&nbsp;Sampling&nbsp;Rate&nbsp;up&nbsp;to&nbsp;192KHz<br />–&nbsp;Supports&nbsp;Dolby&nbsp;Digital/DTS/MPEG&nbsp;S/PDIF&nbsp;(IEC-61937)&nbsp;Digital&nbsp;Audio&nbsp;Bitstream&nbsp;or&nbsp;Raw&nbsp;PCM<br />S/PDIF&nbsp;(IEC-60958)&nbsp;Audio&nbsp;Output<br />–&nbsp;Supports&nbsp;S/PDIF&nbsp;Digital&nbsp;Audio&nbsp;Input&nbsp;Interface&nbsp;(IEC-61937&nbsp;Compressed&nbsp;Bitstream,&nbsp;IEC-60958<br />Raw&nbsp;PCM)&nbsp;for&nbsp;DVD&nbsp;Receiver&nbsp;Application<br />–&nbsp;AC97&nbsp;Audio&nbsp;Interface<br />–&nbsp;I2S&nbsp;Audio&nbsp;Interface<br /><br />Pulse&nbsp;Code&nbsp;Modulation<br />–&nbsp;Four-signal&nbsp;Interface&nbsp;(Clock,&nbsp;Input,&nbsp;Output&nbsp;and&nbsp;Sync)<br />–&nbsp;Full-duplex&nbsp;Synchronous&nbsp;Serial&nbsp;Data&nbsp;Transfer<br />–&nbsp;Supports&nbsp;Master&nbsp;and&nbsp;Slave&nbsp;Modes<br />–&nbsp;Supports&nbsp;Long&nbsp;or&nbsp;Short&nbsp;Frame&nbsp;sync<br />–&nbsp;All&nbsp;Transfers&nbsp;are&nbsp;16-bit&nbsp;(8,&nbsp;13,&nbsp;14,&nbsp;and&nbsp;16-bit&nbsp;data&nbsp;formats&nbsp;supported)<br />–&nbsp;16-bit&nbsp;Wide&nbsp;Sample&nbsp;Data&nbsp;by&nbsp;16&nbsp;Samples&nbsp;Deep&nbsp;FIFOs&nbsp;Each&nbsp;for&nbsp;Transmit&nbsp;and&nbsp;Receive<br />
zymkt 发表于 2008-3-11 22:13 | 显示全部楼层
fanyi
cly1005 发表于 2008-3-11 22:14 | 显示全部楼层
看上去还可以,贵不?
 楼主| ysdx 发表于 2008-3-11 22:20 | 显示全部楼层
不能直接说价格。只能说和ST同等功能的比,价格是一半左右
说实在的,很公道很公道。
mmd2102 发表于 2008-3-11 23:01 | 显示全部楼层
专用的
要用有市场的CPU,不是最便宜的CPU
 楼主| ysdx 发表于 2008-3-12 14:54 | 显示全部楼层
CPU是否有市场,大家都不关心。
大家关心的是自己用CPU设计的产品是否有利润。利润何来?产品销量、产品成本、产品销售价格三者恐怕是关键。
brandnew 发表于 2008-3-12 15:07 | 显示全部楼层
楼主,还是说点实际的吧,在哪个地方可以买到这个片子,北京,上海,深圳?<br /><br />有怎样的开发资源可以提供?样片,开发板,linux&nbsp;wince驱动等等。<br /><br />谁分销via的产品?
kar98k 发表于 2008-3-12 15:11 | 显示全部楼层
资料能不能再详细些,芯片供货?开发系统?
smartdsp 发表于 2008-3-13 07:47 | 显示全部楼层
好东西,就是不知道平台成熟不
LPcfANS 发表于 2008-3-13 08:36 | 显示全部楼层
网址?
deeploves 发表于 2008-3-14 09:29 | 显示全部楼层
应该是专用芯片
用专用芯片开发产品对量小的人来说太可怕了,随时会停产
