带SATA II接口的ARM
6845|4
 楼主| wenming 发表于 2008-3-24 21:10 | 显示全部楼层 |阅读模式
看起来比较爽<br /><br />500Mhz&nbsp;ARM9&nbsp;CPU&nbsp;&nbsp;<br />Internal&nbsp;PCI&nbsp;bus,&nbsp;PC/104&nbsp;connector&nbsp;&nbsp;<br />128MB&nbsp;DDR-RAM&nbsp;&nbsp;<br />512MB&nbsp;NAND&nbsp;Flash&nbsp;(17MB/s)&nbsp;&nbsp;<br />12,000&nbsp;LUT&nbsp;user-programmable&nbsp;FPGA&nbsp;&nbsp;<br />2&nbsp;SD&nbsp;Card&nbsp;slots&nbsp;(1&nbsp;micro-SD,&nbsp;1&nbsp;full-SD)&nbsp;&nbsp;<br />2&nbsp;SATA&nbsp;ports&nbsp;&nbsp;<br />2&nbsp;USB&nbsp;2.0&nbsp;480Mbit/s&nbsp;host/slave&nbsp;&nbsp;<br />Gigabit&nbsp;Ethernet,&nbsp;10/100/1000&nbsp;speeds&nbsp;&nbsp;<br />5&nbsp;10-bit&nbsp;ADC&nbsp;channels&nbsp;&nbsp;<br />10&nbsp;serial&nbsp;ports,&nbsp;2&nbsp;optional&nbsp;RS-485&nbsp;&nbsp;<br />110&nbsp;GPIO&nbsp;(86&nbsp;as&nbsp;a&nbsp;PC/104&nbsp;bus)&nbsp;&nbsp;<br />Matrix&nbsp;Keypad&nbsp;and&nbsp;text&nbsp;LCD&nbsp;support&nbsp;&nbsp;<br />Optional&nbsp;Temp&nbsp;Sensor,&nbsp;RTC&nbsp;and&nbsp;WiFi&nbsp;&nbsp;<br />Low-power&nbsp;(4W&nbsp;@&nbsp;5V)&nbsp;&nbsp;<br />Sleep&nbsp;mode&nbsp;(uses&nbsp;200&nbsp;microamps)&nbsp;&nbsp;<br />Fanless&nbsp;Operation&nbsp;from&nbsp;-20°C&nbsp;to&nbsp;+70°C&nbsp;&nbsp;<br />Linux&nbsp;Boot&nbsp;time&nbsp;under&nbsp;2&nbsp;seconds&nbsp;&nbsp;<br />Kernel&nbsp;2.6&nbsp;and&nbsp;Debian&nbsp;Linux&nbsp;&nbsp;<br />
boy123 发表于 2008-3-24 21:21 | 显示全部楼层
用起来也爽吧.
 楼主| wenming 发表于 2008-3-25 09:33 | 显示全部楼层
国内有MARVELL的代理吗
fhwclq 发表于 2008-3-25 14:01 | 显示全部楼层
SATA实测读写速度是多少?
SATA实测读写速度是多少?
tonychow 发表于 2008-3-26 00:45 | 显示全部楼层
AVNET代理Marvell
